Yeah, I was interested in theirs but they are pricy and they don’t seem to be doing them anymore. I would love to be able to buy a good BLF lightbar, I’ve held off on getting one for a while because none of the good manufacturers really make what I want. Your specs are pretty much identical to what I would want- 4k-5k (as warm as we can go without taking an output penalty) , high CRI, weatherproof, on-off only. A good mix of throw/ flood would also be a necessity for me.
A whole lineup would probably be possible. I would be interested in a ~12”, a ~50”, and a couple of cube lights depending on price.
Thats the issue with a large light bar. By the time you get the custom parts and the labor of making one off lights the price is gonna be sky high. Most people aint gonna want to spend it.
Another issue is aiming for middel of the road stats or price point. The cheep guys will say you are price gouging and there lights aRe Gude’Nuff. The high end guys will just trash your product for being over priced imported crap made at the same factory and just charging more.
It is a no win situation for the manufactures. Even I would like a few light bars, I just don’t like the mounting options for my daily commuter rig.
If price will surely be an issue in a 20” light bar (with C8 reflectors/XHP50.2), I suggest just a shorter one that can house let’s say 4 reflectors per modular, EXPANDABLE housing, as nowadays a single C8 is already quite impressive compared to a pair of car OEM headlights.
I understand that to actually sell a light bar it would have to have at least the appearance of having a ton of emitters even if they weren't needed . What about a mixture of high power and interlaced with B.S. cheaper annoying colored emitters and a supersonic stupid mode which dazzled and hypnotized the less led literate .Maybe a moon mode of High Cri 5MM leds for map reading :p
I’m keen. Need to measure if 20” would fit on a ‘standard’ nudge bar as well as a full on bull bar to keep the market open. I will do some measurements and come back.
I guess as a first attempt a 12” bar would work fine.
But looking on banggood, they seem to offer a selection all under $140
Now don’t get me wrong. I know that those ones are likely dreadful.
But we all know that a good tint LED doesn’t really cost anything more than poor tint ones.
Just as we have with flashlights (Kronos X6, BLF A6, etc). I’m sure an existing housing could simply be utilised with different emitters and electronics. I was thinking for a 20” bar to be in the $120-300 price range depending on exact size.
I know this is all fantasy. But I can see it being feasible. And should places like Banggood want to stock and sell such an item (maybe with involvement from someone like Lumintop/Manker etc). Then I see such an item being potentially a good seller too.
I thought about this a few times. If I were to make it, it would be just to do it. There isn’t a way to make them cost effectively for the non-bulk manufacturer. Materials just cost too much.
You got me interested again though. I haven’t made a light in a while. I might put this on my TO DO List.
I have been thinking about an offroad lighting setup that uses fewer, higher intensity leds, and bigger reflectors, mainly to keep costs down but also to keep blinding stray light (spill) to a minimum.
My thoughts keep going to the SBT90.2 in about 2.5” reflectors… im guessing youd get around 400kcd, which would be pretty awesome. I wouldnt know how to power it in a 12 volt system tho.
Does anybody make a 25ish amp buck driver for 12-14 volts?
It would be much easier to just hook (probably 4) them up in series and direct drive. The drawback is that the light bar would have a multiple of 4 LEDs on it. Not really a big deal.
A bigger deal is the current draw. 18 amps x 4 is a lot for small alternators.
I like the idea of a BLF light bar. I don’t know a lot about the market though. I wonder if making a “light bar host” would be a viable option. Develop it so that people can finish it with standard light parts, e.g. c8 reflectors, carclo triple set ups, 20mm mcpcbs, etc. People can select their own optic/reflectors and led set up and then purchase those separately. That would help keep the price down. I think a really nice host with excellent heat sinking and maybe a few driver options would cover the parts that are hard to find or make. Not sure how feasible or desirable this is though.
Good idea.
Amp draw shouldnt be a problem- it would only be about 18 amps @ 12 volts. Even less @ 13.5.
A person would have to start with pretty small wire so as to not supply too many amps untill you figure out how many amps it will pull. Would suck to burn up 4 $35 emitters.
