Keeppower 14430 950mAh P1443C2 (Black) 2020
Official specifications:
Voltage: 3.70V
Rated capacity: 850mAh
Minimum Capacity: 800mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
Standard charge current: 500mA
Maximum constant discharge current: 2A
Protected LiIon 14430 batteries from Keeppower, these batteries are about 5mm shorter than AA batteries, but with the same diameter and the higher LiIon voltage.
The two batteries tracks nicely, they are rated for 2A and can handle it.
Conclusion
This looks like good batteries, but they are not for high current and there size is a bit uncommon.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
