Can anyone tell me if a Fenix ARB-L18-3500 battery (69mm length) fits in an Xtar VC2?
I have VC2S and measure max lenght of possible battery is around 69.2mm. For VC2 I donβt know. Maybe it is possible but that will be very tight fit.
Hi there, XTAR VC2 can charge 21700 batteries (70mm length), and it can also support your battery asked.
Hi,
may I ask if your Xtar 18650, 3500mAh Li-ion, 3,7V, 10 A battery (https://www.topbaterie.cz/akumulator-xtar-18650-3500mah-li-ion-3-7v-vc-ochr-obvodu-p16217/) can be used in Fenix HM65R headlamp instead of their Fenix ARB-L18 3500mAh Li-Ion battery (https://www.kronium.cz/dobijeci-baterie-fenix-18650-3500-mah-li-ion/prod_1458.html?) Are these two compatible?
Thank you very much for your answer.
