[77outdoor] High CRI + RED 660nm dual led headlamp D25LR
I am definitely interested in a redhead.
Interested, if this project is still alive.
Also 14500 headlamp when it’s up :slight_smile:
Interested
Interested
Soooo… can we have an update on this project? Is it still happening? When might we able to buy it? Thanks :innocent:
Interested ... In for at least a couple ...
Interested
Dang it, let’s make this happen
i’ll be interested too. i’ll take 2.
please do not use rgb leds, i build few lights with them, i used xml leds, the focus is always off, dies are off center, not to mention d25 reflectors are pretty picky, i had 2 with l2, aka fake xml leds, and the beam was horrible, it had a hole in the middle at any distance, when i replaced them with xpg3 the beam became very smooth ,with no rings or holes, sst20 will work just right with them. and besides who needs green and blue light anyway in a headlamp
I’m interested in this as well.
Very interested. I hope you can make this happen. High CRI throw led and a red flood would be ideal for a lot of hunters and outdoors people. I know it won’t be a great thrower given the reflector, but if close to 150-200m that would be ideal to me. Also, I propose the red xp-g3 that was recently released be used for the red led. It’s above 620nm but less than 660, so it’s a more red than orange in theory but still has more visible light to the human eye than the 660nm leds if I understand that correctly.
Thank you.
Now that Chinese new year is over and everything, can we get an update on this project :slight_smile: ?
Not sure I want to commit yet but definitely interested!
Yes, I am back but have been super busy. I will keep going and check if when factory can start the project
Any news :slight_smile: ? I need a new headlamp and if it could also have red light that would be great :slight_smile:
Interested. I also need a T shaped headlamp with decent red output (not the 5 lumens found on most compact headlamps).
Interested in two (2).
interested in this too
How is the D25WR? Will it be ready for hunting season :slight_smile:
interested
