prbly would be easier to get a cheap one with a good heatsink, rip out crappy leds\drivers\optics, and build everything on that heatsink from scratch, but it wont be easy, it is nothing like building a flashlight, those things are exposed to elements, vibrations, temp fluctuations, much more than flashlights. there is a good reason why we almost never seen one,
I have already looked into trying to use an existing lighr bar quite a bit. The problem with the way they are made, is they have the led on the same board as the driver, and no room to have driver separate from the led board. So you’re forced to make something completely custom instead of using something cheap and off the shelf. Maybe I’ll build a prototype to try out a few ideas. Ive got the metal work down, but I’m not well versed in electronics.
I like the idea of using optics if possible, simply for the reason of not having the spill bouncing off of trees, fence posts, or the ground right in front of you and blinding you. But whatever i use, it has to have a wide beam but short from top to bottom. Most of the intensity needs to focus straight forward and gradually get less intense the further from the center you get.
That’s why TIR lenses are common among better lightbars.
Elliptical (“striped”) TIRs do exactly that.
Traditional reflectors are not a good idea if you are trying to reduce stray light. Larger TIR optics that are optimized to whatever type LED (eg 3535 vs 7070 vs COB) would be what you want.
Also consider a remote driver. This could solve a lot of packaging issues IMO, especially if its a multi-mode driver with in cab control. Only have LEDs and optics in the housing and plug into a regulated harness…
As for a B-as-in-budget ‘BLF lightbar’, I think the way it has to start is from people first modding what’s out there, developing drivers, figuring out optic/emitter combinations, etc. Then after two or three years maybe an open/crowd sourced design could be drafted and mass produced. If anyone designs something faster than that and of high quality, it ain’t gonna be cheap.
So, most of the shit light bars have a single thin as shit allu mpcb with all the circuitry and all the leds on it to save on mfg costs.
For this to get off the ground, we need
- a mfg willing to do this.
- a good starting point with the design, the simpler the better. if we can find a semi shit light bar, get a hold of the oem and say, “can we get x many of (base light bar) but with y exact changes” that makes things much easier and more likely to happen.
- proffit
this is basically what happened with the eagle eye x6 GB way back in the day.
Looking at the Vf of a lot of emitters, it appears a good portion like the Samsung 351D, all the XHPs and rainbow Cree’s, White flats, sst/sbt, and FC-40 could work near their sweet-spot direct drive. Old Cree and Nichia don’t match up so well. A simple 12V linear driver could work with very low losses and therefore be able to probably be in a potted die cast aluminum enclosure.
Ide be happy with one of these with 6 sst-20s in a good tint bin, with proper waterproofing.
If we want to get weird, 6x xhp50s with a constant current driver, and a turbo button
This is BLF, we are aiming for the cross over between cost and performance. there is no need to reinvent the wheel, and no reason to just try and take someone elses broken wheel put some bells and whistles on it, and try and sell it to someone else.
im fine with a shitty plastic reflector on a light bar, if its well sealed behind actual glass, and the leds have a nice tint, a good driver, and proper heat sinking to the body.
Isnt the idea to avoid extraneous retooling costs. and get something simple, effective, and enough of us to make an order large enough to make it actually happen in actuality?
This is as far as I’ve gotten. These are Nichia NV4L144ART which I want to run at ~12,1V/1A with TIR 5° lenses.
Mounted on a 5mm pure copper bar? I want to solder copper fins on the backside.
I’ll probably use stainless steel for the cover and polycarbonate for the “glass”. Going to buy screws with flatter heads too.
Bought some AMS1117-ADJ for regulation, haven’t had time to get started on that at all though.
Added: 2700K, CRI80+. Spec lm: 1183 @ 143lm/W (8W)
Can’t find the price tag.
What’s reasonable for us?
I see this jumping off track very quickly. While buddget is fine, theres no point if what is produced is marginally better than whats available for modest cost right now. All of the cheap light bars I’ve bought are waterproof already, with good construction. So just better tint and slightly more throw is not reason enought to call it blf. This bar here has crap reflectors that scatter light terribly.
I think the light that most of us want is best quality/ performance without the inflated price that premium light bar companies charge.
The large offroad lighting companies have huge marketing campaigns and huge overhead/ operating costs. We don’t, its volunteer development- so we can endeavour to put something together rather inexpensively that is still top notch.
Now, if one were able to find some top quality optics to shorhorn in there for a nice tight spot beam without spill, that would be ideal. You just have to make the optics and board fit behind the lens with just the right thickness so that the lens holds everything in place with the proper tension.
Sombody mentioned having a remote driver; that is the only thing that would work here but sounds doable.
Stoopid question, but why a lightbar over spotlights? I’d have thought more distance is better?
Just a thought, but maybe a solution to the cost issue would be buying a “cheap crap” light for $15-20 bucks and modifying it? At least the aluminum shell would be there, and the modder could put in better TIRs, more heatsinking, and a driver etc without having to make the entire thing from scratch with a lathe? Otherwise, I don’t see this being done for a lot less than the higher quality light bars.
I’d say no though it might work. I tried with a free 22”/50cm and the quality ducks ass. Also the reflector height makes it hard to find something that’ll fit.
I could machine the housing and brackets but as others have mentioned it would be just for a few of us on here. We could get in contact with some Chinese partners to see about buying the housing and brackets without the internals if someone would build the boards for it. QC could be done here and loctite all screws on final assembly. It could be a cost effective light bar while keeping cost down.And all important stuff is done in the USA or Europe wherever the boards are built and assembly is done. Could even contract out the boards if needed. Just brainstorming without any actual research.
I guess one of the things people are not asking about as I see everyone asking for throw. What kind of application?
Do we want to see 5 miles down the road or do we want to see 180 degrees in front of us for 100-200 meters? As someone that is not running high speeds off road I am ok with a bit of flood over throw as I rarely hit 30 MPH using a light bar for primary lighting needs when off road.
Again each person is going to be different.
I need tons of throw. Minimum 300k candela, but 500k or more would be even better.
My application is running lonely back roads and 2 track at higher speeds, plus paved roads in the less populated parts of Colorado.
Most everybody that travels alot at night in my neck of the woods has some sort of auxiliary light whether it be a bar or a kc type light, simply to be able to see deer and elk before you hit them. We have massive resident elk herds that hangnout next to the roads because of warmth and feed.
Legalities aside, that is the reality. I personally have mine wired to the high beam switch with another switch to be able to turn it off separate of the high beam switch. I dont use it when other vehicles are on the road, same as my high beams. Most other people around here are respectful about that as well.
I say both. 270 degree for the corners and throw in the middle.
And as we are blf it’s not necessary to be cheap, only to be reasonable. There are many outside who can afford a little more if it’s worth.
For the legal side: a good cover when not in use would be fine…
Nice Fenix lightbar…
But much too complicate.
Yes-No full! basta
