【ツ】Wurkkos TS30 + TS30S Sales Thread - available on wurkkos.com, Amazon & AliExpress
Thank you Wurkkos and Lux-Perpetua for this thread and the discount offer.
I ordered a TS30S from AmazonUS yesterday, received it today and now have answers to the questions from my previous post.
I was pleasantly surprised while using the included Wurkkos battery (~10A max discharge current) that the TS30S easily threw farther than any other light I currently own and it had a reasonably large hotspot along with usable spill. The few extraneous beam rings outside of the spill were very dim, minimal in size and did not distract from the beam quality.
I am looking forward to obtaining a high-discharge battery (capable of >20A discharge current) to determine the throw improvement from that.
My TS30S would not charge using any of my USB-C to USB-C cables with any of my various USB-C chargers. I had to use either a USB-A charging port or a USB-C to USB-A adapter plugged into a USB-C charging port along with a USB-A to USB-C cable.
I cannot recall any other Wurkkos lights that use Anduril (which motivated me to purchase this light) and I hope to see Anduril-2 which includes a "voltage calibration feature" on your future Anduril lights, because the built-in charging for my TS30S terminated when the battery reached 4.16 Volts DC (as read on my various multimeters) while the Anduril battery check voltage query (3 clicks from OFF) only reported 4.0 Volts DC which is 0.16 Volts too low and will cause Anduril's built-in low-voltage protection function to activate earlier than it should.
Thank you again, I will enjoy my first capable thrower. The build quality, performance and aesthetics of the TS30S are more than I expected and the optional "strike bezel" is definitely a conversation piece.
Thanks a lot for your feedback, roostre. :BEER:
Good to see that most people are happy with their TS30/TS30S lights. It's good that TS30S is really living up to its promised specs. Some SBT-90.2 lights seem to underperform due to higher contact/internal resistance in the light's current path. In an early stage of this model I recommended Wurkkos to use brass buttons for springs on the positive terminal and high quality dual springs on the negative terminal. I did not see any peak current measurements yet but I am confident this decision has a positive impact on TS30S's overall performance.
In terms of a high drain battery I'd recommend using the Samsung 30T/40T or Molicel P42A if you are after peak lumens. The best compromise of high current and runtime is Samsung's 50S (Vapcell T50) battery. Unfortunately, it is (and will be) hard to get as Vapcell seems to be an exclusive reseller of this battery and currently they are out of stock.
In terms of the USB-C port: AFAIK, Wurkkos and Sofirn are already working hard on improving their USB-C circuits for better compatibility, i.e. full support of type C-C cables and so called smart chargers with PowerDelivery. However, I do not expect to see anything above 5V 3A (15W) as input in the near future. I would really appreciate seeing higher wattages through higher voltages, e.g. PD 3.0 12V 3A (36W) for Sofirn's LT1 or SP36 for faster charging. I assume Wurkkos will first introduce the new circuits with their next revision of the HD20 headlamp, Sofirn probably with the next major release of the LT1 (incl. reverse charging feature).
In terms of Andúril 2: That is an ongoing subject I am discussing with them. So far, both Wurkkos and Sofirn are a bit reluctant about Andúril 2. That's not necessarily a bad thing as there were introduced some controversial changes with Andúril 2, e.g. direct access to Turbo mode which now takes a different interaction than before. It will also take some time to explain Simple and Advanced UI in detail to achieve a common understanding between manufacturer, flashoholics and standard customers. As far as I remember they were afraid in the very beginning of Andúril that customers might turn away from them because they could feel overstrained by Andúril's complexity. Fortunately, it all worked out more or less with better manuals, FAQs and trained customer support.
I recommended Wurkkos to remove the strike bezel in future batches (hopefully in return of a lower sales price and not only a better sales margin ;-) ). Most customer feedback I have read was very clear about that bezel, in a negative way unfortunately. For the next upgrades I hope Wurkkos and Sofirn can somehow adopt/incorporate their latest driver generation of constant current buck drivers (SP35, SF47T) into powerhouses like TS30S or SP36 Pro. Wouldn't it be great to have fully regulated output in the lower/mid modes like Fireflies E12R or T9R?
I really enjoy everything about my Ts30s. Please don’t put “UI # 2” in it. I am not trying to kick the hornets nest here, but IMO the “upgrades” for it are
not significant and do not outweigh some of the drawbacks, like direct access to Turbo. That one really bothers me. Why would that be changed? there is no good reason for it, as in practical use that is a very common command many people use. And i don’t understand the need for a completely separate simple mode. IMO Anduril “1” was almost perfect and recreating the wheel has been disappointing for me.
I would say this - If two UI’s had to be created for “UI #2”, It would’ve been nicer to see . “Thrower Ui” and “EDC UI” … OR… “Hotrod UI” and “EDC UI”. This way something like no direct to turbo would be understandable, in edc mode. But in hotrod or thrower mode, direct to turbo is very useful. I don’t use it in my edc’s too often, but i almost always do in my bright, powerful lights. Anyway, off my soapbox…
The bezel is cool i just wouldn’t have minded paying maybe $3-5 less and not get it.
The rings are not that bad, and i feel I put too much emphasis on them in my earlier post. I just got a Noctigon K1 (the thrower that can do no wrong lol), and it has rings too. almost all of my throwers do. The TS30s is not unique with this.
Ultra fast charging… i don’t need it, and if i gifted this light to someone they would have a separate charger bc no newbie would be receiving these hotrod lights from me. Also, I only see the benefit of internal charging in a multi cell light because they are usually the hardest to get the battery out of and put back in without damaging the cell wrap.
The current driver, for the sbt90.2 TS30s, is a great fit. I get the idea of a buck / boost / CC driver up to XXamps is very appealing, but i have been reading a LOT of the threads and reviews on the FF lights with it, and runtime tests, and I don’t see the extreme benefit in runtimes and cooling. The buck driver is higher cost and maybe more finicky, but who is running their batteries out to below 3v on the regular? Top notch runtimes and cooling are not part of the equation when I am deciding to buy a light like the Ts30s. they just aren’t. A single cell sbt90.2 thrower that fits in a jacket pocket is never going to be a primary light of mine, and i would argue that for most people it wouldn’t be either. It is a fun light, a check the property light, scan the yard light, but not a light where long runtimes and absolute efficient cooling are necessary. Im not carrying it for more then a half hour and if i dont ill have another 40t on me. or ill put in the 5000mah included battery and sacrifice the couple hundred lumens. I could see maybe the new FF e12r needing those things, but not the TS30s or even TS30. They aren’t in the category of lights i see benefitting from a buck driver. An edc yes, a hot rod, nope. give it all the amps!
I am sorry to go on so long about these points, i just wanted to say that i think these two Wurkkos are excellent lights and also stand for the heart of what BLF is. Greatly built lights, innovative, and impressive (and fun!) at a nice cost. and that the renewed obsession with the buck / regulated driver use as well as “UI #2” has me a little rubbed the wrong way, for a few reasons. Not that they’re bad, and not that they aren’t really awesome, they are just not necessarily perfect for revery situation like some people may say.
I agree to most of your points, Artiet59. Let me put it this way...
"UI # 2" (a.k.a. Andúril 2)
Agreed, the access to turbo is troublesome here - unless ceiling level is hardcoded to a value of 255 in Andúril's souce code or if the user reprograms the ceiling level to 150. If I had the liberty to decide what to implement, I'd try to put two separate UIs into one MCU, in particular the new ATtiny 1616-MNR chip. Flashoholics may use Andúril 1 but for default there would be a simplified, stripped-down UI which could look like this:
I am confident that switching between these UIs could be triggered by multiple methods.
The stainless steel bezel "feels" probably more like $ 7-10 according to some discussions I had with Wurkkos about the material costs. Leaving them out of the equation could put TS30S in a more competitive position, but that's just my personal opinion. It should also be noted that the strike bezel will distort the beam profile significantly. Those blue rings in the spill's outer rim are a typical side effect of ss bezels mounted on flashlights.
A plain buckdriver will not be the best option for a hotrod like an SBT90.2 light, agreed. It probably takes buck + FET to get high lumen ratings. What I am more up to is to convince Wurkkos developing a light based upon TS30S but using a Luminus SFT-70 LED (3000-4.000lm, 6V) with a buck-boost driver. That LED is much cheaper to source, has a smaller die size than SBT90.2 and will hopefully appear in 5000K tint anytime soon. I have a good feeling that Sofirn's engineering will soon come up with such a driver/LED-combination, so more efficient, regulated output is within reach.
I totally share the positive aspects about TS30S as it is right now. I am just starting to think about gen.2 already. ;-)
Artie you are absolutely correct in everything you say. Anduril 2’s “simple UI” was IMO a response to high profile non-enthusiast reviewers who complained that Anduril was “too complex.” Well, maybe semi-enthusiast in the case of EveryDayCommentary, he may have been an enthusiast years ago but someone who does not know what an 18650 battery is—the most common lithium ion battery in the world and one of the most common overall batteries—can’t reasonably be called a modern flashlight enthusiast.
Obviously things like adding multi channel support in Anduril 2 is great but overall the UI is a miss for me, I don’t appreciate the random and unnecessary command re-mapping, and simple UI is a confusing and unnecessary waste of memory.
Lux- P, thank you for this feedback. Sorry I came across maybe a “Ranty”, I just have been noticing things on here that bother me for some reason. A couple questions and comments on your response-
Are you saying your proposal is to have two UI options for the next generation of the lights, meaning anduril 1 or the diagram you have written?
Is that diagram you have written above ^ a proposed UI or an existing UI from somewhere else? I really like it! And, turbo only in stepped mode? (I only use stepped mode Anduril in my throwers, so that works for me!) I would take the diagram written above over the more complicated UI’s. The best thing for me about Anduril outside of its very nice basic commands, is the ease of checking battery level.
I really like the idea of the sft70 6/12v with boost/buck driver. I have seen that emitter on the forum recently, and really prefer its COST, footprint, output, and COLOR. Really seems like the next best thing for enthusiasts who want higher lumens, good throw, good color, And cost savings. I don’t know if the buck driver / boost driver needed for sft 70 would cost as much as the sbt90 led, but From the little reading I have done I don’t think it will. $35 has got to be one of the highest single costs of making any flashlight (outside of some Awsome big reflector lights like gt94 or x65).
I like where you’re thinking is going for V2! I will be in for that.
No worries, Artiet59. I didn't take your words as "ranty". :-) In fact, I'm really open to negative feedback, too. While some things can never be fulfilled to please everyone (tint, for instance), there is always something that can be improved or made different in rev. 2.0 and following, so suggestions and criticism is more than welcome.
Yes, I was saying there could be two UIs in one flashlight, precisely not either/or but both/and. Users could choose between the simplified (proprietary) UI as default or Andúril UI. The UIs can be changed by some hidden command (IDK, maybe click 20 times or...?). I don't know if anyone has ever attempted to do that but I doubt it's impossible. The new AVR-1 chips should have plenty of memory to fit code for multiple UIs.
The diagram above was drafted by me and first presented in another thread here ("Improving Wurkkos UI"). It is not an actually existing UI and it's basically a more simplified "Simple UI" derived from Andúril 2 and a mixture with Wurkkos's FC11 UI. Maybe one could add 7C to cycle AUX light functionalities but that should be all IMHO. Turbo level is actually available in both ramping and stepped modes, same as in Andúril 1 or FC11/TS30 UI. You just ramp up to the maximum or hit 2C to get to peak output. In stepped modes you have the classic standard modes while holding the button pressed (low-mid-high). Battery level here could be indicated by the side switch / AUX LEDs as we know from previous models. The best thing is that gchart and Tom E (both well-known and reputable members and FSM suite coding experts) have said such an UI could be easily derived from Andúril's code and made in FSM software as well.
I agree with you that costs for a sophisticated buck-boost driver should not reach a level similar to the bare SBT90.2 ($ 40-45 per each). The more models they start to equip with such a driver, the lower the material costs should get. Even if Wurkkos were to offer the TS30S with SFT70 and buck-boost driver for the same price as with SBT90.2, they would still catch a lot of interest. For now, both Wurkkos and I have already come to the conclusion that more efficient and better regulated drivers are the future.
These are great things to hear. I love the idea that wurkkos is on board with your thoughts for this new driver in conjunction with a new led such as sft70. I like this driver for sbt90 but see the value of a buck boost for the 6/12v platform and a necessity for it obviously.
The dual UI is a fantastic idea, and I know nothing about chip technology but if they can hold that amount of memory, I would love to see an option like that. Ship it in the wurkkos UI and allow us to change to anduril 1 if we want. That would be amazing, and the possibilities are endless. Theoretically someday lights could have both Anduril options.
Tom E and Gchart have helped me work through some issues with my early stages of trying to mod and both seem like stand up guys. And they also appear to be geniuses in their own right. I bought a light from Gchart and it’s defintely pound for pound the best performance light I have. Lol.
Anyway, enough of that. Lol. Looking forward for things to come from Wurkkos. And loving my ts30s as well at the moment.
Good to hear to you like the TS30S. Did you give in and get the TS30 as well?
Not sure if your comment was specifically directed to me since I do not know of a way to display posts in a "threaded or hybrid" mode to determine who is responding to who, but:
I did not purchase a TS30 since I already have several multi-emitter lights (multiple Sofirn Q8 and SP36, multiple Lumintop FW3A and EDC18) and I prefer lights with Anduril especially the "3 clicks from OFF" battery check function that blinks out the voltage to one decimal place.
I also have four single-emitter deep-reflector dedicated throwers but none of them are much better than the floodier multi-emitter Q8 for long distances, so the TS30S with Anduril interested me the most.
I like comparing things, even identical things since they are never exactly the same. When I find a light I really like, I cannot resist purchasing it multiple times, sometimes with different LED emitters but not always. After a picky comparison, the particular ones I like the most get treated like treasure and I use them carefully to not damage them. The others I use without caring or worrying about and even abuse or give them to other promising potential flashlight addicts as a surprise (if I believe they can safely care for Li-Ion batteries).
I need to purchase another TS30S to directly compare the brightness and throw differences while simultaneously using different batteries in each light to see how much better a high-discharge capacity battery performs. A contradictory discovery I made while doing this exercise with multiple "Lumintop Tool AA 2.0" and multiple "Manker E03H II" lights convinced me that I prefer the brightness levels of some lights while using NiMH instead of Li-Ion batteries. The "Manker E03H II" multiple moonlight modes are exceptional, but only with NiMH.
The pleasures derived from little flashlights keep my mind from dwelling on the larger more depressing issues of life and I thank BudgetLightForum and it members for this affordable experience.
I was looking forward to Anduril-2 mainly for the "voltage calibration feature" since the "3 clicks from OFF" battery voltage check query on my Anduril lights have always had a consistently inaccurate offset throughout their entire voltage range, but with calibration they could be consistently accurate.
I have not used Anduril-2 and did not realize the "2 clicks from ON" behavior had been changed to only go to "Ceiling Level" instead of "Turbo" unless you were already at "Ceiling Level".
"2 clicks from OFF to Ceiling Level" is unchanged and acceptable, but not having "2 clicks to Turbo from ON" at any brightness level is very undesirable in my opinion also. Thanks for making me aware of this.
I am a first year beginner on this forum, but an avid learner (with spare time being an older retired guy) and are now thinking that I may need to learn how to modify and re-flash Anduril-2, even though the thought of it intimidates me from what I have read and tried to understand, especially for lights that do not have readily accessible flash pads, but I'm willing to try and may someday even reflow an LED.
@Artiet59, after re-reading this thread for information about the TS30, I believe the following question from forum member "hodor" was directed to you:
Also @Artiet59, after becoming more interested in throwers and reading the entire Noctigon K1 info / review thread, I was wondering how your new 4000K XHP35 HI Noctigon K1 compares to the throw, hotspot size and spill brightness of the TS30S.
A comparison between the TS30S and Noctigon K1 with both using the 5700K SBT90.2 would be very interesting and I hope that someone can post about that eventually.
I have never ordered a light directly from China, but the K1 interests me enough that I may if it can be delivered to a USPS PO Box since I live in a remote area where there are no deliveries to my physical address.
Thanks! I have not ordered the ts30… yet, but I plan to. The ta30s is really nice. Also, I used permanent marker on the inside of the bezel and eliminated the larger outside ring in the beam. I got the tip from Vinh at SL and it has really made the Ts30s one of my favorites now. Just thought I’d share
Thanks roostre. I am loving my K1 xhp35 4000k. To have a nice tinted thrower that throws that far is awesome. I do jot have the K1 sbt90 to compare it to, but I do have the ts30s obviously and the ft03s. The xhp35 4000k is just different. It’s more like a nicely tinted osram so a thinner beam and less strong spill. Contrary to popular belief these small die emitter have spill, it’s just not as strong.
Now the ts30s throws as far (to my eye) as the K1 xhp35 4000k, maybe a little less. But the ts30s is much more compact which makes it a better all around light for me. I like the K1 and its performance but because of its size I won’t use it that much. I am always carrying my ta30s because it fits in my jacket pocket so well. Their throw is very similar but the ts30s spill is much brighter from the sbt90
Hope this may help.
I haven't done a side-by-side comparison of the Noctigon K1 (SBT90.2) vs the Wurkkos TS30S (SBT90.2), but I've made some beamshots from the same distance here in these videos (the flashlights are in max brightness levels).
For the videos below, the oppposite building is around 150 meters or 400 feet away from the flashlight's position.
1) Wurkkos TS30S (SBT90.2) beamshot
2) Noctigon K1 (SBT90.2) beamshot
3) Astrolux FT03S (SBT90.2) beamshot
Per my testing, the Noctigon K1 (SBT90.2) appears to perform very similar to the Astrolux FT03S (SBT90.2), following beamshot shows TS30S vs FT03S
4) Astrolux FT03S (SBT90.2) [left] vs Wurkkos TS30S (SBT90.2) [right]
in the following video, the distance of the flashlight and the opposite wall is approximately 18 meters or 60 feet
5) comparing the Noctigon K1 (SBT90.2) [left] vs Astrolux FT03S (SBT90.2) [right]
Thanks, those videos were great.
The two separate videos of the Wurkkos TS30S and the Noctigon K1 (SBT90.2) were so similar that I could stop the video at almost identical scenery locations and compare the beams.
I have gained useful knowledge along with details for interesting lights from your helpful posts and videos in this and many other threads. Thanks again.
Can we get a new TS30S code? I ordered a TS30, after thinking it over I think I want to add a TS30S also but Amazon US code is expired.
TS30 code 30% off Amazon UK update :J656Y8IE
Code does not work. It says it’s invalid
Working now thanks
I bought this light TS30S. Will update on what I find and how it compares to some other SBT90.2 lights.
