New 5-digit power supply RD6006P is released 60V 6A
Hello, everyone
today we release a new device RD6006P, you can treat is as a update version of RD6006, it has 5 digit, voltage resolution 1mV, current resolution 0.1mA , lower ripple , more accurate it can be used to fix phone , computer and other devices.
As what we always do, when a new product is released, we will set the lowest price for 5 days, and then we will sell them at normal price
Here is the product link: www.aliexpress.com/item/1005002185722889.html
you can get all the information at the product description page
RD6006P:64.99 USD (normal price 80USD)
RD6006P-W: 68.99 USD (normal price 84USD)
Notice: this price is only for 5 days
We have test the accuracy, efficiency and ripple of RD6006P, you can check it in this link:
www.youtube.com/embed/ZncOU4eSjvk
Compared with RD6006, it improves a lot and you can see the improvement below:
1.Ripple: Output ripple typicalis 20mV VPP (RD6006: 100mV VPP )
Ripple measurement method: noise and ripple are measured at X1 range, AC coupling, 20MHz of bandwidth on your oscilloscope with a 0.1uF parallel capacitor at the output terminals
2.Higher Accuracy: RD6006P is 5-digitdisplay in Voltage/Current/Power(RD6006: 4-digit), and the output voltage and current has lower error.
RD6006P
RD6006
20mV VPP
100mV VPP
Display
5-digit display
4-digit display
Output voltage setting measurement resolution
0.001V
0.01V
Output current setting measurement resolution
0.0001A
0.001A
Output voltage accuracy between setting and measurement
±(0.5‰+4 digits)
±(0.3%+3 digits)
Output current accuracy between setting and measurement
±(1‰+6 digits)
±(0.5%+5 digits)
Usually RD series power supplies are not suitable for phone repair, but if you use RD6006P version, it can be used for repairing phone and other electronic product.
There are other improvements that you can set the display style
And it has PC software control and app control(only for RD6006P-W):
For detail parameter, you can check it below:
Model
RD6006P
RD6006P-W
Input voltage range
7-70.00V
Output voltage range
0-60.000V
Output current range
0-6.0000A
Output power range
0-360.00W
Input voltage measurement resolution
0.01V
0.001V
0.0001A
Battery voltage measurement resolution
0.01V
Input voltage measurement accuracy
±(1%+5 digits)
±(0.5‰+4 digits)
±(1‰+6 digits)
Battery voltage measurement accuracy
±(0.5%+3 digits)
Automatic cut off current value when charging
Set by yourself
20mV VPP Note①
Working temperature range
-10℃~40℃
External sensor Temperature detection range:
-10℃~100℃/0℉~200℉
External sensor Temperature detection accuracy:
±3℃/±6℉
Constant voltage mode response time
2ms(0.1A-5A Load)
Constant voltage mode load regulation
±(0.1%+2 digits)
Constant current mode load regulation
±(0.1%+3 digits)
Capacity measurement range
0-9999.99Ah
Energy measurement range
0-9999.99Wh
Capacity and energy statistical error
±2%
Buck working mode
Voltage drop >10%*VOUT+2V
Cooling fan start condition
Output current >4A or System temperature>45℃
Cooling fan shut down condition when working
Output current <3.9A and System temperature <45℃
Over temperature protection
System temperature >80℃
Screen brightness setting
0-5(6 levels)
Screen
2.4 inch color HD display
Weight(with package)
About 0.62Kg
Product dimension
167*81*65mm
Support USB communication
Yes
Support WiFi communication
No
Yes
compared to RD6006, RD6006P hardware change a lot though the look same from the front panel, so RD6006 cannot just be updated to RD6006P just by uppdating the firmware
https://www.aliexpress.com/item/1005002185722889.html
RD6006P China customer Feedback:
Compared with 6 1/2 digit multimeter, good at accurancy
RD6006P customer feedback
This power supply is very easy to use. There is a separate terminal for charging the battery. It will not be damaged if the battery is charged with wrong polarity. The screen display information is very comprehensive,
RD6006P adopts two-stage buck design, it has the advantage of switching power supply and linear power supply: small size, light weight, high efficiency (full output efficiency>90%), low ripple(output ripple typical 20mV VPP)
RD6006P China customer feedback
The accuracy is absolutely perfect. Fig. 1, 2: 5V voltage measurement, Fig. 3, 4: 10mA current measurement
This power supply has nice appearance, good accuracy, and convenient operation. It is recommended!
RD6006P customer review
good performance and good appearance design(this panel is made by himself)
Compared with RD6012, the product details of RD6006P seem to be more thoughtful. The charging temperature probe also has a specially reserved adapter, so you don’t need to find a hole on the shell to lead it out like the 6012.
I have 2 RD series power supplies, one is RD6018, the other one is RD6006P, it depends on your needs to choose the product which is suitable for you, both power supplies have good performance
This S400 shell is great, about 1.5 mm thick. No bending traces were found in the assembly. There is still room at the top of the 350w switching power supply, and it can be used for battery charging
my first DC power supply, good
Order received. SUPER!!! Thank you very much. Very pleased with the purchase
Excellent for accurancy
for RD6006P, some customers have already reveived the devices and after test, they give us positive feedback. It seems that 5-digit display, higher accurancy and lower ripple is more important for some customers.
Good precision in CV mode, low ripple. Another thing from this seller and it works fine. I recommend!
great seller (thank you)
RD6006P feedback
It came packaged well, in foam plastic, it was not crushed at the post office. Collected for two hours. Who comes to visit.
RD6006PW feedback
The efficiency has slightly decreased, but the ripple level has become low for a switching power supply. I plan to prepare a detailed review of this converter with tests. You can find it on my Youtube channel - MrDemalit.
When you order our products, you can check the option title and picture to see what you can get.
And if you still have questions, you can check the description, there are more information.
Our case has necessary components like screws and cables for internal connection.
