Yes, the 5700k in ea01 looks very similar to my 6500k in a couple other lights. I don’t know if it is the optic effecting the color?
MT01 (SST40) arrived. It was so sharp, unfinished the bezel, that could the paper be cut with it. I had to grind with sandpaper.
Otherwise, I like the beam profile. Outside, it can be very useful for hiking and walking.
Unfortunately, I measured that consume 19x as much electricity on standby as EC01.
MT01/EA01 consumption is 1,68mA Does not change. It seems the microcontroller does not go to sleep.
EC01 and SC31 Pro consumption is just 0,09mA at intervals jumps up to 0,15mA.
Each with low-level button backlit.
What are you measured? Is that average?
I measured mine EA01 (SST40), on standby it consumes 0,09 mA.
Thanks for the reply! Sadly, mine is faulty I tried to factory reset. It wasn’t better.
Yup Freeme, could I have a coupon for this light please. Thanks
Coupon code please.
Sent.
Mine has the center purple dot too. It also has a yellow corona, then further out is bluish. Yea, it sux, and it's a CREE XHP.
I sliced a SST-40 in my EA01 and it came out terrible - big loss of lumens and barely 4% increase in kcd. I was so disappointed, I restored it back with a domed SST-40 5000K from Simon. 87 kcd with a nice big spot is not so bad, plus about 2000 lumens and decent tint, and wayyy better beam than the XHP50.2.
The slice looked pretty good - it could have been the LED, dunno. The wires and phosphor were not touched and it sliced pretty low.
Mine has the center purple dot too. It also has a yellow corona, then further out is bluish. Yea, it sux, and it’s a CREE XHP.
These artifacts are clearly visible in the video [( ͡~ ͜ʖ ͡°) Reviews] Astrolux EA01 3500 Lumens Vs NEXTOOL 4TOOL ED20 2200 Lumens - Best Value 2021 . Maybe XHP not very suitable for this optics …
Dunno if the XHP50.2 is well suited for any optics, maybe a heavy OP. I know it looks about as bad in a SMO reflector.
Xhp50 in my smo reflector Astrolux’s looks pretty good. I have an xhp50 in one of my KR1’s it is looks great because the dome sits right inside the reflector opening. Maybe it’s this optic. I may still dedome the xhp in the ea01. I have had mixed feelings about dedoming sst40 because of the significance in lumen loss
DC Fix maybe? I hate to lose the throw. The xhp 50.2 EA01 driver would kill a SST40 right?
Dc fix will definitely deteriorate the throw, at the least the version of dc fix I have. I have to believe that the drivers are the same for both versions of the light. I’m sure Tom could tell us, but I doubt they used two different drivers while trying to keep the price nice and low…
Yes, the same - XHP50.2 and SST-40. Didn't notice any difference - had both lights open this past weekend. SST-40 does about 9 amps on a good cell. Measured 9.2A on a 40T for the SST-40, 17.8A on a 40T for the XHP50.2.
Wow - thought I recalled the XHP50.2 in a FT03 SMO look'n bad but typical for XHP50.2's. Might be the tint - I use 5700K's.
Thanks for the amperage readings. I have a cheap multimeter on the way so I can start doing those myself.
My ft03 with xhp50 looks good. I mean tint shift, I guess but that reflector in particular suites the led well. That is just a great light/emitter combo. One of my favorites still.
In my KR1 also tint shift, but not terrible. KR1 has a slight purple dot believe it or not, but ft03 does not. Both are 6500k. Just wierd.
Come to think of it- my convoy s21b with 5000k xhp50 (I assume it’s 6v) has very bad tint shift, purple outside and green to yellow going in. Nice beam pattern but dc fix does wonders in that light. And that even has a OP reflector, but without dc fix it’s pretty bad.
I think what you said is actually the case, as the tint / color drops in xhp50 the beam color and appearance deteriorates.
You really need a clamp meter to measure amps, specially the high amps these lights do nowadays. I've had a UNI-T, think the UT210E model, the one commonly used here on BLF and had a group buy on way back. With the meter I use a 16 or 14 AWG wire to ground the batt- to the battery tube of the light with tailcap removed. If the tailcap springs are not ideal (no bypass), you'll get a bit higher reading then when the tailcap is screwed on. Another reason to add bypasses - always do better than dual springs as well.
Maybe a different optic to better blend the colors? Tonight I’m trying the DC Fix thing 2 ways. One with only the center covered and one completely covered . The center only doesn’t look to change things much concerning the hot spot but that is inside testing only. Any idea what TIR will fit?
Edit:
DC Fix leaving 1/8 inch ring around the perimeter uncovered seems a good compromise of blending without hurting throw much. Can still see a slight purple tint to the hot spot on a white wall but no green. Total coverage killed the throw too much but did produce a nice smooth beam outside.
Tom E, not sure if you're not receiving notifications, but I sent you multiple messages in the past 3 weeks about my calibration light, can you please reply?
Oops, yes - replied.
I posted about this stuff before with the Mateminco MT01, but same in the Astrolux EA01
Plumbers putty - dunno what for, I removed it all:
Hidden messages? Not sure it's a good idea but certainly out of sight for most:
All cleaned up, contact surfaces sanded smooth, MX-4 applied:
Got a little bump in output, didn't expect much: 17.8 amps on a 40T, 4810 (was 4540) lumens at start, 4381 at 15 secs (30 secs had thermal reg kick in), and 67.1 (was 65.2) kcd.
This is with the stock XHP50.2 3V 5700K, and used a bypass on the tailcap spring before and after.
