compared to RD6006, RD6006P hardware change a lot though the look same from the front panel, so RD6006 cannot just be updated to RD6006P just by uppdating the firmware
RD6006P China customer Feedback:
Compared with 6 1/2 digit multimeter, good at accurancy
https://www.aliexpress.com/item/1005002185722889.html
RD6006P customer feedback
This power supply is very easy to use. There is a separate terminal for charging the battery. It will not be damaged if the battery is charged with wrong polarity. The screen display information is very comprehensive,
RD6006P adopts two-stage buck design, it has the advantage of switching power supply and linear power supply: small size, light weight, high efficiency (full output efficiency>90%), low ripple(output ripple typical 20mV VPP)
RD6006P China customer feedback
The accuracy is absolutely perfect. Fig. 1, 2: 5V voltage measurement, Fig. 3, 4: 10mA current measurement
This power supply has nice appearance, good accuracy, and convenient operation. It is recommended!
RD6006P customer review
good performance and good appearance design(this panel is made by himself)
Compared with RD6012, the product details of RD6006P seem to be more thoughtful. The charging temperature probe also has a specially reserved adapter, so you don’t need to find a hole on the shell to lead it out like the 6012.
I have 2 RD series power supplies, one is RD6018, the other one is RD6006P, it depends on your needs to choose the product which is suitable for you, both power supplies have good performance
This S400 shell is great, about 1.5 mm thick. No bending traces were found in the assembly. There is still room at the top of the 350w switching power supply, and it can be used for battery charging
my first DC power supply, good
Order received. SUPER!!! Thank you very much. Very pleased with the purchase
Excellent for accurancy
for RD6006P, some customers have already reveived the devices and after test, they give us positive feedback. It seems that 5-digit display, higher accurancy and lower ripple is more important for some customers.
Good precision in CV mode, low ripple. Another thing from this seller and it works fine. I recommend!
great seller (thank you)
RD6006P feedback
It came packaged well, in foam plastic, it was not crushed at the post office. Collected for two hours. Who comes to visit.
RD6006PW feedback
The efficiency has slightly decreased, but the ripple level has become low for a switching power supply. I plan to prepare a detailed review of this converter with tests. You can find it on my Youtube channel - MrDemalit.
When you order our products, you can check the option title and picture to see what you can get.
And if you still have questions, you can check the description, there are more information.
Our case has necessary components like screws and cables for internal connection.
RD6006PW feedback
A smart device, my dream has come true) I recommend this laboratory!
