thefreeman’s HDR Anduril 2 high efficiency drivers - update : AA/li-ion boost driver
358 posts / 0 new
thefreeman
thefreeman's picture
Last seen: 9 min 42 sec ago
Hello, I’ve been working on this for quite some time, I wanted a boost driver compatible with Anduril and proper moonlight modes but there was none available so I started to learn about electronics and PCB design to make one myself, while browsing boost ICs I stumbled upon the the new TPS61288 which looked really nice for flashlights : small footprint and 15A switch limit, plenty enough for me. I thought of a technique for moonlight too so I got to work. Then Loneoceans showcased his boost driver with basically the same hardware and features so I hesitated to continue working on mine, but I decided to carry on with it as I wasn’t sure he was going to publish a standard sized driver rather than one specific to a flashlight.
Specs :
  • 20-22mm (or larger) with components within 18mm, max component height between 2 and 7mm depending on the chosen inductor.
  • Single cell input with up to 5A at 6V or 2.5A at 12V outpout.
  • Attiny1616 : 3 wires flashing and calibrated temp sensor
  • E-switch with Anduril
  • High resolution dimming : at least 1:65000, something like a 0.05 lumens moonlight when configured for max power.
  • Reverse polarity protection
  • RGB AUX LEDs
I tried to pay attention a lot to physical compatibility as to make it as universal as possible, not without some headaches, especially with the large spring pad (10mm)  which made routing a bit complicated, going with 4 layers would have probably made it easier. (Also maybe because it’s just second PCB I design)
The largest inductor it can fit is a XAL7070 (7.5x7.2x7mm) for maximum efficiency, in the render it’s a 7030 (7.5x7.2x3), but a smaller one can be used if there is not enough space in the driver cavity or simply if less power is needed, the pads will fit down to XGL/XEL5020 (or other brand parts of the same size) and are away from the center to give more space to the wires if necessary.
The components on the back should be hand solderable (but there are some 0402 passives that I should try to change to 0603), allowing to build it with just a hot plate/frying pan.
To achieve a higher range than the usual 8 or 10bit i.e 1:255 or 1:1023, I use a second current sense resistor allowing to regulate very low currents, I described it in more details here, I haven’t tested this yet but after disassembling a Zebralight I saw they use the same technique, Loneoceans too on the LumeX1 apparently.
So now I need to receive the parts, build it and test it, hopefully it will work laughing
And if you have suggestions I’m all ears.
Edited by: thefreeman on 09/11/2022 - 16:55
thefreeman
Reserved
id30209
id30209's picture
Last seen: 3 hours 30 min ago
Big IN!
Looking good freeman Smile
WTB Titanium 4sevens 2xAA tube
Agro
Agro's picture
Last seen: 1 month 3 days ago
Thanks for doing this. Smile While this may be a bit redundant with what loneoceans did, as you noted it’s not exactly the same and being a more standard footprint carries significant value by itself.
Though I wonder, maybe it would be possible for you two to work together in the future? Smile
Agro
Agro's picture
At the same time I’m thinking…
There used to be a big disconnect between high end lights and BLF ones.
The former used to be highly integrated designs that were hard to modify. Potting was used there frequently, though not universally.
The latter used to be good from the factory but highly moddable. They never employed potting.
Some BLF members used reversible potting f.e. silicone based which compromised potting performance for the ease of modding or repair. Which was still much worse than it would be with unpotted light.
Here, potting could enable using a fraction of a mm higher components.
Alternatively, it could enable reducing the length of the light for a fraction of a mm while improving reliability, as long as the driver uses lower than usual components.
Is potting worth it? IDK. Food for thought.
Barkuti
Barkuti's picture
Last seen: 23 hours 33 min ago
Mmm, with a 16A switch limit you could raise the power output some more. Assuming a conservative 2.8V figure as the lowest input voltage and 85% efficiency… mmm, can't go much above, 5.5A, also presuming conservative ≈7V of Vf. You could change the main sense resistor to a 9mΩ one… Innocent
The dual sense resistor path is a great idea for very low current modes. However, you could overlap both ranges a bit because… does people really needs a 20μA moonlight? Seriously?
Thumbs Up
Sun, 02/28/2021 - 00:05
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
thefreeman
I’m not sure I follow, potting would allow to use taller components ?
Barkuti wrote:
Mmm, with a 16W switch limit you could raise the power output some more. Assuming a conservative 2.8V figure as the lowest input voltage and 85% efficiency… mmm, can’t go much above, 5.5A, also presuming conservative ≈7V of Vf. You could change the main sense resistor to a 9mΩ one… Innocent
Thumbs Up
Yeah not much more than 5.5A, if you want regulation for the whole input voltage range. Here is an example with spice models for 2S2P Nichia 219C (but the Vf is higher than what we usually see I think) and XAL7030-222 :
The peak input current hits 15A (limit is 12/15/17.1A min/typ/max, 16A in the spice model) at 3.05V Vin.
As for the minimum being too low Big Smile , I think the older ZL MKII used to advertise a 0.01lm minimum, so something like 30μA (1S LED) ? Personnaly I thought that was the minimum usable moonlight.
Barkuti
Barkuti's picture
thefreeman wrote:
… Here is an example with spice models for 2S2P Nichia 219C (but the Vf is higher than what we usually see I think) and XAL7030-222 :
LoL with the green curve (output current, Iout), looks like a rollercoaster.
Curves should look more stable with the bigger inductor, doesn't it?
Guess I'm not used to moonlight modes at all. Innocent
Sunnysunsun
Sunnysunsun's picture
I don’t know much about boost drivers and you seem knowledgeable enough to ask this question.
What needs to be changed so that the driver can reliably boost to something like 4.5v CC rather than 6v? This driver is constant current right?
EasyB
Looks good Thumbs Up . Looking forward to your test results once you get it built.
JaredM
JaredM's picture
Do you have a 2D schematic / wiring diagram for this non-EE to try and understand this design? How many added components do you use for the dual sense circuit? I think you’d only need 3. A small fet, sense R, and maybe a pulldown R for the fet.. I could be way off here, but it seems like there’s a lot of extra components here..
Also, this is extremely application dependent, but I’d think using a second half moon shaped PCB (maybe 0.8mm) and connecting it via header pins could be an option to get the rest of the components on the top side by moving the solder pads for the RGB/switch up to the top board. In lights where you have the depth for a large inductor you should also have room for this in my mind
https://fundrazr.com/osturaband
No affiliation, just a fan.
Agro
Agro's picture
Yes, because when the entire driver cavity is filled with the potting compound there’s no risk of components hitting the shelf.
BTW milling small holes in the shelve above the taller components is a trick I’ve seen before…but only in high end lights.
Quadrupel
Quadrupel's picture
Last seen: 7 min 30 sec ago
Thumbs Up But … 32 components , 2 sides and 0402 size ! Just wondering what is and what for U2 and Q2? ;))
Barkuti
Barkuti's picture
I'd say it can stock boost to just 4.5V, that unless the TPS61288 has some limit down there; but I don't see a reason for it not to.
If you can provide more information, do so. Leds are far from being constant voltage devices. A typical “6V” led, usually a blue pumped phosphor converted white led with 2 in series groups of dies, actually requires way more than 6V when driven hard, and barely 5V when driven very low. So, where did you got those “4.5V”?
Wait for thefreeman's input.
thefreeman
Curves should look more stable with the bigger inductor, doesn’t it?
Guess I’m not used to moonlight modes at all. Innocent
Ripple is due to the limited output capacitance of the 2 1206 capacitor, but the zigzagging is (I think) reduced loop stability with the XAL7030-222 spice model (as opposed to the ideal 2.2uH inductor+14mΩ DCR with which it was very stable), also the limited output capacitance, I’ll have to see how it is in reality, I’ll need to buy myself a scope for that and adjust compensation, maybe it would be good if I can fit another output capacitor.
Min output of TPS61288 is 4.5V, so it depends if you mean 4.5V or a little below.
Yes it is constant current.
I’ll post the schematic, just need to clean up a bit and annotate.
A mosfet, sense resistor, and a gate resistor, not sure the later is really needed, ZL don’t use any.
The mosfet is on the high current path and part of the current sense resistance, so it needs to have a low RdsON to not influence the sense resistance too much as they don’t have a precise resistance, a smaller size mosfet would have too much resistance for that.
Yeah but like you said it becomes more specific to a flashlight.
Ah alright.
U2 is the LDO, Q2 is used to switch between the two sense resistors, you’ll see the same on the LumeX1 driver, as well as ZL driver (2 mosfets because 3 sense resistors)
All components are necessary here (exept Q2 gate resistor maybe). As for 0402 I never used them but I doubt it’s that bad.
For less passives, the to be released MP3437 will be good for lower power boost driver since it’s more integrated (no external compensation network)
Quadrupel
Quadrupel's picture
OK, and what lowest mode possible with minimum component and usual resolution?
thefreeman
If no moonlight mode is needed then we can remove R6,R7 and Q2 (bridging Q2 pads), with 10 bit the minimum outpout would be ~5mA with 5A max, the lowest level might flicker a bit similarly to lume1 or the new Fireflies lights, 3rd (1:340) and up should be free of flicker.
Barkuti
Barkuti's picture
thefreeman wrote:
… with 10 bit the minimum outpout would be ~5mA with 5A max, the lowest level might flicker a bit similarly to lume1 or the new Fireflies lights, 3rd (1:340) and up should be free of flicker.
10 bit (210) sense resolution… lowest level might flicker? Is this because of switching noise?
Honestly, the dual sense resistor solution grabs my attention with respect to reducing sense voltage, not so much because of moonlight. Guess I'm fed up finding drivers like this buck driver with 4 - 5A output and 47.619mΩ sense (above 0.2V sense Facepalm in a “3V” driver?) which, in my opinion, is a sloppy botch.
Still, in my honest opinion I find no reason for not wanting polished boost-buck engines, so full regulation independently of input voltage / battery SoC and power output.
And then, I remember the thread Modifying a weird AC led driver from a gooseneck lamp which I opened long ago, featuring a very simple AC led driver which I found curious and smart:
There current delivery depends on input frequency times capacity. I wonder how this concept could be of help in low voltage drivers… probably not much. They really saved on such a driver, and guess it was not meant to break, by the way.
thefreeman
I suppose noise yes, the op-amp is precise enough, very low offset voltage (max10uV) and input curent bias so I think it’s not that, I don’t know what is the sense voltage in the new FF lights, it’s 60mV I believe in the lume1, 50mV in the KR4 driver (linear, but also have unreliable 1st and 2nd levels). So it would seem that 50~100 uV sense voltage is too low. I mentioned 1:65000 in the specs, that is 8bit on each ranges, with a 40mV sense voltage (5A, 8mΩ) that means 150uV at 1/255 and which should be high enough to avoid any problems. It would generate 200mW of wasted power at the max current which is quite low already, but it could be lowered further with a lower sense resistance, at the cost of resolution.
Caleb
Caleb's picture
Last seen: 2 days 6 hours ago
I love this forum.
Following
Mike C
Mike C's picture
Last seen: 1 week 2 days ago
Nice work. I’ve also designed a driver around the TPS61288, it’s a bit different than yours though, it’s 17mm dual sided and intended to work with both E-switch and clicky switch. Parts are ordered and on the way.
One thing I don’t quite understand is why you are using a LDO? Are you using PWM though a RC filter? I’m not sure why you would do that with the ATtiny1616, is it to maintain Anduril compatibility?
thefreeman
It’s to give the MCU a fixed voltage supply so that the output PWM signal is also a fixed voltage (2.8V in this case), which is then filtered and divided down to Vsense.
But I have barely any knowledge of the MCU/firmware part, do you mean that with 1 series Attiny you can output a fixed voltage PWM no matter the supply voltage ? Or use the DAC maybe ?
Mike C
Mike C's picture
Yes, the DAC. It’s what I use. I have not been using the 1616 specifically, I have used the 3217, but by looking at the datasheet it works the same way. I have just received an order with 1616s for my 61288 driver so I’ll find out soon enough anyway.
When using 2.5 voltage reference the DAC output is capped at 2.5V if MCU voltage is higher. Another benefit with the DAC is that it has better resolution than 10 bit PWM on the lower modes when using the 0.55 voltage reference. If requires some coding for smooth transmission between these voltage references if you want smooth ramping all the way through, but for me it’s worth the work to avoid LDO and RC filter.
thefreeman
That’s very interesting, indeed that means several parts fewer, unfortunaltely I really have trouble with coding in general, maybe one day I’ll have to learn, but for now I made it compatible with Anduril which output a PWM signal.
Are you getting reliable low levels when Vsense gets very low ? (See the discussion just above)
Mike C
Mike C's picture
I do get a little instability on the lowest modes with 0.55 vref on my previous boost driver with MP3429. However, I did take your suggestion in the LumeX1 thread and added a second sense resistor and mosfet, so thanks for that. Space is a little tight on my 17mm driver after fitting the mosfet so I have been forced to “downgrade” to 1616 for this new driver, I couldn’t make it fit with the 3217.
thefreeman
Cool, glad it could help. But now with 2 sense resistors, one vref for the 8bit DAC should be sufficient ?
Are you going to use anduril with it (in e-switch mode) ?
Mike C
Mike C's picture
Yeah, it’s a good suggestion, and looks like Loneoeceans method is the same. I could actually fit a tiny charge pump I’ve used before to keep mosfet resistance low, so I squeezed it in for the mosfet gate.
I only use my own firmware, for me it’s the fun part of the hobby. My firmware is E-switch, clicky switch and dual switch compatible as it is so no need for different firmware files for different lights.
thefreeman
I hesitated to use a charge pump gate driver like mic5019 to get a very low resistance, but I thougt that there was already enough parts, so I chose a mosfet that have arround 2.5mΩ at 2.8V, a bit expensive but not more than mosfet+driver. Ah but I forgot, the LDO is also to keep the mosfet resistance constant, without it the charge pump should virtually eliminate that resistance variation.
Mike C
Mike C's picture
Ok, without the charge pump the LDO is probably a good idea. It’s the MIC5019 I have used, it works well but if you use it, make sure to put a pull down resistor on the enable pin. At first I didn’t, and the datasheet states that it can be unpredictable if the pin is floating. The datasheet was right.
Which mosfet did you choose? When do you expect your parts? I’ll follow this project with interest.
thefreeman
BSZ010NE2LS5
Good to know for the pulldown resistor.
Not sure, depends how much time it takes for shipping from Oshpark, also I haven’t made my order at Digikey yet, it’s the only place where I see the TPS61288 in stock, and it’ll have to go through customs unfortunately.
Mike C
Mike C's picture
Ok, it’s the same mosfet that was in your schematics… I have ordered the same.
What’s the issue with Digikey? I ordered mine from Digikey.se, I got free shipping when buying over 50€ and UPS take care of all the customs. I only have to pay added 25% tax, but I have to do that when buying from Mouser too. The only difference is that Mouser add the 25% to the invoice that I pay. Digikey doesn’t add that, I get a separate tax bill from UPS with only taxes, no additional costs, end cost is the same. They don’t offer this service with Digikey.fr?
