Ordered 2. Was originally after one but with the price of shipping was a case of buy one for AUD$29, buy two for AUD$50.
Interested, for 2 pieces.
Sent.
Ordered 2.
Forgot to post earlier 3 ordered !
Thank you for your support! Cheers!
Any more request?
Looks like mine shipped out today!
Shipped on last Friday.
some impressions would be nice to hear when u get yours
Received mine today when I got home from work. Nice little light! I got the white with 4000k. UI is ok, button takes quite a firm press to operate, which is good for a keychain light. Currently on charge. The AUX lights are nice and bright. Not quite sure what the RGB lights could be used for, a locating beacon?
Really happy with my purchase too! You can regard RGB mode as location function or Party mode. Haha.
can i get code pls ? these look fun
Sent.
I received mine yesterday, and i must say…
I’m a bit disappointed.
They are chunky,the head diameter is 17mm vs 15mm on the jetbeam mini one & se
the finish is kind of rough and the uv on the clear version comes through the body way worse than the jetbeam mini one se.
on the blue star version the uv comes trough even worse, but i expected that
one of them to the head ring is not down all the way, there is a gap.
For the price i payed, it’s an oke light,
wil keep using it for a while to se how long the GITD lasts, but the tiki and mini one se wil stay in use more over this model.
Most people wouldn't mind the extra 2mm wider, in exchange of a bigger battery and more metal for cooling down the SST20.
JETBeam AUX LEDs beams are really intense, and its flashing frequency pattern gave me bad headaches within a few seconds.
Main XP-G3 like is fine but you don't get 4000K or ramping UI.
I preferred diffused beam. Beam is more uniform and shell lid up like a mini glow stick.
K2 (white/clear shell) UV is weaker than SE without doubt. If buyers are buying this like for its UV feature, you might be disappointed for this one.
K2 (white/clear shell) GITD is 10x brighter than JETBeam mini-one SE and more lasting.
I don't see any usual gap for mine.
I tryed to take a decent picture, but I’m at work right now so i don’t have my dslr with macro
On the blue star version it’s nice and flush, but on the clear one i have a gap.
So maybe i just got unlucky with this one.
Can you find out if this is glued with a pres fit or if it is threaded and glued?
In the last case i can tri to tighten it a bit more
thanks for code, both 2 one in each tint.
