I have a Resqme tool clipped to the sun visor of my car. The window breaker is spring loaded so itās much smaller and lighter than the hammer style tools.
Iāve never needed to use the tool or had an opportunity to test it, but my brother has tested it and said it worked well. Heās a firefighter and has also had a fair bit of rural road rescue experience so I trust his opinion on seatbelt cutters and glass breakers.
Itās better to have something that might be out of reach in some situations than to not have anything at all.
I think the Resqme tool is small, light, and inexpensive enough to have a couple in different locations if youāre really concerned about being able to reach it.
we use a spring-loaded center punch for windshields.
here is an example : Amazon.com
of course, some sort of knife is always āonā usā¦.in a pocket, on a lanyard, etc.
here is a long story about a vehicle escape:
late at night, our dentist was driving back from a conference, came around a curve, and drove into a flooded part of the road.
he was in his Mercedes and it began to float, then started sinking. all electronics quit (shorted out?). his automatic seatbelt
would not retract. he happened to have dental tools with him which cut the belt. the doors would not unlock. the windows
would not roll down. he ended up kicking out the back windshield. it never broke or shattered. it popped out complete.
he got out ok, and his car only sank up to the door handles. now his escape tool is taped (not clipped) to his seatbelt.
According to this article and interesting video, side windows on many newer cars are constructed of laminated glass (like the windshield is) instead of tempered glass (like the side windows used to be) and ordinary impact escape tools are not effective on laminated glass:
The only person I ever knew that had to escape after a rollover crash (which did not break any windows but the doors and windows would not open), said the way they broke out was by bracing their back against the front seat and using both feet to kick and push the windshield out.
Iāve got the Astrolux S43 with the point on the end in my door pocket. Of course, likely just drown as being trapped without a seat belt cutter when I break the window is problematical.
Yeah, you need a light that can double as a brick smaher and glass broker.
You can make your own āglass brokerā by cracking the insulator of a sparkplug, finding a pointy chip, and using resin/epoxy/whatever to attach it to the end of, well, anything. Wooden dowel, switchless tailcap of a light, anything.
Those big doodads, you can attach anywhere with velcro or the better-stuff like whatās used to attach EZPasses and the like. Iād avoid clipping to a sun-visor unless youāre okay with hitting a bump in the road and having the visor drop down in front of your face.
Strange, but true. There are many YouTube videos demonstrating that.
We bought a couple of those glass breaker and seatbelt cutters many years ago and put them in the center consoles. I donāt have one in my car, but the others do. My wife just feels safer with one in her car.
I've gone back and forth on this kind of stuff. I was in a horrific car wreck that totaled the vehicle. The door couldn't be opened and I had to escape through a window. It was the middle of nowhere too, so no immediate rescue. My memory of that event is a blur but I'm pretty sure the seat belt release worked just fine.
One thing to consider is that I use a seat belt extension. It is basically just another female-side attachment with release button that plugs into the existing one. The point is that it brings the connection up a few inches so I'm not having to reach around my own body and dig down to release it. (I got turned on to this years ago when I was recovering from a back injury and my wife was pregnant. It was a godsend for both of us.) It makes life easier in general and may be helpful in this kind of situation.
In theory, I could probably just use a regular knife to cut an exposed off-body piece of strap. Thinking about all the possible scenarios, I just don't know how often it matters from a self-help perspective. I totally get the idea of a safety cutter for rescue workers who are reaching into a wreck and might have limited access to trapped persons. I suppose it's possible that one of us could come across a situation like that, be the only person available, and not be able to use our regular EDC blades.
As far as glass breakers, I've kicked out car windows. I've smashed them with other objects. The "glass breaker" is usually just a hard point for concentrating impact. That could certainly make the job easier. Where I question it is that I usually see them on small EDC objects that require you to have your hand very close to the point of breakage. Does anyone here have a lot of experience using that kind of tool to break glass?
Some cops I know carry spring-loaded punches Just In Case. Canāt get into a car, just push it against the glass and it āpopsā and busts the glass. Carrying one of those on your person if youāre a civvie might look funny, though.
Didnāt one of the Zanflares (F1?) have a glass-broker on it? One flashlight had a nib that was supposta be able to do thatā¦
Anyhoo, taking a regular item and embedding a porcelain splinter would be way less conspicuous.
Ummm, ever try to crack that kind of porcelain? Good luck with thatā¦
I saw someone with just a chip from a plug hold it in thumb/forefinger, and just lightly tap-tap-tap on a car window enough to āweakenā(??) it, then quietly put his back to the window and leaned. It gave way and shattered almost silently. Oh, you could hear the glass āgravelā falling and clacking together all over the seat and into the footwell, but the actual window shattering was almost noiseless.
One too many taps, or just tap too hard, and it could shatter right then and there. Doesnāt take much.
The one in the car has the glass breaker bit loaded as the primary bitā¦ its in the āspare bitā section on the Skeletool that doesnāt live in the car. You lose the āsmallerā flathead bit out of the original 4 bits on the tool, which seems like an acceptable tradeoff to me.
The escape tool in the OP is currently on lightning deal at Amazonā¦ tempting to get a couple of those in case as well.
Me and Mrs. Jeff have the Resqme thingies. Have had for years now.
Went and checked the windows.
My 2014 Toyota has tempered glass side windows. My wifeās 2019 Ford has laminated glass side windows.
Guess we need to rethink her escape options. Luckily out here, to drown in a car out here, you need to head for a swimming poolā¦
Still would like to have something to get out if a door refuses and we want out.
All the Best,
Jeff
No Officer, this is is not a sawed-off shotgun. Itās an escape tool I had to get because normal methods wonāt open the new laminated windows in my carā¦.
And the President of the United States told me to: āJust buy a Shotgunā.
All the Best,
Jeff
