It's weird for sure. Found the same stuff in the EA01, just received.
I did some LEGOing with the MF01 Mini in the OP pics. Another single LED TIR light is the FireFlies E01 - I got one, but don't think I ever opened it.
Is it possible they use it as a sort of firewall to protect the electronics from the heat?
My EA01 50.2 came today. First impression was how small it is. Calibrated the temperature and can’t wait for dark tonight to give it a whirl. Having reset capability is reassuring in case I’m ever somewhere without the directions and I need light. One question, what does a factory reset do to the temperature calibration?
Pretty sure it gets reset - think al the settings are reset.
You mean the electronics of the switch PCB? Maybe? I originally thought it was to keep all the wires from the switch from interfering with the optics, but I'm guessing.
So if it comes uncalibrated it will reset to uncalibrated?
Took mine for a walk tonight and am very pleased with the beam and CCT. The default max temp is supposed to be set to 45 but it felt hotter to me. Had to set it to 35 to keep it comfortable at top ramp. Thinking about dropping top ramp setting but first I want to see how the lower thermal max setting works out. I don’t know what is better, drop max temp or drop max ramp lumens to keep it at a sustainable level? Fun to play with. As I said before, very small. Not a lot of mass to dissipate the heat. Good throw without a discernable hot stop which is what I was after. Chewed through a 5500 mah 26650 pretty fast though.
What kind of tool do you use for the ring around the switch? I don’t want to scratch it. Thanks in advance!
The ring is SS so hard to scratch. But I do use a pair of needlenose that are curved on the outside so usually fit the ring notches pretty well (can't find a pic of mine). For the BLF Q8's I actually made a tool out of plexiglass material - it's a perfect fit and no scratching.
Go slow and careful though - think the SS ones can still scratch if mis-handled.
Do you think other optics are available that may give a nicer beam?
My MT01 is an SST-40 so the beam looks great. For the XHP50.2, I dunno. Last night I compared the beams of just about all my XHP50.2 3V lights and they are all ugly to me, maybe some slightly worse than others.
I always order a 5700K tint when available - not sure of all of them. Maybe it's the more neutral tint? Saw some think the FT03 XHP50.2 looks good, but I never saw a good beam from a XHP50.2 3V light. It's not a deal breaker for me, but it's certainly noticeable indoors or outdoors. I was planning on modding a lot more lights with the XHP50.2 3V but mostly been preferring the SST-40 5000K because of the beam.
Outside, my SD05 OP 50.2 6000k is OK. Thought maybe behind a 45 or 60 degree TIR, the 01 50.2 wouldn’t be bad. Hard to find large ones.
Shoot, forgot bout the SD05 - I got one too. That center dot thing happens in reflectors too, but sometimes purple, sometimes yellow - weird. Again, wonder if it's the tint or maybe focusing... Haven't played around with it enough.
Nice! Think someone at work printed me a 3D tool as well, but with so many different lights and switch sizes, 3D printing is not a good option for me unless it's super easy and fast.
Tom, did you you see vietnamreviews EA01 disassemble video? The forward side of the driver was also covered with clay. Maybe for potting? I was wondering if it could be the source of the current leakage?
After viewing the inside and the previous clips about Astrolux EA01 you see how Astrolux EA01 is [Astrolux EA01 3500 Lumens Teardown - Best Value 2021]
Tested my driver cleaned up, still leakage. In hospital now, covid finally got me. Should be out tomorrow, not sure how long recovery will take
Oh boy. Hope it’s mild.
It's a weird one, close coworker tested positive, couple days ahead of me, 102 temps for 9 days, lungs issues now, 3 PCR tests all negative. CT scan showed covid damage in lungs. So many classic symptoms but no positive test. Also pneumonia. Oxygen stayed above 90 though, and did not lose taste.
Covid lookalike or weird undetected strain?
Lyme ? Try an antibiotic. Can’t hurt.
Hope your hanging in there Tom, and definitely dose an antibiotic. I think with some of this Covid stuff, they can do some good. Especially for the lung infection. take care and get well soon man!
Was given antibiotics and steroids, nausea and temp cleared.
