freeme - Please send coupon code to my PM - thanks!
As long as the WP2 does not underperform like the RRT M1X…Please send a coupon code! Ready to buy…Thank you!
Shared. [quote=tamadedan] As long as the WP2 does not underperform like the RRT M1X...Please send a coupon code! Ready to buy...Thank you! [/quote]
The WP2 had a slight edge over the RRT M1X. But is beaten by a large margin by the W30, W4, M1X Wp-Rx, especially after the drop-down @ 3minutes. After 3 minutes it's not really impressive anymore.
Good to know @ChibiM. I wonder how much of that is because of the wider beam pattern. What I am more interested in than outright performance is the rotary UI: If it is as satisfying as the magnetic ring on the Polarion PH50, then I will be satisfied to some degree. The ability to move from low to strobe (with the L61 diffuser) may make this a nice residential walking light (strobe while crossing the street). Order placed.
If not completely satisfied after some time, perhaps I may send it to Vinh to turn it into a WP2vn
That's true, I did reviews on almost all popular LEP flashlights currently available (13 in total).
Links are in the LEP discussion thread here: https://budgetlightforum.com/t/-/63612 so we don't get too far off topic here.
48hrs FLASH SALE
FREE MEOTE FM1 4* LH35 1D/SST20/XPL-HI 4980LM
with purchase of ASTROLUX® WP2+WP1 Combo / ASTROLUX® WP2 / ASTROLUX® WP1
freeme Is the GB code for the WP2 still available?
Price is listed on original post now.
WP3 is coming.
Are you referring to the pre-flash on activation?
Yes
Specs ? projected specs ? based on the naming it would be a larger LEP but how much larger ?
EA02 lookalike with more "tactical" feel?
Why not try to bypass the tailcap to isolate the problem?
Yes
Thx. Tried it now and problem stays. So maybe rotary ring or electric board?
Driver is held down by screws, there is nothing much you can do except tightening joints or battery swap. Did it happen during first power up or it developed much later?
I noticed it first day of use. Speaking with seller what now. Hope it will be resloved. Sorry for off topic in your thread.
