The first code I got for the SD01 did not work. I sent another PM and the second code worked.
Code for s11c please! Thanks!
Please PM me for the code.
Please PM me! I can’t PM you directly.
Please PM me for the code, I got a limitation.
Please PM me for the code, I can’t PM you directly.
The PM function back to normal right now.
Thanks for your suggestion.
Interested in a code for the S11C please. Thank you!
Code for s11c please, I’d love 3 if possible.
Could I please have a code for the S11C, Thanks!
S11C is a great deal for $8. Works great. Nice neutral beam tint. Direct to moonlight or High from off. Hidden strobe. Smooth zooming function. USB-C charging. Strong magnetic flat base. Cell and cable included. Might be best $8 I ever spent on a light.
All functions tested and work fine.
Keep it away from water - check! $8.
Only complaint no spare o-rings and needed to grease threads. Not a big issue.
Thanks for the deal Sofirn.
Yeh, think I got a half-dozen S11Cs between me and the gf. Great for gifting to The Muggle, too.
Cheap but definitely not a “toy”. Similar to the LEDLenser type zoom? It’s not the usual aspheric, but more like a sliding TIR lens.
And the SD01 is a nice light, too. No end-cap on the battery tube, but one solid milled piece, so no leakage or O-rings to mess with there, either. Nice!
Codes for both, please
Thanks
I would like to get a discount code for the SD01.
Thank you.
I’d like the code for the S11C please.
Thank you,
Could I please have the code for the SD01 light? Thank you!
Hi I would like the code for the SC11.
Thanks,
Scott
