FastTech New Arrivals & Promotion
Thank you very much Ventsi!
Wish all of you a great weekend. :slight_smile:
May be I’m wrong but I guess not many customers would like to deal with that. At least that’s the reason why my last order from FT was made almost an year ago. I can order from other sites without all that hassle.
Lumintop? Sounds like a Klarus story.
KLARUS XT21C LED Flashlight
Luminus SST70 LED / 6-mode / 3200LM / pure white / 1*21700 / USB-C rechargeable / lanyard / IPX8 waterproof
Working voltage: 2.8-4.2V
Light intensity: 26280cd
Head diameter: 35mm
Tail diameter: 25.4mm
BORUiT BC15 EDC LED Flashlight
4*Cree XP-G3 LED / 6-mode / 3000LM / pure white / 1*26350 / lanyard / IPX8 waterproof (2m underwater)
Voltage: 3.7-4.2V
Happy St. Patrick’s Day! | UP TO 33% OFF What More Could You Want?
Check here to know more details: https://www.fasttech.com/forums/promotions/t/3126393/happy-st-patrick-s-day-up-to-33-off-what-more
FT has been consistently good from the time I got my things from them, even years ahead in the game compared to GB and BG, and also a much professional complaint dept.
The only thing missing from them is they don’t give discounts as deep as GB and BG.
Hey FastTech, can we have some more info on this light:
https://www.fasttech.com/products/1601/10072546/9736575-smiling-shark-8029-edc-led-flashlight
Like, how do you change the modes and is it just click to ON/OFF or hold to ON/OFF?
Yes, single click the switch to High, Middle , Low modes, click twice to Strobe mode. Thank you.
IMALENT MS03 LED Flashlight
3*Cree XHP70.2 / 6-mode / 13000LM / pure white / 1*21700 / USB-C rechargeable / lanyard / IPX8 waterproof (2m underwater)
Voltage: 3.7-4.2V
Head diameter: 36mm
Tube diameter: 27mm
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature.
Battery level indication
1.5m impact resistant
SMILING SHARK 8029 EDC LED Flashlight
1*LED / 4-mode / 1000LM / pure white / 1*16340 / clip / IPX6 waterproo
Voltage: 3.7-4.2V
Head diameter: 25mm
Tail diameter: 25mm
Fenix E28R EDC LED Flashlight
1*Luminus SST40 LED / 6-mode / 1500LM / cool white / 1*18650/2*CR123A / lanyard / IP68 waterproof (2m underwater)
Head diameter: 26.5mm
Tube diameter: 22.6mm
KLARUS XT11R Tactical LED Flashlight
1*Luminus SST-40 LED / 4-mode / 1300LM / pure white / 1*18650/2*CR123A / clip / lanyard / IPX8 waterproof (2m underwater)
Reflector diameter: 25mm
Head diameter: 33.6mm
Tube diameter: 25.4mm
Working voltage: 2.5-6.4V
Could someone please tell me what “pure white” means?
Wouldn’t it be more honest to quote a colour temperature and/or a CRI?
Pure White means it hasn’t had sex with any other colors .
While they don’t include that info in the product name, they tend to have information like the temperature and brightness in the Light Sources section of the product details.
They’re a little inconsistent with the application of labels like pure white, neutral white, natural white…so I tend to ignore them and go straight to the details.
Correct. 6500K
MATEMINCO CSF-04 USB-C Rechargeable EDC LED Flashlight
1*main LED+3*auxiliary LED / multiple modes / 300LM / pure white(6500K)+blue+red+UV light / smooth ramping / IP65 / glow resinous material
Operation:
  • In shutdown mode
    Single Click to return to the stepless dimming memory mode
    Long press to enter steppless dimming, the default minimum brightness, long press until turbo light
    Double click to enter the strobe mode
    Triple click to enter the auxiliary function light mode. Default UV/white light, single click to enter the red light, single click to enter the blue light, single click to enter the red light flashing, single click to enter the blue light flashing, single click to enter the red and blue alternate flashing
    Four click to enter the voltage detection mode
    Five click to enter the locked mode, five click again to unlock
    Six click to enter RGB breathing light switch mode
    Seven click to restore factory settings
  • In boot mode
    Double click turbo light
    Long press stepless dimming
Operation:
  • In shutdown mode
  • In boot mode
Fenix E02R Mini LED Keychain Flashlight
1*Cree XP-G2 S3 LED / 2-mode / 200LM / pure white (6500K) / Micro-USB rechargeable / IP68 waterproof
Head diameter: 15mm
Tail diameter: 14mm
