I saw the 10440 tube on Facebook or at Neals shop when I did the review. I just assumed (which I shouldn't have done) that the 10440 tube would be available soon after the review. It's 3 months later, and the tube is still not available.
My newly arrived Nano from Banggood also has a copper board. I haven’t tested to see if it has a DTP design. Maybe I’m wrong but I’m not sure it’s that important given the nature of the light.
I’ve asked Lumintop about the change, and also 10440 battery tubes, no reply yet but knowing what I do about Chinese manufacturing, personally I would be confident of getting a copper board as apparently the change was months ago, the sellers I know of sold out and were recently restocked, and the Chinese have a horror of sitting on unsold inventory. Notice I said personally. For example; I canceled my Lumintop order yesterday and got a query from them about the cancelation. The site says there are around 35 copper nanos in stock but turns out you are actually preordering and he lights will be in stock around March 10th.
BTW I found the Lumintop site difficult to use, but not as bad as Aliexpress. Also if searching for Lumintop, clicking on the Lumintoponline instead of lumintoplighting site got me to a official looking site that wasn’t current and wouldn’t allow me to log in without reregistering. Strange.
I’m curious why a aluminum board would apparently cause the led to be overdriven. The difference in conductivity?
It might be the other way around. I used lumintoplighting@foxmail.com and got a reply about my order, lumintoponline might be bogus, I didn’t try that email as the site didn’t work for me and also doesn’t show the Nano copper.
I guess so!
Example: I have a Tool AA, in which I was using a Samsung LH351D Led, on the stock aluminium board + FET Driver + Vapcell H10.
When I first lighted it with the H10 inside, within seconds it turned blue.
I ordered a thicker copper DTP MCPCB from Kaidomain store at AliExpress and used a new led (the other was damaged), same driver and cell. Guess what, it didn’t turn blue anymore.
Knowing that the Osram leds are even more sensitive to heat and current, if not put in an adequate PCB, they will blue in harder conditions, specially with FET drivers or high drain cells.
The GT Nano I received from AmazonUS appears to have a copper board. I do not know how to determine if the board has DTP.
But being new to this hobby, I have two questions:
1) I had to pry the board up and off the shelf to see the side to determine if it was copper.
Did I destroy any Thermal Paste that might have been under the board and do I need to re-apply more Thermal Paste (which I do not have any of) or was it OK to just put the board back into the shelf and re-assemble the Reflector, O-ring, Glass Lens and Bezel?
2) The copper board has a white colored surface.
Is there a reason the copper board has a white surface coating and is this coating anything special and is it OK if the white coating has some scratches in it between the led and where the wires are soldered to the board?
It is generally believed that you should replace the paste, but in my personal opinion if there is enough left to cover the underside of the board just pressing the board back onto the shelf will be fine for heat transfer.
The white coating on top of the board (called solder mask) does not do much, in theory exposed copper tracing could electrically short with things, mostly the reflector, but assuming there is a plastic centering thingy that keeps the reflector from touching the board, no shorts are possible and you will be fine.
The clearance between the board and shelf allowed for some sideways movement, but the LED lined up OK with the reflector when I re-assembled everything.
The light works fine, so I am guessing the scratches will not be an issue. I was very careful prying the board and did not cause the scratches. The scratches probably occurred when the wires were soldered to the board. The soldering was not done very well and looks like a cold-soldered-joint so I was extra careful and did not pry the board out any more than necessary to see the copper side since I did not want to break the wires off.
My Nano from Skylumen has a copper board. I have used it pretty extensively with both the TiHi and Nitefox 10440 tubes and absolutely no bluing of the LED.
I was happy too that the Nitefox head works great with Nano Body. A two for one great buy with the Nitefox!
Thanks for taking the risk and posting your results.
Did you use a 10180 Li-ion battery in the GT Nano body with the NiteFox K3 head or did you use a 10180 NiMH battery?
If so, it is very interesting that the higher voltage Li-ion battery did not damage the NiteFox K3 head and now I am wondering if the stock NiteFox would be damaged if I used a 10440 Li-ion battery in it (which may allow a higher current flow than a 10180 Li-ion battery would) and how much brighter it would be compared to using a NiMH AAA battery.
I do not have any 10440 Li-ion batteries yet, but did purchase the two-pack of the NiteFox K3 single-AAA-sized twisty lights from AmazonUS along with my GT Nano.
Yes, 10180 Li-Ion cell with the Nano body. I wasn’t aware they came in NiMH. I haven’t used the Nitefox head with the Nano body a whole lot but so far no problems and boy, the little sucker is bright. I’m sure it’s not advisable for extended period use but I’ve used it for 1 to 2 minute periods with no ill effects so far.
A problem with using Li-Ion cells with lights that aren’t recommended for their use is sometimes you’ll lose some of the functions such as strobe, low mode, etc.
Earlier in this thread, forum member "jon_slider" mentioned some NiMH 1/3 sized AAA batteries that are almost the same size as a 10180 Li-Ion battery and that was the first time I had ever heard of this size and do not know anything else about them:
Just got mine. Very cool. It wont replace my larger 18650 based lights but cool nevertheless. My first impression was from the box size. The box is smaller than a pack of cigarettes.
“I was excited to see you post this extension for the Nano, so I quickly ordered one and it came last night. I popped a good 10440 cell in it and turned it on. All was well till I kicked it into turbo. A few seconds after being in turbo the light went very purple. I pulled the body off and the battery was not being popped up via the spring at the tail of the body. Not sure if that was the cause of the issue or not.
Now, when I put the 10180 battery in the output is lower and the overall light is purple with a small tan spot in the middle. Seems like it may have been overdriving the LED somehow… bummer. At least this happened on a fairly cheap light, I guess.
Just a warning to others, but I’m sure it’s an anomaly of bad luck for me”
When I purchased my Nano from Vinh, there was no mention of a copper board or anything else. When I received it, it definitely had a copper board. Later after visiting his site on CPF, he said he didn’t sell them without a copper board.
There’s been many reports now of the Nano’s LED turning purple when turning on turbo but thankfully I haven’t had any such problem and have used turbo in my example in short bursts without any problems.
Anyway, now I notice that Vinh recommends buying the Nitefox light if you want a 10440 tube. BUT he cautions, use it at your own risk!
It looks like these Nano heads can handle 10440 tubes or not.
