Fireflies NOV-MU 21*Nichia E21A mule 1x21700 Flashlight --in stock
Your test is measuring center lux, not lumens. A 200 lumen throwy beam will register more lux than a 12000 lumen floody beam.
Referring to the E12R vs EDC18, the E12R should be throwier based on shear output and similar beam patterns. It’s likely he’s not entering turbo or maybe using a really bad cell.
That was it, wow what a difference.
Thank you !! :smiley:
Thanks to the group I found the problem, it shipped in simple UI
Feel better much better now. :+1:
Thanks again, as stated in another post. I was going into turbo but the light shipped in simple UI…
all is fine now.
Thanks again….works great now.
Good to hear! Enjoy!
I took measurements and posted here
Yes, amazing output, floods night into day. One thing I’ve noticed though which differs from my
other Anduril lights is that, this one must be fully ramped up to high before it will go into Turbo.
If it is not on the highest ramp, double clicking will only take it to max ramp, then if I double
click it from there, it just returns to the previous lower ramp setting. Not a problem
now that I know this but I wonder why they would have set it up this way? On all of my other
Andruil lights like those mentioned in my original post along with the MF01S, I can jump to turbo
from any ramp level.
It’s a change for anduril 2.
That is not a Fireflies decision. It is how Anduril 2 UI was decided by TK and the BLF community. Though personally I dont like having to ramp to top of ramp inorder to double click to turbo.
I like the ability to access top regulated setting via a shortcut, but it would have been nice to reach full turbo as well from any setting. Example 2x click to top of ramp, or 3x click to Turbo
Triple click to turbo would have been nice. Or at least double click to top of ramp and double click again to turbo.
I think it is possible to change 2 click to turbo in Anduril firmware, but you are correct that Anduril2 UI change a little from Anduril1.
I agree, I would prefer the old system letting you access turbo from the lower settings but, at least I know
now so it’s not a huge problem.
OK thank you… a little annoying but no regrets on the purchase.
:+1:
You can access momentary turbo from any brightness setting by doing a click-click-hold from on.
FireFlies, have you sent my order 3942? I am waiting it since December. You said you’d ship it after the holidays, but I dont see any news.
Or should I make “Negative experience with FireFlies” thread?)
FF don’t check BLF threads. Try to email and PM them.
