Sorry I’m not able to try it tonight. I will do by tomorrow though.
Found the leaky part. Removed a 3 legged IC, maybe a LDO, as part of the charging circuit and on the bench, the standby drain went down from 250 uA to 32 uA. This was on the EA01 that read 640 uA on standby with switch LED's off. It's probably the only cause but won't know for sure until it's fully assembled again, repeating the setup for the 640 uA reading. It was the only resistor outside of the standard LED driver circuitry I could find connected to ground (i.e. Batt -).
Thanks for troubleshooting Tom.
It bugs me enormously, I’m a great fan of USB-C charging within a light so I do not want to disable that. But with the casual way I handle flashlights (and so it should be, one should not have to think when using a flashlight) this light will continue to kill a battery every now and then.
And with 5mA parasitic drain (with or without the switch light on) I got the worst from the lot.
Showing the part removed:
Haven't been able to get a good pic of it with the #'s:
Checked two caps in the driver circuit and one is 40 uF (C1) and other is 5 uF (C2). Our usual FET+1 design originated by DEL is to use a 10 uF primary (C1) of Batt+ to GND after the R5 4.7 ohm resistor, and an optional C2 of 0.1 uF between the V+ and V+ of the MCU. I'll have to re-check this - might be inaccurate to measure caps inline. Also know DEL wasn't too tight on specs for the cap values so these might be ok to use.
This was the light that didn’t charge if I remember correctly. Do you plan to replace the part and how would removal affect a working charge circuit?
Yes - this one didn't work for me. I don't have the know-how to redesign the charging circuitry, so only option for me is to remove/disable it. Would be great if the 3 pin part could simply be replaced with a non-leaky one, but usually it's not that easy.
The three-legged component is an N-FET.
3416
I think it connects the charging circuit to the battery when you’re feeding the usb-c from the outside.
I’ll try to put resistance between Gate and Source in case it stays open and that’s what’s causing the problem.
Thanks for researching this! So the "Gate" is the pin marked "G"? Think the "D" pin was connected to GRND and another pin connected to Batt+ -- would that be the place to add a resistor? If so, what value do you think I should try?
Ok, was looking at that resistor, yes 47 ohm. Problem with this piece is I don't think the charging was working. On my other light, the MT01 (same driver), I know the charging works and the leak is even bigger. I've been inspecting for shorts, bad solder, etc. - haven't found anything definite. The other pin seems to go through that big diode - is that supposed to be? The thru-holes there got me confused though. The USB processor chip (I think??) is on the other side of the driver. It's a square package, 16 pins, 4pins each side.
This pic is from the MT01 - exactly the same as the EA01, but the MT01 is a lot cleaner. Been cleaning the EA01 driver up with isop alcohol:
The 16-legged IC is the controller of the charging circuit.
TP5100
Unfortunately, I don’t really understand why it’s built this way.
The Gate resistance is connected to the positive of the battery, not the usb. It’s close, and I mistook it.
I thought it was strange, but something I'm not seeing/understanding.
I think the 3414 FET is the reverse polarity protection of the SS52 diode which would short the battery otherwise. When inserting a reverse battery.
The charging circuit itself could be the leak that you turned off by removing the FET or just the diode. I don’t know.
So component failure or design flaw ?
I do not know, we should compare one with one of which has no problem. Mine consumption decreased from 2mA to 0.6mA after soldering and cleaning (isopropyl alcohol). I’m trying to figure out the reason for the high power consumption, but the parts are very small, and the circuits are hard to trace.
Well, thank you and Tom for trying.
Hi My friend, could you please send me a code for sst40 one pls?
Oh, that's interesting, but still 0.6 mA is too high. I think there's a design failure in there some where but can't be sure yet.
Hi, newbee here.
I saw on Mateminco aliexpress store 21700 batteries shouldn’t be use for MT01(EA01)
Will it really gonna damage the flashlight? (does not make sense to me)
Any simple explanation since I don’t know much about these things.
Thank you so much!
(ps. I’m planning to use samsung 40T, also seems like mateminco doesn’t have XHP50.2 5700K on any their flashlight. I wonder if 6500K would be a bad choice)
“Don’t recommend 21700 battery because it may damage the flashlight!”
My guess is that some 21700 batteries can release more power to the flashlight and burn out the LED (notably SST40).
I’ve actually had a (somewhat early batch) Fireflies E01 (single SST40) wherein I placed a fully-charged Liitokala Lii-40 4000mAh 21700 (which is not even that high-drain battery), clicked to Turbo mode, and the flashlight blinked once and then does not work anymore. I believe the SST40 got burned out (the LED doesn’t seem burnt out, but then I think SST40 LED may not show burn marks in this case).
I did get another E01 (SST40) much later which worked properly with the Lii-40A 21700 battery on Turbo mode (although I didn’t try to use Turbo for long periods of time).
My guess is a 21700 battery may release more power and “might” burn out the SST40 LED. XHP50.2 can take much more current though so I’m not sure if this also applies (a 30T or 40T probably can provide too much current to the XHP50.2 if current consumption is not being limited by the driver?)
I’m no expert here so these are just my guesses…
