I have compared my LT1 to my Fenix CL30R and the fenix on turbo mode is quite alot more lumens than the LT1 sadly
If the LT1 has those extra bridges soldered can it’s higher output stay sustained without overheating/having to step down?
Thanks, so will it get damaged running higher? I usually run it hours straight in up to 30degrees C static environment, Sounds like I best leave it stock.
I have a question. The LT1 doesn’t seem to be very efficient in its power usage; is that mainly because of extra circuitry to handle the tint mixing, or what?
Say the LT1 on high produces in the neighborhood of 600 lumens, for a bit less than 6 hours. The Q8 with the same 4 18650s can produce 750 lumens for something like 17 hours. The LT1 sucks juice a lot faster.
That’s not to take away from the advantages of a purpose-built lantern for specific uses, especially one that can vary its color temp output. I’m just thinking that when a person is camping, thrifty energy use from whatever cells one has packed can become a factor, too.
The LT1 is far from an efficiency champion, but the Q8 performance you suggest is not accurate. It would be nearly 250 lumens per Watt. No flashlight on the market comes close to that.
Since I’ve actually been curious about a comparison with the CL30R for a while, I went ahead and used this discussion as an excuse to make one, and I added the Q8 as well, since you brought it up.
In general, the LT1 compromises on efficiency for the sake of having high CRI (especially so at the warm end of the tint ramp). Based on Lumeniac’s photos, I suspect the CL30R is also high CRI. The LT1 and CL30R both compromise on efficiency for the sake of having well-diffused output. I assume the CL30R achieves its better overall efficiency by utilizing a buck driver (if a Lume1 or similar topology driver was ever offered as a mod for the LT1, I would be all over it!).
All of them are similar in size and weight, but of course, different shapes, and the CL30R holds one less battery. The Lumeniac review linked below has really good photo comparisons of the LT1 to the CL30R, showing by size and relative output under controlled conditions. A few users elsewhere have provided comparisons between the Q8 and LT1
I personally went with the less expensive LT1 with it’s tint ramping and Anduril, and am very happy with it. The Fenix looks like a really good lantern, too, and adds powerbank functionality and Fenix’s product support.
Comparison table (smartphones may need to be landscape orientation for best viewing):
BLF Q8
BLF LT1 CW
BLF LT1 WW
Fenix CL30R
Max Output (lm)
5,000
463
355
650
Efficacy (lm/W)
80
71
55
100
Regulated time on Max
N/A
7 hours
7 hours
2 hours, 40 min
Color Temp
5000K?
5000K
2700K
4000K?
CRI
70?
90
90
80+?
Batteries
4 x 18650
4 x 18650
4 x 18650
3 x 18650
Weight @ 48g/cell
592g
597g
597g
556g
Sources:
Q8 Output: Advertised
Q8 Runtime Test: Zeroair review using 3000mAh cells
Q8 Efficacy: Calculated stepwise from Zeroair’s graph in combination with advertised output.
LT1 Output: Maukka Test
LT1 Efficacy: Calculated from Maukka’s based on 5 x 0.35A driver and 3.7V average battery voltage
LT1 and CL30R Runtimes: Lumeniac’s Review using 2600mAh cells
CL30R Output: Manufacturer specified (Not tested. See Lumeniac’s photos for comparison)
CL30R Efficacy: Calculated stepwise from Lumeniac’s graph and advertised output.
I got the Q8 numbers from a post by CivilGearReviews, which cited alleged mfr test runtime results. Note the “Group 8” data line in the chart. CivilGearReviews thread
Not saying that I’ve done anything to confirm accuracy of those numbers, though.
I’m not comparing max output to max output, but rather m/l equivalent lumens of output.
Runtime of the LT1 at high setting has been mentioned by several people, and GreenCampfire did a runtime test and posted a graph showing almost 6 hours before output fell off sharply.
Maybe I missed it, but does anyone know what the button LED turning on halfway through the ramp signifies? Usually it’s the FET channel turning on in other lights, but the LT1 doesn’t have a FET.
