Compared with RD6012, the product details of RD6006P seem to be more thoughtful. The charging temperature probe also has a specially reserved adapter, so you don’t need to find a hole on the shell to lead it out like the 6012.
I have 2 RD series power supplies, one is RD6018, the other one is RD6006P, it depends on your needs to choose the product which is suitable for you, both power supplies have good performance
This S400 shell is great, about 1.5 mm thick. No bending traces were found in the assembly. There is still room at the top of the 350w switching power supply, and it can be used for battery charging
for RD6006P, some customers have already reveived the devices and after test, they give us positive feedback. It seems that 5-digit display, higher accurancy and lower ripple is more important for some customers.
The efficiency has slightly decreased, but the ripple level has become low for a switching power supply. I plan to prepare a detailed review of this converter with tests. You can find it on my Youtube channel - MrDemalit.
Really great kit. I bought RD6006p Set and now have a power supply almost as good as the >$1000 supplies I use at work. All parts supplied along with a link to the assembly process.
Wow! What a great unit. Very simple to install, and perfectly calibrated. Even the battery charging option has proved useful. The wifi option works well with the app, but it would be so much better if it worked with secured wifi networks, not just open ones
