To bad the UIs are normally H-L-Strobe. And to bad that this AAA light is probably similar to the one reviewed here where the driver and the led are in the same platform It would be a nice host otherwise…
When it comes to hunting LEP has so many sensitive parts that I don’t even doubt it would fail under heavy recoil plus non adjustable beam would cover only 200+ hunting situations and most hunting situations are up to 100 meter.
But you noticed right Maxtoch LEP is the cheapest of them all… Not expensive at all IMHO if someone want to play with it.
The short or ‘slim’ L2K is the most attractive of the larger LEPs IMO. Its on my ‘if I win a scratch off ticket’ list. Just wish it worked on 1S liion.
Ordered one yesterday!
Front led + Laser + Side Led
Ramping on front and side led, High CRI on the side led, red laser to be used with my aunt’s cats! Magnetic tailcap, USB-C, Powerbank, only 2000mAh, back clip, and hook to hang!
Anyone try the Alonefire SV370(or SV310 as engraved on the body?) yet? Seems like a good multi-emitter light to mess around with I assume it lights up one LED at a time since it’s has a white/yellow/UV LED.
So I ended up buying this to play around with. Build is what you would expect from a cheap light. Driver is seated on a cheap spring wire to make negative(?) contact with the body. Not too well versed with the technical stuff. I did slightly disassemble it to get photos for BLF. 1 click for on/off. half press to switch between LEDs. Might need to make better contact with the battery since switching LEDs is finicky and flickers when on.
