No pics there (or maybe I can’t see them), but go to the search and type custom titanium and the images will appear there and are related to that thread !
V4+ flashlight UI:
ON/OFF: Click the tail switch to turn on or turn off the flashlight.
Output selection: Tap on the tail switch to go through all output levels and click to select.
Selections switching: Tap on the tail switch 10 times continually and click, the light will be off for few seconds, then it will blink 5 times for 2 rounds, during which you can switch to other output selections via a click on the tail switch.
and the output selections you will switch into depends on which blink you click the tail switch.
1st blink: Medium1-High-Turbo
2nd blink: Eco-Low-Medium2
3rd blink: High-Turbo-Strobe
4th blink: SOS-Breath-Beacon
5th blink: To change between output level with and without memory.
Default setting: without memory.
I was thinking about the user interface, and I would like to point out a few things:
Current setup:
My ideas:
I like the 2nd mode configuration for kids, but 1 3 and 4 are not very well thought out.
1: people miss a low
3: not very interesting for most people, a single mode would be better, or just a simple Low High
4: most people probably don't use flashlights for just blinkies, a single mode would be better, (for 1 normal mode or 1 blinky mode)
currently, High is too close to Turbo in my opinion in terms of output. I will be reviewing it so I will get the exact numbers.
****My suggestions: **
1st blink: Mode group 1: Eco, Low, Medium, Turbo
2nd blink: Mode group 2: Eco, Low, Medium (great for kids)
3rd blink: Mode group 3: Turbo, Medium, Low, Eco (reversed from group 1)
4th blink: ??? single mode??? (could be any normal mode, or even a blinky mode)
5th blink: mode memory toggle on/off
That's probably covering most of the stuff people are interested in.
