And even then, the meter will still have a +–10% deviation unless you spend hunderds of dollars for a professional calibrated meter.
As said, every change will impact the reading, even inserting a larger or smaller light affects the reading.
So the real question is, how accurate you want your readings to be?
Question 2 is how large you want your setup to be?
Question 3 is how much effort you want to spend for your readings?
If the diffusing sheets do their job and you spread them out over the length of the tube, there should not be any need for sanding the insides. This is part of why I hunted for the perfect diffusion material so long to save a ton of work on each sphere.
Even without that extra work I still get flashbacks to the weeks we spent building these spheres way back, learning as we went. Tubes all over the house in various states of completeness. Calibrations seeming to change just because someone else was testing it. Good times lol. Luckily I figured out most of the issues and got them consistent enough for our uses after a LOT of trial and error.
Without a proper sphere the real key was diffusing the light repeatedly, this removed most of the variance from light to light and made things much more consistent.
After that it was getting a proper calibration light to base the calibration off of. My home grown setup was WAY off and I had to send everyone some correction discs to fix it once I got Maukkas lights to do a real calibration.
Wow, thank you for sharing this hard won experience openly with us, and me! I bet it was a nightmare I. A way getting those setup properly in the beginning. This also makes me realize I really need to try and get the calibrated lights from Maukka …
I have always tried to be transparent about what I do and how I did it, at most waiting to release the full details until after I sold out of whatever it was I made.
My philosophy has always been that if someone wants to put the work in to do it themselves, more power to them, they are also the kind of people that would not consider paying for it pre-made from someone like me anyways. And if they did they would not be happy about it. So might as well help them out whenever possible.
I never want to be someone that forces people to buy something from me. I will build or DIY most things before even considering buying it pre-made, it would be wrong for me to not grant others that same choice.
The TA drives being a good example, I naturally could of kept those closed source and only available from me but instead I decided to release them publicly for those that wanted to DIY it and offered some for sale pre-made from me. Making them the most used modded light drivers ever as far as I know even years after I stopping making them.
That said one thing I have learned over the years is that sometimes, it is better to just buy something pre-made and be done with it unless the journey is something I want to experience lol.
Artiet59, there is very much uncertainty in building one yourself. If TA has one you can buy, get it !!
I have spent a lot of time and money building 2 Lumen tubes. A 6” is calibrated with Maukkas lights, and it took months to get some consistant readings. Took it apart countless times adjusting, changing diffusers. When I tried the Big Throwers in it, well bad readings again. The 6” was only good for 2000 lumens or less. So I made an 8” lumen tube for the big throwers and used them to calibrate it with. There are no calibrated lights for 6000 to 30,000 lumens, so its a wide open guess.
I tried to get help with lumen tubes, but not much interest at the time. LUMEN TUBES, pics, accuracy, opinions Please.
EDITED : The reason I built mine is because I enjoy the challenge and there was none available for my big lights. Mine cost considerably more the TA was selling his, and I’m not really interested in lumen accuracy on my EDC.
Getting the tube/lux meter to readout directly in lumens that are close to the actual value of the light really takes some fussing.
On the one I built, a few mm in pipe length throws things off. But that is also part of the calibration process on my tube. Changing one of the tube lengths moved me closer to my desired readings.
When I tried to use the hardware store diffusion stuff, how it was cut relative to the pattern made a difference. How it was oriented inside the tubes made a difference.
How tightly the tube sections fit together made a difference. I used thin spacer rings to adjust the fit for consistency and naturally this changed the reading too.
On my version the insides of the straight sections are lined shiny metal duct tape so very little light is lost. I covered the outside with the stuff initially. But I felt that more or less light was getting absorbed into the tube plastic depending on the throw of the light being measured. So I did the inside treatment.
And yes, just covering the outside of a tube with tape or foil - makes a measurable difference in the readings….
I found no need to scuff up the insides of the curved tube. The light is well defused by the time it gets to the elbow. But I did anyway because I wanted to get more consistent readings when changing the elbow sections. Different elbows had slightly different finishes.
I am still testing, I’ve got versions with the outside of the elbow covered in chrome paint. And another with chrome paint on the inside as well.
The project got put on hold for a while and I’m about to dive back in. I want to experiment with elbow finish.
I also want to add a photo diode at the end of the assemble so I can use the setup to get runtime plots that can be adjusted to the lumen values. I’ll use my USB O-Scope and logging software for this. My cheap lux meter hasn’t got a way to do data logging.
All in all it’s a good way to waste a goodly amount of time. Getting close and using a correction scale is a viable option.
If you are at all OCD, just step away, or keep the meds handy.
Or convince TA to build just one more…
All the Best,
Jeff
Exactly my experience Jeff!
I’d buy one from TA, but i’m frugal. But the time and money ive spent into my setup (tube and sphere) is worth more than TA’s price of the tube
CNCman, I completely missed the thread about your adventures.
I found the larger tubes harder to control, so I stuck to the 4” (actually 3” - had a brain fart and didn’t remember) for sanity and costs sake.
All the Best,
Jeff
Yeah, when I started, I thought “How hard could it be?” Still I’m glad I did it, I’m semi-retired and have always been a tinkerer.
When I get mine to a point to where I’m happy with the end product, I’ll do a DYI build POST.
Build one for someone else?
I don’t think so Tim…
All the Best,
Jeff
FYI, I don’t read BLF much anymore, so I never saw that thread CNC otherwise I would of been happy to help you.
Just a quick glance and I saw where some of your issues came from, those diffusion sheets in the pictures are no good. I tried those and had nothing but issues, 4 or 5 options later I found this local place that had some and it worked WAY better.
When you put the diffusor over the light in a room, you should not be able to see any simblence of a beam coming out of it, just a perfectly smooth wall of light. And even then multiple layers are important due to how the light reflects inside the tube.
For anyone interested, I did manage to find a few more lux meters (they need to be a specific kind of sensor body to fit properly and they are going out of production it seems) and I had someone order a tube awhile back that required me to get more stuff laser cut. So I do have the important parts needed to build a few more tubes if anyone wants one.
They will just take a week or 2 as I will have to order the rest of the parts.
You have helped me on several occasions TA, :+1: Thank You.
I had hoped there would be more input on the tread I started so I could learn more about why I was having so much trouble tuning it. In the end, it is clear to me the variables are not controllable to any satisfactory degree. The smallest thing can affect readings, so sensitive, I now just use them for fun, not accuracy. The work I do revolves around accuracy, that drives my thought process. Lumen tubes for me is a failure. Most of the time Lumens are arrived at by led type, voltage, and current for a ball park value.
I Apologize that my frustration has offended anyone or everyone. :person_facepalming:
CNCman, I don’t think anybody took offense at anything you said. Certainly not me.
Farting around with these things can be frustrating. I have pages (and pages) of notes taken of test builds and the results.
I got pissed off more that once as I made changes and seemed to be getting me further away from something that worked.
Just taking the tube apart and putting it back together yielded different readings.
I got that ironed out using spacer rings to control how tightly the parts fit together along with using witness marks to make sure the tubes went back together in the same orientation.
The diffusion stuff I used is so consistent, at least that wasn’t a problem orientation wise. Yet moving it in relation to the tube placement by 2mm made a difference in the reading.
On my setup, I found that room light did indeed make it into the test setup until I covered and/or lined the PVC tubes. So do your testing in a controlled light environment or shield the setup.
As TA said, even the smallest changes makes surprising differences in the readings.
All the Best,
Jeff
Cncman, great info thank you. And I am interested in the build but not so if the experience is lot ha of aggravation, especially since I will not have calibrated lights. That is my biggest deterrent at the moment. I already bought the PVC connections but obviously can return them. That was $50 alone. But if I cannot calibrate it then it’s no good to me. I want it to compare when I change leds and emitter in my lights, which I do often. I hardly will use a lumen tube for a stock light. It’s more about I have put 5 different emitters in my KR1’s and I’m curious how they rank and where they stand . Information that is impossible to find from someone else and is very Interesting to me.
Texas ace- that is a great philosophy. Do you want have any 3.5” calibrated lumen tubes for sale?
Thanks Jeff for sharing your experiences.
For a long time I felt alone working on the tubes. Trial and error and a never give up approach can give someone a heart attack.
In the 8” tube, my Diffusers are rattle can sprayed with Matte White, 4 coats on the top Diffuser, 2 coats on the one 6” below it. They are 2 inside glued in place with no leakage around the edge. Using all the data on the MT09R, it was possible to adjust the tube to that light. An additional Diffuser is required for throwers. Both thrower and flooder lights have a slightly different number for calculations. I’m guessing about +/- 500 lumens at 6000 to 30,000 lumens, best I could do guessing.
The 6” x 4” tube was more difficult than the 8” to tune, worked on it for the better part of a year, off and on. Same problem you stated about getting close to 1.0 then .760, then 1.192. Not to mention light meter additional calculations. I used ‘maukka’ Calibrated Light set on this tube. Give up a while, then back at it. Not sure it was worth the trouble after checking and documenting the few lights I have, LOL.
lol, no worries no offense taken. More felt bad you had to struggle through that alone, it is never fun doing that from scratch.
Yeah, people would ask a lot at first how accturate these tubes would be and kept being surprised when I would say not to treat them as an accurate lumen reading and more use them to compare readings between lights and between others with the same style tube.
All my tubes should be pretty comparable as they were all calibrated to within a ~2-3% of each other. That will grow over time though as things are moved around etc.
I have used this stuff to control brightness in the setup I use for run-times.
The thin white closed cell foam used to package some of our lights or other electronics works also.
The semi-transparent frosted plastic from gallon milk jugs (and the like) can be used as well.
And the best part is they are free. But don’t expect consistency from different sources of the material or even across a sheet of it.
Stuff designed to be used as a diffusion material is better choice if you want to go that route.
The biggest hurdle I had was getting the setup to work with throwers and floodies. Other than getting the readings close to some sane value…
Getting the beam diffused early and lining the tubes to prevent escape prone photons did it for me.
I suspect there are many ways to approach the build. Just have at it - and keep repeating: It’s only a hobby - It’s only a hobby…
All the Best,
Jeff
