Emisar D3AA is available now
I hadn’t considered the different diameter, and it makes sense components would have to be relocated to fit. So at the very least there are separate D4V2 and KR4 versions of the driver, which can be customized in either 5A or 7.5A. What I’d really like to know is whether it’s just something like a resistor change I can play around with later. I can’t find any photos of the business side of this driver.
That is correct, all ordered and received in the last two months, interesting.
One observation which differs from a typical KR4, all three have stable moonlight mode which is set to ramp level 1 by default whereas the KR4 is set at 3.
Only applicable to the aluminium D4V2 at the moment.
yes, i had definitely noticed that! i actually started a small thread about the low modes a few months back, in which TK responded to me. She said it had to do with the kr4 driver having a courser low ramp mode due to the amount of power channels, which at the time i did not understand. Emisar / Anduril - stepped low mode “jump” - #6 by ToyKeeper
Hank - or anyone - do we have any specifications on the UV mules? And are there any special considerations (other than eye safety) to take into account when using the light? Or do or the normal drivers/thermal step down look after the UV led’s as normal?
btw, my sister in law just bought a house in some rocky granite country and we went looking for scorpions with the i5UV olight - wow, LOTS of scorpions!! Most around the 40 - 50mm size (black rock scorpions I think) and they just look like glowing toys under the UV. Our Australian species are generally small and not dangerous to humans although they evidently can give a painful sting.
There should be normal temperature stepdowns with anduril (If he’s even putting anduril in the Uv mules)
UV LEDs need a high voltage so they won’t be driven too hard with direct drive.
You should wear polycarbonate glasses (almost any pair of plastic safety glasses will do, just double check to see that it blocks the Uv)
My normal prescription glasses are blue blockers / transitions - if I point the UV lights at them, very little UV goes through and the lenses will also go dark. I can’t find a transmission spectrum graph for them, but I’m hoping they’re ok for the odd bit of reflection that I might get.
Are the moon levels the same at those ramp levels or how do they compare? (5A CC (LVL3) vs 1+FET (LVL1))
I’m looking for a new house light and the FET+1 is low, but not low enough.
Also, does anyone know if these CC drivers are considered Buck or use some other kind of current regulation?
If I remember correctly the moon and both are similar once you set the KR4 to level one. Kr4 level 3 is high, But easy enough to set to level 1 ramp. I’m pretty sure the regulation is linear Constant current. No buck or boost.
So I don’t have to bother hank- does anyone know if any of the Nichia emitters offered are able to go into the D4SV2? I assume the E 21a’s can’t go in because the driver is not regulated? Maybe Hank has 219’s left? Can 219- go into D4sV2 ?
I also wanted to have Nichia 219C in my D4V2, have contacted Hank and he replied only 219C in 5000K available in a few. I am loking for the 4000K, I have not decided whether I will go with the Nichia 219C 5000K or the SST20 4000K.
I have 219C 4000k in a KR4, you should be aware that the ones Hank got have a donut hole/dark spot in the center of the beam with the standard optic. Not sure if it would be the same in D4Sv2, but I had to swap my KR4 to the frosted optic to fix the problem. I don’t mind that at all for the KR4 but I wouldn’t want to use a floody optic in D4Sv2, kind of defeats the purpose.
Mine (KR4 219C 4000k Carclo 10622) doesn’t have any donut hole. Have you tried to unescrew the bezel to check if the lens is centered?
There is quite a difference between the throwier 10621 and the still throwy (but not as much) 10622.
Mpb- Was your 219c with the donut hole using the 10622 (standard from Hank) or the throwier 10621? I’m just curious. Because I may try and get a 5000k 219c kr4 depending on which one you were using. I don’t mind using 10622 (the Hank “standard”) but I’m not going with frosted. I always prefer 10621, I don’t have any e21a to worry about bc I know they don’t work well with that optic.
Yes, no issue with fitment. I have noticed this issue with several other 219C lights I have, and I know of at least one other person who got a D4v2 w/219C 4000k and had the same darker spot. It is not apparent all the time, maybe wholly unnoticed if you are less picky than me.
10622, had to go to 10623 to fix the issue.
Alright, great to know. Thanks for the info mpb!
E21A 2000K is my favorite emitter. I have a copper KR4 with it and also one of my 9.3’s on CH1. I’d love it if that was available on all Hank’s lights, such as the D18
we need a 1800K E21A :disguised_face:
Yep I’d buy that. I loved the 2000K so much I replaced all the bulbs in my house with 2000K ones
But, but, no more blues ?
