You got a good one. Today I cleaned the side of the driver that faces the battery with alcohol and compressed air and the drain dropped from 1.2 mA to .8 mA . Still not good. Maybe cleaning the other side will reduce it more?
Thank you so much taking your time and replying @d_t_a I really appreciate. Now it make sense to me.
I will get the XHP50.2 version so hopefully it shouldn’t be a problem with 21700 batteries.
I was going to get samsung 40T but in these days I was checking some batteries and found out new Vapcell rewrap 21700 T50 (samsung 50S)
Seems like T50 has a very similar performance like 40T but in a long run it is actually even better. And for the begging of usage the battery, start volt is little lower than 40T so it might help not to burn out the led maybe…
Mine is EA01 XHP50.2 version and got 0.27mA/0.30mA on low and high led switch on during standby.
I would suggest to capture your readings in video for claim later.
Dismantling of EA01 head will void warranty.
Ok, Just update us. I hope the next batch of EA01 will fix the issue. I’m just wondering why EA01 didn’t have anduril 2 pre installed.
From what I understand, there may be a more serious issue — Mateminco (the manufacturer for Astrolux EA01) doesn’t seem to have enlisted ToyKeeper’s assistance for use with the EA01, so it’s unclear which device target of Anduril is used on the EA01 light. (supposedly, although Anduril works similarly, the brightness ramping and some other more special functions may need to be optimized for a certain flashlight build/model; it will likely work if using a different device target build of Anduril, but brightness ramping and other heat dissipation/thermal control may be less than optimal).
Now Anduril 2 is still fairly new, even though it’s out for some time now, I think it’s not widespread enough (even Anduril 1 can be challenging to use for people not familiar with advanced UI), which will complicate usage operation issues. There are some youtube videos on how to use Anduril 1, but much less for Anduril 2)…
Can I get a code for the SST 40 please. When should I order to get the new batch that hopefully does not have some of the issues reported?
Any chance of having a red body?
My ramping and thermal control work ok after calibrating the temp and settling on a max temp that feels comfortable in my hand.
Can we get also Mateminco quad xhp50 version from Ali code?
Can I get the code for this? thank you
Sorry, only Astrolux deals here.
Thank you Freeme for the coupon, order placed!
which 26650 is recomended for the xhp50 quad?
Can I please get a code.
Thank you
Sure!
If this group buy is still running, can I get the code please?
Sure.
Hello
Can I get the code please?
Thank you!
Sent.
Can I please get a code…
