There seems to be some margin for error with the new drivers (like there was with the old drivers…)
I have 3 of the new 17mm 5A 12 group drivers. One of them acts strange. When programming the light the LED remains on but dim in between programming blinks, and seems to have a much higher lowest mode than the other two.
The other two drivers work as expected, the LED is off between programming blinks and the lowest mode is pretty low.
I ordered a few more to mess around with. I’ve used two of them to make S2+ triples.
Simon Mao, on my flashlight from the last order (convoy s2 + LH351D 5 Amperes), a shunt in the spring from the side of the button fell off, and this happened almost immediately, literally after 2-3 battery replacements. I don’t know how to do soldering and I don’t have a soldering iron!
The question is: what are the consequences?
It is possible that because the internal resistance becomes larger, the low-voltage protection will be entered in advance. I have a switch with a copper spring, which can be sent to you for replacement.
Well, that’s a shame. I have some button top 1000mah Vapcells I was hoping to use with the T2 I just ordered. Might need to look into what is preventing the fit.
On another note, I’m looking forward to my M21C-U XHP70.2 and another simple S2+ with a Dogfart and the new FET driver from the same order.
I wish we had figures for the new XHP35 HI offering in the M21C though, I would have maybe bought another if there were candela ratings available.
So would it be correct to say that it appears this is a driver issue/inconsistency rather than the LED type the driver is used on?
I've had a few different Convoy lights that use this 12-mode (Biscotti clone, not the original Biscotti) driver, and also noted that for some lights, when doing voltage check:
- on some flashlights, the main LED stays on at a dim mode, while it "blinks (brighter)" out the voltage count
- on some flashlights, the main LED is off, while blinking the voltage count
(for comparison, on the original Biscotti, when doing "voltage check" mode, the main light is Off in between the "blinks" for voltage count)
The issue you mentioned might be related to the observation I noticed (main LED is dim, or main LED is Off in between blinks)
The 6V will be more efficient because of the boost driver, both drivers will output ~18W (3V * 6A or 6V * 3A). A normal XHP50.2 will be 6A, if it’s 3V it will say so.
@stephenk You may need to contact Simon about the needs of the light painter community.
I had the driver in a light with a single SST-40 and the light remaining on between blinks was present there too. I didn’t play around with the mode groups containing the lowest mode on that light though.
Then I ended up taking the driver out and putting it in a triple with 3 SST-20s and noticed that the lowest mode is almost the same as the next lowest. Another of the same driver in another triple has a much lower first mode.
I have 5 more of these drivers on the slow boat, when they arrive I’ll swap out the suspect one and see if it’s any different.
Yes, dimensions and body design are the same as the S12. it’s 7.5mm shorter and then head is 1mm smaller than the M21B, I’m not really sure that the difference is large enough to warrant a new design unless the M21B’s crenelated bezel is illegal somewhere. Simon is updating his store so often that it’s hard to keep track.
I will be honest with you Simon, the only reason why I didn’t buy more T2 until now is because of the driver and the impossibility to change the fact that it has memory, and that I cannot configure the amount of modes in it.
The Convoy T2 is a sturdy and robust flashligh, easy to mod, capable of taking a hard beat, what makes it good for many modders and people that want practical “work” lights.
In case you offer it with drivers with more flexible UIs, I am sure it will sell more!! Your led options are also great
