Ok, Just update us. I hope the next batch of EA01 will fix the issue. I’m just wondering why EA01 didn’t have anduril 2 pre installed.
From what I understand, there may be a more serious issue — Mateminco (the manufacturer for Astrolux EA01) doesn’t seem to have enlisted ToyKeeper’s assistance for use with the EA01, so it’s unclear which device target of Anduril is used on the EA01 light. (supposedly, although Anduril works similarly, the brightness ramping and some other more special functions may need to be optimized for a certain flashlight build/model; it will likely work if using a different device target build of Anduril, but brightness ramping and other heat dissipation/thermal control may be less than optimal).
Now Anduril 2 is still fairly new, even though it’s out for some time now, I think it’s not widespread enough (even Anduril 1 can be challenging to use for people not familiar with advanced UI), which will complicate usage operation issues. There are some youtube videos on how to use Anduril 1, but much less for Anduril 2)…
Can I get a code for the SST 40 please. When should I order to get the new batch that hopefully does not have some of the issues reported?
Any chance of having a red body?
My ramping and thermal control work ok after calibrating the temp and settling on a max temp that feels comfortable in my hand.
Can we get also Mateminco quad xhp50 version from Ali code?
Can I get the code for this? thank you
Sorry, only Astrolux deals here.
Thank you Freeme for the coupon, order placed!
which 26650 is recomended for the xhp50 quad?
Can I please get a code.
Thank you
Sure!
If this group buy is still running, can I get the code please?
Sure.
Hello
Can I get the code please?
Thank you!
Sent.
Can I please get a code…
Anybody have a clue as to why my EA01 SST40 steps down 10°C above the thermal limit? Set it to room temp with IR thermometer and 20 clicks for 50°C and it steps down at 57-60°C
Mine needed a few attempts at calibration and max set before it operated well. Once I got it there it was alright.
Edit: come to think of it , I had to set mine to only about 10 clicks over 30 degrees to keep it from getting toasty. Driver temp needs to cool for a long time before calibration too.
May I have the code please
Purchased.
