FastTech New Arrivals & Promotion
MATEMINCO CSF-04 USB-C Rechargeable EDC LED Flashlight
1*main LED+3*auxiliary LED / multiple modes / 300LM / pure white(6500K)+blue+red+UV light / smooth ramping / IP65 / glow resinous material
Operation:
  • In shutdown mode
    Single Click to return to the stepless dimming memory mode
    Long press to enter steppless dimming, the default minimum brightness, long press until turbo light
    Double click to enter the strobe mode
    Triple click to enter the auxiliary function light mode. Default UV/white light, single click to enter the red light, single click to enter the blue light, single click to enter the red light flashing, single click to enter the blue light flashing, single click to enter the red and blue alternate flashing
    Four click to enter the voltage detection mode
    Five click to enter the locked mode, five click again to unlock
    Six click to enter RGB breathing light switch mode
    Seven click to restore factory settings
  • In boot mode
    Double click turbo light
    Long press stepless dimming
Fenix E02R Mini LED Keychain Flashlight
1*Cree XP-G2 S3 LED / 2-mode / 200LM / pure white (6500K) / Micro-USB rechargeable / IP68 waterproof
Head diameter: 15mm
Tail diameter: 14mm
In Stock! Let me share these awesome products!
IMALENT MS06 LED Flashlight
6*Cree XHP70 2nd LEDs / 6-mode / 25000LM / pure white / 3*21700 / magnetic rechargeable / lanyard / IPX8 waterproof
Utilizes 6 pieces of XHP70 2nd LEDs. The lifespan up to 50000 hours with maximum output of 25,000lumens.
Powered by three rechargeable 4000mAh 21700 Li-ion batteries
Instant turbo output by double press the power switch button while triple press the power switch button, can get lowest output
High efficiency constant power supply circuits will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum SMD reflector
Aerospace-grade aluminum alloy body.wear-resistant Type II hard-anodized surface treatment
IPX-8 standard waterproof(2 meters submersible)
1.5m impact resistant
Tail stand capability
Head diameter: 56mm
Tube diameter: 51mm
IMALENT RT70 LED Flashlight
1*Cree XHP70.2 / 6-mode / 5500LM / pure white / 4*18650 / lanyard
Utilizes one American XHP70 2nd generation LED.
Exquisite,powerful,long throw.
Maximun output up to 5500lumens.
Built-in intelligent temperture control module can automatically adjust the brightness output.Keep using camfortably.
Built-in magnetic charging.
Reflector diameter: 81mm
Head diameter: 86mm
Tube diameter: 51mm
Working voltage: 3.7-4.2V
Beam range: 903 meters
JetBeam II PRO BeCu EDC LED Flashlight
Cree XP-L HI / 5-mode / 510LM / pure white / 1*16340/CR123A / clip
Head diameter: 23mm
Tube diameter: 22.3mm
Tail diameter: 22.3mm
Beam range: 138 meters
Working voltage: 3-4.2V
Especially designed for camping, cycling, outdoor adventure and self-defense
One side button control design makes it easy to use outdoors
Max intensity 4800cd
With timing mode and lock-out function
Built-in efficient power management circuit
Waterproof in accordance with IPX8 (submersible to 2 meters)
Impact resistance 1.5 meters
Fenix TK35 LED Flashlight
1*Cree XHP35 HI / 7-mode / 1300LM / neutral white / 2*18650 / lanyard / IP68 waterproof
Beam range: 480m
Voltage: 3.7V
Current: 1A
Head diameter: 48mm
Body diameter: 43mm
Hi FT,
Do you have a nice coupon for this?
https://www.fasttech.com/products/0/10021158/9722800-xiaomi-mijia-electric-screwdriver-automatic
SMILING SHARK E64 EDC LED Flashlight
3*LED / 5-mode / 3300LM / pure white / 1*26650 / USB rechargeable / IPX6 waterproof
Head diameter: 40mm
Voltage: 3.7-4.2V
Fenix LR50R Multifunctional Super Bright Searching LED Flashlight
4*Luminus SST70 / 9-mode / 12000LM / cool white / 1*battery pack/1-4*21700 battery / standard tripod socket / intelligent brightness downshifting sensor
Compatible with 1-4 21700 Li-ion battery (not included).
USB Type C charging and discharging interface, supports PD3.0/PD2.0, QC3.0/QC2.0 fast-charging protocols.
Fenix TK16 V2.0 Tactical LED Flashlight
1*Luminus SST70 LED / 6-mode / 3100LM / cool white / 1*21700 / USB-C rechargeable / clip / lanyard / APF / IP68 waterproof
Advanced Pulse-Frequency Transmission System (APF).
Instant activation and strobe with the dual tactical tail switches.
Stainless steel strike bezel inlaid tungsten steel breaking tips.
SMILING SHARK ES03 EDC LED Keychain Flashlight
3*LED / 6-mode / 3000LM / pure white (6500K) / 1*20350 / IPX8 waterproof / multi-stage heat dissipation / crush & drop resistant
Fenix E-LITE Multi-purpose Mini EDC LED Flashlight
1*LED + 2*2835 LED / 7-mode / 150LM / pure white(6500K) & red & blue light / USB-C rechargeable / IP66 waterproof
The Fenix E-LITE is a multipurpose super mini light that can be clipped on a hat, pocket, backpack or bicycle tail, or worn on your waist or chest.
It has two lights: one on top which provides three brightness levels from 5 to 150 lumens for daily lighting needs, and another in front that provides eye-catching red and blue lights for signal transmission in emergency conditions.
Red and blue signal and warning lights.
Electronic lockout function avoids accidental activation.
Fenix PD32 V2.0 All-round Compact LED Flashlight
1*OSRAM KW CSLPM1.TG LED / 4-mode / 1200LM / cool white / 1*18650/2*CR123A / lanyard / IP68 waterproof
Head diameter: 25.4mm
Tail diameter: 23.6mm
Hi tatasal,
We have the 8% off site-wide promotions now! The last day Mar 19! For more information, please refer to: Hey, Have You Tried Gift Certificates? Save 8% on Everything Now!
You also can check our discount at FastTech promotions to know the new information! Thank you.
Wish all of you a wonderful weekend.
In stock! IMALENT LD70 LED Flashlight | UP TO 28% OFF NOW
Use coupon code MAP, get up to 28% off now
$42.92 is an affordable price.
1*Cree XHP70.2 / 6-mode / 4000LM / pure white / 1*18350 / magnetic rechargeable / lanyard / IPX8 waterproof / OLED display
Voltage: 3.7-4.2V
Tube diameter: 25mm
Peak beam intensity: 10350cd
Built-in multi-function OLED display, can display various parameters
And settings
Built-in thermal control module will automatically adjust the brightness output to keep the unit from overheating
Impact resistance (1.5 meters)
WUBEN T70 LED Flashlight
1*Cree XHP70.2 / 6-mode / 4200LM / cool white / 1*26650 / lanyard / IP68 waterproof
Fenix UC30 USB Rechargeable LED Flashlight
Cree XM-L2 U2 / 5-mode / 1000LM / 1*18650/2*CR123A / lanyard / USB cable
Reflector diameter: 21.3mm
Head diameter: 25.5mm
Tube diameter: 25.5mm
Tail diameter: 25.5mm
Lanyard length: 22cm
Beam range: 204 meters
Cree XM-L2 (U2) LED with a lifespan of 50,000 hours
Uses one 18650 (included) 2600mAh rechargeable Li-ion battery or two 3V CR123A Lithium batteries (sold separately)
Micro-USB charging
Digitally regulated output - maintains constant brightness
Low-voltage warning function to remind you to replace the battery
Reverse polarity protection guards against improper battery installation
Over-heat protection to avoid high-temperature of the surface
Anti-roll, slip-resistant body design
Side switch on the head for output selection
Made of durable aircraft-grade aluminum
Premium Type III hard-anodized anti-abrasive finish
Toughened ultra-clear glass lens with anti-reflective coating
Fenix PD40R V2.0 LED Flashlight
1*Luminus SST70 LED / 5-mode / 3000LM / pure white / 1*21700 / USB-C rechargeable / clip / lanyard / mechanical rotary switch
Fenix TK30 White Laser Flashlight
1*Blue Lake WP-Rx / 3-mode / 500LM / pure white (6500K) / 1*21700/1*18650 / lanyard / IP68 waterproof (2m underwater)
Head diameter: 32mm
Tube diameter: 26mm
Laser product danger level classification: Class IIIb/Class 3B
1*21700 rechargeable li-ion battery (included) or 1*18650 li-ion battery (not included) for use with ALF-18 battery holder (not included)
Welcome to FastTech To Get The Exclusive Coupons And Deals For New User!!
Up To 8% Off Site-wide Exclusive Discount For New Users!
Hello, every old friend and new friends,
FastTech always thank you for your continued support and always welcome your every visit.
To express our gratitude, we are offering an exclusive discount for new friends and old friends. Read the below guidelines for this promotion, simply follow the steps to get your exclusive discount.
When does this promotion valid?
From November 5, 08:00 2020(UTC-6)
Until when does the new user discount valid?
FastTech running this promotion to reward customers out of gratitude. We have the right to terminate this promotion based on our operational needs and will notify at least 5~10 working days in advance, please keep an eye on the notice or ticket.
Am I a new user?
A new FastTech account that registered with a new email address, new shipping address, and new phone No., and never make any order on our site will be considered to be a new user, which works on both sites of https://www.fasttech.com/ and https://m.fasttech.com/.
What is the exact discount for a new user and an old user?
*We offer a 5% off site-wide discount for the first order under $20(shipping cost is not included), 8% off site-wide discount for the first order over $20 (shipping cost is not included).
*If a new user is invited by our old users which have a current existing FastTech account, then the new user will get 5% off for the first order under $20 or 8% off for the first order over $20, and at the same time, the old user will get 5% or 8% off for the next order accordingly.
How do I get the discount?
*New users or old users can get the discount only after the new users making the first order.
*Please simply Create a ticket - click here to tell our customer support team that you’re a new user and the registered FT email of the old user if you’re invited. You’ll get a discount after our CS team verifies your account and order.
*If the order is canceled, both the discount for the new or old users will be canceled as well.
Special notices
New user discount is not to be used in conjunction with any other discount, coupon code, promotion, or sale.
FastTech will not be liable to the consequences of the provision of any incorrect information by the customers or technical issues.
OVMS products are not included in this promotional offer.
Above are the rules for new user promotion, don’t hesitate to Create a ticket - click here if you have any problem.
Today’s Hot Sale— Authentic JETBeam RRT-M1X White Laser LED Flashlight
1*WP-T2 LED / 5-mode / 480LM / pure white / 1*18650/1*21700 / lanyard / IPX8 waterproof (2m underwater)
Use the coupon code MAP in the shopping cart page to see our unbeatable price $161.95!
Details:
Reflector diameter: 53mm
Head diameter: 61mm
Tube diameter: 28.3mm
Tail diameter: 28.3mm
Voltage: 3.7-4.2V
1*LED 6-mode 1000LM LED Headlamp
pure white / 1*18650 / Micro-USB rechargeable / IPX6 waterproof / angle adjustable / stepless dimming
FiTORCH PR40 Outdoor Hunting Searching LED Flashlight
1*Cree XPL-HI / 6-mode / 1350LM / pure white / 2*18650/4*CR123A / 1000m beam throw / power bank / IPX8 waterproof (2m underwater)
1*Cree XHP35 HI / 7-mode / 1300LM / neutral white (4700K) / 2*18650 / lanyard / IP68 waterproof
Ordered the ES03 Friday - good price! Used the BLF coupon code. Wish they had 4000K tint though. 6500K may be the least popular here.
Says will ship today -- can you confirm?
