I think it depends heavily on how hard they are driven. I can say my personal experience is that the 4040 pad versions are warmer (looks like ~5500K) and have a higher duv/more green tint than the 3030 versions, of which all of mine have been 6000K+ and very rosy.
You can put the 3030 CSLNM1 on a 3535 pad but it’s a tight enough fit that tolerances means it may not work on some 3535 pads. I would assume though it would either fit all pads on the same board or none at all, i don’t think it would be a case of it fitting only some.
It’s also a bit fiddly to align them to the pad which will slow you down when doing multiple reflows at the same time so i consider anyone who can do many at a time to be a superstar
This HHL532.TG has nearly the same Vf as XP-l hi until 3 amp. So it could be able to simply swap with XP-l hi in some light with buck driver for XP-l, like in Convoy L2, L4 for those who prefer constant output like me. Getting around 800 lumen at 2.8-3amp is nice. Interesting!
Yea, I'm certain the 2nd one is an SFT-40 -- just put one in a BLF GT.
What kind of light is that? Interesting how they got bare wires there, but ok because the holes seem to be connected direct to LED+ and LED-. Plus it's really small with two nice size screws.. Hhmm.
Maglite modding is American national sport… I tried to modd my more than 30 year old Maglite Magcharger and never finished it… I just surrendered To complicated for me.
The YinDing 5050 one in 5000K looks different than what you got there, but when you de-lens it, it does about the same as a Boost HX in lumens, throw, and tint. And all that with a round dye! I got 3 in, installed one in a FT03 - best throw: 581 kcd, ~1600 lumens, at ~7.8 amps. The pain is you have to find that ideal amp level and it's right about there, 7.5 - 7.9 amps or so.
I got 5 more on order from Ali, waiting. Waiting to see how it does in a aspheric - the round dye should be nice.
I think the CSLNM1.TG is still the king of throw in white, but the green one beats it. Isn't the Simon and Mouser ones the same?
Tom beat me to it but the YinDing 5050 is great, especially for pwm or linear FET lights. For me, 7.3-7.5A is peak output at 30s in a light. I’m getting 415kcd in a L21B and 186kcd in a C8+ running a ramping driver, 205kcd direct drive. Tint is perfectly cold white.
The NM1 from Simon is a 6N bin, and Mouser’s are anything from 5N to 8N. In my experience, every Osram from Mouser has been barely hitting the bottom end of the range. NM1 from a long time ago was 286lm @1A (280 min). The HHL532 I tested came in at 356lm at 1A (355 min).
