Hi
We now have a new version of SP35 with ATR, which is different from the previous SP35. Are you interested in testing these two flashlights now and compare the differences between the two. We can send you one from an independent station and send it for free .
So far, I have the first batch SP35 (with a more floody beam pattern), without ATR.
I also have the next batch SP35 (with a more focused beam pattern), also without ATR.
Would love to try out the new SP35, with the ATR…
I think Luminus SFT-40 could be a great emitter for SP35T, especially if it was available in 5000K CCT. It is basically the SST-40 without dome. It probably gets you a bit more peak intensity compared to SST-40. As an alternative (more lumens, less intensity) they could incorporate Luminus SST-70 (6V) into that light but then it takes to use a boost- or buck/boostdriver, like their SD05 diving light.
They could easily offer a 5000K version but I suppose SST40 5000K is very limited right now. They have probably used them up for SC31 Pro and SP36 Pro.
SST40 4000K does not exist. XHP50.2 3V (as alternative) is not available in anything warmer than 5000K and even these are prone to greenish tintshift.
I’m really liking this updated sp35 with ATR working,looking forward for the reviews,seems like a good balance for lumens/battery duration and with thermal control you can give it to uneducated userà.
Meanwhile, I have received my new Sofirn SP35 (with ATR) from AliExpress, purchased a couple of weeks ago. Today, I have run a detailed analysis regarding runtime and temperature. Below you find the results:
Conclusion
In general, Sofirn did a great job with their new model SP35 as you get a decent price/performance ratio for a small budget. The initial version without ATR (sold out) received a lot of good feedback in forums like BLF and TLF and revealed how good a buckdriver with constant current regulation can be. Many customers appreciate the option to manually step down their lights with regard to proper safety precautions.
Now, with their new ("revised") version with ATR I feel a bit displeased. On a positive side I can confirm that ATR works effectively, i.e. the flashlight remains within its thermal limits of about 55°C. Overheating will be prevented successfully. On a negative side I discovered a way too aggressive regulation which cannot provide a steady continuous output. Quite the contrary, the output always fluctuates between 28% and 63% of its initial ANSI output. This is such a big difference that you can even notice it with your bare eyes. For some of you this "sawtooth" profile will remind you of Sofirn's SP33 V3 which has also received some negative feedback for its mediocre thermal regulation.
Sofirn shows how it can be much better with their SF47T model. There you will get a much smoother regulated output with fluctuations of only 8%. I include the runtime chart of SF47T for comparison below. I hope that Sofirn will be able to do some tweaking on SP35's thermal regulation. Apart from that there is not much to not like about this flashlight. If they were to offer more neutralwhite/warmwhite tints as well as a logarithmic ramping curve, it could become one of the most recommended budget flashlights.
My SP35 with ATR should arrive in the next few days to a week. I was very hopeful after seeing your SF47T test… Sofirn finally stepped up their ATR game! But alas, it looks like that better version didn’t make it into the SP35. What a shame.
It might be the same ATR and the SF47T just performs better due to higher mass and thermal buffering/dissipating surface area. Dissapointing for sure. That PID needs tuned for a smaller light
