In Stock! Let me share these awesome products!
IMALENT MS06 LED Flashlight
6*Cree XHP70 2nd LEDs / 6-mode / 25000LM / pure white / 3*21700 / magnetic rechargeable / lanyard / IPX8 waterproof
Utilizes 6 pieces of XHP70 2nd LEDs. The lifespan up to 50000 hours with maximum output of 25,000lumens.
Powered by three rechargeable 4000mAh 21700 Li-ion batteries
Instant turbo output by double press the power switch button while triple press the power switch button, can get lowest output
High efficiency constant power supply circuits will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum SMD reflector
Aerospace-grade aluminum alloy body.wear-resistant Type II hard-anodized surface treatment
IPX-8 standard waterproof(2 meters submersible)
1.5m impact resistant
Tail stand capability
Head diameter: 56mm
Tube diameter: 51mm
IMALENT RT70 LED Flashlight
1*Cree XHP70.2 / 6-mode / 5500LM / pure white / 4*18650 / lanyard
Utilizes one American XHP70 2nd generation LED.
Exquisite,powerful,long throw.
Maximun output up to 5500lumens.
Built-in intelligent temperture control module can automatically adjust the brightness output.Keep using camfortably.
Built-in magnetic charging.
Reflector diameter: 81mm
Head diameter: 86mm
Tube diameter: 51mm
Working voltage: 3.7-4.2V
Beam range: 903 meters
JetBeam II PRO BeCu EDC LED Flashlight
Cree XP-L HI / 5-mode / 510LM / pure white / 1*16340/CR123A / clip
Head diameter: 23mm
Tube diameter: 22.3mm
Tail diameter: 22.3mm
Beam range: 138 meters
Working voltage: 3-4.2V
Especially designed for camping, cycling, outdoor adventure and self-defense
One side button control design makes it easy to use outdoors
Max intensity 4800cd
With timing mode and lock-out function
Built-in efficient power management circuit
Waterproof in accordance with IPX8 (submersible to 2 meters)
Impact resistance 1.5 meters
Fenix TK35 LED Flashlight
1*Cree XHP35 HI / 7-mode / 1300LM / neutral white / 2*18650 / lanyard / IP68 waterproof
Beam range: 480m
Voltage: 3.7V
Current: 1A
Head diameter: 48mm
Body diameter: 43mm
