XHP70 Seanna build
8 posts / 0 new
XZCendence
XHP70 Seanna build
I’m working on a build with an active cooled XHP70 and a ledil seanna, I wanna know how far I can push my XHP70, I’ve got a driver than can do up to 75W at 30V so power and cooling ain’t an issue, I just wanna know how far I can push em’ before I fry the poor thing.
If you're gonna do something, do it in style!
If you're gonna light up a city, do it in 95CRI+!
Hoop
Hoop's picture
Last seen: 21 hours 22 sec ago
The XHP70 (datasheet) can be wired for 6V or 12V. It is rated for 4800mA at 6V and 2400mA at 12V. (~30W) Whether or not the MCPCB is the “direct thermal path” (DTP) type will effect the achievable output. As always, the best thermal path is achieved with a copper DTP MCPCB. If you have an adjustable power supply: use a lux meter or measure the voltage across a photo diode to determine at what current the light output peaks. This will be the absolute max reasonable drive current. You should be using a constant current power supply.
Here is Djozz’s test of an XHP70 on a copper DTP MCPCB: https://budgetlightforum.com/comment/723307#comment-723307
XHP70 is a quad die LED with large gaps between the dies, so it is probably a bad choice for that optic. Also there is the newer XHP70.2 which has much better performance: https://budgetlightforum.com/node/58094
SBT90.2 is the throw/luminance king at this point in time and would be the ideal LED to use.
Enderman
Enderman's picture
Last seen: 1 day 19 hours ago
You can do 10-12A at 6V with appropriate cooling.
XZCendence
My MCPCB is wired for 12v so what could I pull off with that?
XZCendence
I honestly don’t care if the output looks a little ugly as long as I’m getting decent throw and brightness, but that SBT90 does look interesting, what’s the fastest way I can get my hands on one?
Enderman
Enderman's picture
Half of what I said previously, just take a look at the djozz test Smile
Hoop
Hoop's picture
That optic may or may not project an image of the XHP70 die, meaning the beam could be four distinct squares with a dark X in the middle. Usually no one prefers this result. Test it out and let us know how it goes!
Convoy store and intl-outdoor sell the SBT90.2 but they ship from China so it may take a while. The SBT90.2 is a 3V LED and is rated for up to 18 Amps. Your power supply or driver should be chosen accordingly.
XZCendence
Overall the artifact is not too bad at like 5% power, I’m thinking if I crank the power high enough, most of the cross artifact might die out.
Also I peeked at the photometric sheet for my optic and they tested it with both the XHP70 and .2 variant and it said the XHP70.2 had a 5 degree FWHM while the XHP70 has a 4 degree FWHM; maybe because of the slightly larger LES? The cross artifact goes away the closer the LED Dome is to the TIR’s hole so hopefully I can get rid of it with the way I mount it. Anyway I’ll try my luck with the XHP70 but I still want to get my hands on that SBT90.2 some day, it should give me a way tighter beam. I attached an image of the seanna just sitting on the XHP70 at 5% power and it’s not too bad
