Linux or Windows? I’m guessing Linux since you referenced a Home folder. If Linux, are you using the “build-all.sh” script or are you trying to build a single config? When downloading the files, did you maintain all of the folder structures? If not and you just stuck all of the files in the same folder, you’d need to fix the directories for all of the #includes.
Is this the right place to get them? I just click the number, 247 at the moment, and then click download tarball
I guess I have to add those lines in if they’re not they’re already?
On another note, how do you guys bring the spaghetti monster files into a project? Do you just copy paste into the project’s folder? I’m not sure how to open anduril in atmel studio as a project so I can build natively in atmel.
The old guides I could find on blf have lost their images/are out of date
I have been looking for a source code of this 7135 driver: 淘宝网 - 淘!我喜欢
5modes: Low-Medium-High ,Recycling; Double-Click at any mode turn to strobe mode; Three times Click at any mode enters into stepless dimming mode (In the current state, the brightness first decreases and then rises. When it reaches lowest or highest, it will flash once and wait for 1 second to continue to increase or decrease. When it is turned off at any time in the stepless dimming state, the brightness at the time of shutdown can be saved.)
So far I haven’t found the code. Does it even exist in this repository?
I would like to modify it with a few elements of TK’s crescendo firmware. For example, I don’t need strobo, but I would definitely use battery check instead.
I’m not an expert, but I believe Crescendo is designed to be used on attiny 13A, 25, 45 or 85 MCU’s. (on the 13A there are reduced features) Those are all 8 pin devices. The driver pictured appears to have 10 pins. I don’t have any idea what that is but my guess is that it might not be easy to get crescendo to run on that MCU. Chances are there is no open source code for the firmware on that driver, but I am guessing.
Oh,I didn’t spot it had 10 pins. I thought all of the 7135 drivers are attinys. Too bad, I have already ordered a couple of those. Maybe I can live with them, but i will surely miss battcheck.
Hey I’m sorry if this isn’t the right place to ask this. If it isn’t, please direct me to the correct place. But I was wondering if someone could make a custom anduril mod for me?
Yes, I just want a hex file that I can flash to my d4v2. And I just want some of the strobe modes removed, and one strobe mode modified. I will pay for the services btw.
Question…
Is this the place where I can write or suggest modifications about anduril 2 or there is an other thread? (Like “Anduril…2?” By Toykeeper)
I want to help but I desire I am in the right position
Thanks
can someone help me?
I have an older (2 years) anduril hex file from Lexel for his Skilhunt H03 or Utorch C8F driver. I wanted to flash it to a Nangj 105c with Attiny 85 and tripple Channel Setup.
Can someone say me the pinout of this Anduril from Lexel? Is it dual channel or trippel channel? On which pin can I connect which output.
For test I have already disconnected the AMCs of the 105c on pin 6.
I have made several test but the flashlight works very unnormal, sometimes dark, sometimes with wrong order of channels.
Second Question:
Whats an easy driver mod? Using a A17DD (Astrolux S41) Driver, flashing Narsil and put the switch on the place of the OTC?
