Hi FT,
Do you have a nice coupon for this?
https://www.fasttech.com/products/0/10021158/9722800-xiaomi-mijia-electric-screwdriver-automatic
Hi FT,
SMILING SHARK E64 EDC LED Flashlight
3*LED / 5-mode / 3300LM / pure white / 1*26650 / USB rechargeable / IPX6 waterproof
Head diameter: 40mm
Voltage: 3.7-4.2V
Fenix LR50R Multifunctional Super Bright Searching LED Flashlight
4*Luminus SST70 / 9-mode / 12000LM / cool white / 1*battery pack/1-4*21700 battery / standard tripod socket / intelligent brightness downshifting sensor
Compatible with 1-4 21700 Li-ion battery (not included).
USB Type C charging and discharging interface, supports PD3.0/PD2.0, QC3.0/QC2.0 fast-charging protocols.
Fenix TK16 V2.0 Tactical LED Flashlight
1*Luminus SST70 LED / 6-mode / 3100LM / cool white / 1*21700 / USB-C rechargeable / clip / lanyard / APF / IP68 waterproof
Advanced Pulse-Frequency Transmission System (APF).
Instant activation and strobe with the dual tactical tail switches.
Stainless steel strike bezel inlaid tungsten steel breaking tips.
SMILING SHARK ES03 EDC LED Keychain Flashlight
3*LED / 6-mode / 3000LM / pure white (6500K) / 1*20350 / IPX8 waterproof / multi-stage heat dissipation / crush & drop resistant
Fenix E-LITE Multi-purpose Mini EDC LED Flashlight
1*LED + 2*2835 LED / 7-mode / 150LM / pure white(6500K) & red & blue light / USB-C rechargeable / IP66 waterproof
The Fenix E-LITE is a multipurpose super mini light that can be clipped on a hat, pocket, backpack or bicycle tail, or worn on your waist or chest.
It has two lights: one on top which provides three brightness levels from 5 to 150 lumens for daily lighting needs, and another in front that provides eye-catching red and blue lights for signal transmission in emergency conditions.
Red and blue signal and warning lights.
Electronic lockout function avoids accidental activation.
Fenix PD32 V2.0 All-round Compact LED Flashlight
1*OSRAM KW CSLPM1.TG LED / 4-mode / 1200LM / cool white / 1*18650/2*CR123A / lanyard / IP68 waterproof
Head diameter: 25.4mm
Tail diameter: 23.6mm
Hi tatasal,
We have the 8% off site-wide promotions now! The last day Mar 19! For more information, please refer to: Hey, Have You Tried Gift Certificates? Save 8% on Everything Now!
You also can check our discount at FastTech promotions to know the new information! Thank you.
Wish all of you a wonderful weekend.
In stock! IMALENT LD70 LED Flashlight | UP TO 28% OFF NOW
Use coupon code MAP, get up to 28% off now
$42.92 is an affordable price.
1*Cree XHP70.2 / 6-mode / 4000LM / pure white / 1*18350 / magnetic rechargeable / lanyard / IPX8 waterproof / OLED display
Voltage: 3.7-4.2V
Tube diameter: 25mm
Peak beam intensity: 10350cd
Built-in multi-function OLED display, can display various parameters
And settings
Built-in thermal control module will automatically adjust the brightness output to keep the unit from overheating
Impact resistance (1.5 meters)
WUBEN T70 LED Flashlight
1*Cree XHP70.2 / 6-mode / 4200LM / cool white / 1*26650 / lanyard / IP68 waterproof
Fenix UC30 USB Rechargeable LED Flashlight
Cree XM-L2 U2 / 5-mode / 1000LM / 1*18650/2*CR123A / lanyard / USB cable
Reflector diameter: 21.3mm
Head diameter: 25.5mm
Tube diameter: 25.5mm
Tail diameter: 25.5mm
Lanyard length: 22cm
Beam range: 204 meters
Cree XM-L2 (U2) LED with a lifespan of 50,000 hours
Uses one 18650 (included) 2600mAh rechargeable Li-ion battery or two 3V CR123A Lithium batteries (sold separately)
Micro-USB charging
Digitally regulated output - maintains constant brightness
Low-voltage warning function to remind you to replace the battery
Reverse polarity protection guards against improper battery installation
Over-heat protection to avoid high-temperature of the surface
Anti-roll, slip-resistant body design
Side switch on the head for output selection
Made of durable aircraft-grade aluminum
Premium Type III hard-anodized anti-abrasive finish
Toughened ultra-clear glass lens with anti-reflective coating
Fenix PD40R V2.0 LED Flashlight
1*Luminus SST70 LED / 5-mode / 3000LM / pure white / 1*21700 / USB-C rechargeable / clip / lanyard / mechanical rotary switch
Fenix TK30 White Laser Flashlight
1*Blue Lake WP-Rx / 3-mode / 500LM / pure white (6500K) / 1*21700/1*18650 / lanyard / IP68 waterproof (2m underwater)
Head diameter: 32mm
Tube diameter: 26mm
Laser product danger level classification: Class IIIb/Class 3B
1*21700 rechargeable li-ion battery (included) or 1*18650 li-ion battery (not included) for use with ALF-18 battery holder (not included)
Welcome to FastTech To Get The Exclusive Coupons And Deals For New User!!
Up To 8% Off Site-wide Exclusive Discount For New Users!
Hello, every old friend and new friends,
FastTech always thank you for your continued support and always welcome your every visit.
To express our gratitude, we are offering an exclusive discount for new friends and old friends. Read the below guidelines for this promotion, simply follow the steps to get your exclusive discount.
When does this promotion valid?
From November 5, 08:00 2020(UTC-6)
Until when does the new user discount valid?
FastTech running this promotion to reward customers out of gratitude. We have the right to terminate this promotion based on our operational needs and will notify at least 5~10 working days in advance, please keep an eye on the notice or ticket.
Am I a new user?
A new FastTech account that registered with a new email address, new shipping address, and new phone No., and never make any order on our site will be considered to be a new user, which works on both sites of https://www.fasttech.com/ and https://m.fasttech.com/.
What is the exact discount for a new user and an old user?
*We offer a 5% off site-wide discount for the first order under $20(shipping cost is not included), 8% off site-wide discount for the first order over $20 (shipping cost is not included).
*If a new user is invited by our old users which have a current existing FastTech account, then the new user will get 5% off for the first order under $20 or 8% off for the first order over $20, and at the same time, the old user will get 5% or 8% off for the next order accordingly.
How do I get the discount?
*New users or old users can get the discount only after the new users making the first order.
*Please simply Create a ticket - click here to tell our customer support team that you’re a new user and the registered FT email of the old user if you’re invited. You’ll get a discount after our CS team verifies your account and order.
*If the order is canceled, both the discount for the new or old users will be canceled as well.
Special notices
New user discount is not to be used in conjunction with any other discount, coupon code, promotion, or sale.
FastTech will not be liable to the consequences of the provision of any incorrect information by the customers or technical issues.
OVMS products are not included in this promotional offer.
Above are the rules for new user promotion, don’t hesitate to Create a ticket - click here if you have any problem.
Today’s Hot Sale— Authentic JETBeam RRT-M1X White Laser LED Flashlight
1*WP-T2 LED / 5-mode / 480LM / pure white / 1*18650/1*21700 / lanyard / IPX8 waterproof (2m underwater)
Use the coupon code MAP in the shopping cart page to see our unbeatable price $161.95!
Details:
Reflector diameter: 53mm
Head diameter: 61mm
Tube diameter: 28.3mm
Tail diameter: 28.3mm
Voltage: 3.7-4.2V
1*LED 6-mode 1000LM LED Headlamp
pure white / 1*18650 / Micro-USB rechargeable / IPX6 waterproof / angle adjustable / stepless dimming
FiTORCH PR40 Outdoor Hunting Searching LED Flashlight
1*Cree XPL-HI / 6-mode / 1350LM / pure white / 2*18650/4*CR123A / 1000m beam throw / power bank / IPX8 waterproof (2m underwater)
1*Cree XHP35 HI / 7-mode / 1300LM / neutral white (4700K) / 2*18650 / lanyard / IP68 waterproof
Ordered the ES03 Friday - good price! Used the BLF coupon code. Wish they had 4000K tint though. 6500K may be the least popular here.
Says will ship today -- can you confirm?
Seems like a decent buy, any idea what LEDs it uses mate?
Post #1000!
(at the moment)
SST-20's - it said in the BG listing - their listing is more complete, but you pay for it. FT has a good price for now, but of course it's risky for this "Smiling Shark" branded version. For me, gonna swap the LED's and driver anyway which eliminates some risk but I still won't know the quality and if the dims match up perfectly. The optic they use is a risk as well, but might be able to swap in something better.
