And thank you for the review. That is some sweet pitures you're taking. Looks like a real sweet light.
Can you say a few word about the beam compared to a P60 format XML light. I'm not thinking so much about perceived brightness but rather its ability to throw and do it with a nice beam profile.
Being OP reflector I do realize that throw is not its main purpose but I do like a bit of throw in my lights and for example I really dont use P60 XML lights for anything, thats how bad it is for me. XR-E or XP-G are my favorites in this size light.
So does it have a defined hotspot without the dreaded (by me) donut like appearance that XML lights are so good at making?
Solarforce L2T with 1.4A driver = 7300lux @ 1 meter
Solarforce L2 with SF XM-L = 8300Lux @ 1 meter
Solarforce L2 with Manafont drop in = 12300Lux @ 1 meter
Balder SE-2 = 16600 @ 1 meter
It was brought to my attention :
There is a slight blip or flash in low mode , every 7 seconds or so there is a slight pulse or flash , I used three different multimeters to see if I could read a current change and no go , I could detect none . Hmm , interesting , wow . I havent really used low mode much at all , as the light starts on high , I usually drop into medium , sorry about that guys .
A slight flaw in what is otherwise a very polished product .
Ah, as I suspected, this is really a BD-2 budget version! Old, I believe what you have there is the hidden mode access point. When you put it in Low and it blinks, click off and then on again to access the second set of modes: Strobe and SOS in addition to L-M-H. When you return to Low and it flashes again, turn off and then on again to return to the 3-mode version.
The first shipments of BD-2 made no mention of this in the manual. It was discovered and updated in later versions.
I just checked the stock status there are only 2 CW, and 1 NW left in stock. Are you trying to buy more than 1 NW version perhaps? I can't imagine why you'd get a backordered message otherwise... Anyways, I don't want to detract from the review thread, if you have any questions or problems please send me a PM or email through the site thanks.
Ok , after a few requests I have just completed a runtime test to see how long the light remains in regulation :
Apparently there was some question of how long the light remains in regulation : = 50 Minutes on a Sanyo 2600
Now if you look close enough at the pictures you will see the light is sitting in Water [ yes - water cooling ]
How ever all is not a bed of roses unfortunately .
After some 18minutes , the light strobe'd and continued to do so once every minute for another 32minutes of fully regulated output ...
After 50 minutes the output dropped very quickly and the light was doing 200 @ 51minutes and about 100 15 seconds latter . Batt voltage was 3.5v when I removed the battery .
I dare say , the SE-2 may need some more work ...
So it would seem some were doing run time tests and the light began to strobe [ once every minute for me ] and they thought the light was no longer in regulation ..
What it could be is the voltage warning level , as the light pulls about 3A on high , there will be a lot of voltage sag under such current draw .
So even though the battery has plenty of juice , the voltage sag kicks in the warning strobe ...
Im just wondering at what voltage the warning strobe is set for ? [ maybe 3.5v or 3.6v ? ] With such high current draw , perhaps a much lower setting is needed ..
Wow... I'm going to do a full datalogging runtime test tomorrow on one of my lights in stock with the new driver. I've not run it for more than a few minutes at a time, but never noticed any strange behavior like what you are describing. Hopefully not all lights are like that. I'll post my results tomorrow hopefully...
Can you describe the voltage warning flashes in a little more detail? Also, any chance you'll see how it behaves on RCR123 cells? Last question: what's the size of the driver cavity? This seems like a sweet light for the dough.
This was a continuous run , non stop from start to end ..
Light pulls about 3A on high to start with , so on a continuous run voltage sag will come into the equation ... https://budgetlightforum.com/t/-/8223 See this battery review .
As for reading it now , well , I have school , lots of home work , and time is a little limited , so when time permits .
Initial regulation check was to see if the light runs regulated , which it did , and did again this time , its unfortunate that the (error) did not show up in the initial test as I had done a full run with the previous SE-2 with no issue .
Woops forgot to edit the description when I got more in stock. Still a couple in stock, but I'm still carrying out my own testing on a few of these lights. I'd hold off if you plan to order for a few more days.
So far though 35 minutes into the runtime test no flickering or strobe type stuff going on yet...
Do NOT use 2x RCR123's or CR123's in this light. It is designed for a Single 18650/17670 cell only. The balder BD2 can accept 2xCR123's or 18650's.
I confirmed that the light does 3-4 brief flashes, to signal for a low battery warning. The datalogging sample rate was set to 1 second, thats why you see random drops in output towards the end of the runtime. The test was done with a Redilast 2600 with a 4.15v starting voltage. The first blink happened at ~56 minutes. The next blink was at ~59.5 minutes and the next set of brief flashes happened every 2 minutes. The light seemed to have terminated the discharge at around 25% relative light output. After the test, the light would not turn on until the battery voltage rebounded back to an acceptable usage level. Now when I turn the light on with the almost fully discharged battery, it blinks 3 flashes or so for a brief second, then will provide 2 minutes of output before blinking again.
Perhaps old4570's driver is defective and has the low voltage signal warning set WAY too high.
