There are no official run time specs. The mini uses a FET driver so both brightness and Turbo runtime is influenced by what leds it has and what battery you use.
I just tested two Vapcell 26650 4200mah, and it is better than the Golisi 4300mah and any other rewraps of the same YDL 26650 high current cell
In general, a 7135 chip at 350mA will be warmer than a FET using PWM to get an average of 350mA. On many LEDs, like SST-20 and LH351D, the 7135 chip will also be more green. Those LEDs get lower duv as the current increases, but not all LEDs follow that pattern.
So if you want the tint of a SST-20 or LH351D light to be colder and less green, using just the FET can be an effective solution.
However, it’ll also reduce efficiency, make the output not flat, make the bottom of the ramp really coarse, eliminate moon mode, and might age the LEDs faster. But it can still be worthwhile to get rid of the green tint.
Anduril 2 allows voltage calibrations in 0.05v increments.
OK… i know i am 2 years late to this, but the MF01 mini is easily one of my favorite lights and i just started reading this to find whcih Bin sst20 4000k was used. was it FA3? or FD2 by the way?
I like my silver version a lot, and i want the green. But HOW, HOW did blue or purple or red not happen? they look SO GOOD. makes me want to buy some more silver and anodize them myself… If taking the head apart wasn’t so difficult… OK, im done with my complaining.
I think I remember someone saying they had 1000 pcs of the FA3 but they weren’t going to use them in the MF01S. They were saving them for another light or something.
on page 11 of this thread, it said astrolux had 1000 pieces of FA3, potentially for this light.
Has anyone ordered the aluminum w/copper head recently? Does it come with the plastic spacer insert around battery + or the new Brass spacer insert Astrolux has been using?
I’ve read in the threads that it was coming with plastic, but wondered if they updated the copper headed version like the did the all aluminum version, by adding the brass insert for better heat Mgmt
Also, I wonder if they will make the copper head version again once BG is all sold out? There aren’t many left in stock.
I ordered a aluminium with copper head in August 2020 and it came with a brass spacer.
Bought the copper/aluminium a few months ago and it came with the brass thing. It can run at level 6/7 2.35A without stepping down.
Awesome, thanks grumsel and th558!
$43.99 price still available.
Just pulled the trigger on one, thanks Freeme!
Thank you for your support!
Interested.
Oh sorry, I didn’t realize this was the group buy thread. I’ll remove that post Freeme.
Product discussion is fine.
Can i have code please
Freem: Bought one using your code. Thanks.
