After using mine for a while…
It seems to hold the glow alot longer than the jetbeam,
but the jetbeam let’s the secondary lights pass through more.
The ui is actually pretty good.
I guess the 300 lumen strobe could work in absolute darkness.
I just wish the party light sequence when activating lock out was limited to a few blinks…
It looks like this light is manufactured by mateminco. So if someone doesn’t want to deal with banggood… Use the aliexpress mateminco store. The service is fantastic.
Got my today. Starlight blue and Amber. Really cute keychains. Smaller then expected lol. Button is a little stiff to press but i guess ok if u are gonna use them on your keychain so wont press on so easy in pockets etc.
The UV looks kidna weird on both, but red and blue are very bright, hard capture that with phone. For the price total worth it.
I received my white K2 today but I think it is defective unit after a little use. I didn’t read manual in first use and just trying some button combos of the key. Ramping was worked well and when I turn on for first time the light. I didin’t know what combo I am activated but now my light have very slow ramping. It is like a very slow step mode without ramping. For now to adjust the brightness is very difficult. I tried to factory reset but the result is the same. Do you think is the my unit is defective?
PS
Today I tried to full discharge the battery and seem that works. The ramping is reset back to normal. After that I tried to do some random clicks and that broke the ramping again. I discharged again and that reset ramp. So there is some firmware bug related to some sort of clicks. So if you have similar problem try to full discharge light.
I wondered if others were encountering this bug. It seems to go away by itself but it does not build confidence in the quality of the product. The UI seems like a modified form of Anduril to me. If so I wish they had used the unmodified version.
