The There Are No Stupid Questions Thread
1455 posts / 0 new
Scallywag
Scallywag's picture
Last seen: 19 hours 53 min ago
JasonWW wrote:
Scallywag wrote:
I’m also collecting the platters out of my dead spinners, for a future art project. Most of my hard drive magnets are on my fridge…
What do these magnets look like?
I’m too lazy to take and upload a picture – but I checked, and the google image search result for “hard drive magnets” is pretty representative. I have varieties from both desktop (3.5”) and notebook (2.5”) hard drives.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 53 min ago
The ones I grabbed look kinda like brake-pads.
lionheart_2281
lionheart_2281's picture
Last seen: 2 hours 23 min ago
Yep that’s exactly what they look like
jeff51
jeff51's picture
Last seen: 16 hours 36 min ago
Here are a couple. Often the holder has bends in it and makes it less handy to play with.
You can pry the magnets off the plates, but the magnets are way brittle and I often end up breaking one when doing this.
If you want a really strong magnet to play with, seek out an old 5.25” floppy drive – one of the early ones. They have a circular magnet that was used in the motor. So strong, it’s difficult to remove one from a fridge without divine intervention.
I’ve used the HD magnets to make clasps for woodworking projects. Good for holding “stuff” in place when a third hand is needed.
All the Best,
Jeff
jeff51
jeff51's picture
Scallywag, I’ve also been collecting HD platters. I started when clients needed a data wipe on a drive that wouldn’t spin. Pulled the platters rather than smashing or drilling.
Not sure why I started putting the platters in a drawer after hitting then with the degausser, but there I go again collection “stuff”.
Some of the platters are more silver colored. They make great first surface mirrors as they are VERY flat.
For some reason I also stared stacking old CD disks from software releases Etc. Stuck a dowel in a hunk of wood and started piling them up. About 3’ tall by now.
For those interested in harvesting HD magnets, you will need a few smaller Torx drive screwdrivers. Be sure to look under labels for hidden fasteners.
Good quality stainless steel screws and aluminum (from the chassis) for recycling if you are so inclined.
All the Best,
Jeff
Scallywag
Scallywag's picture
All the Best,
Jeff
Yup. I have one of the $25 iFixit miniature screwdriver sets (well, it was $25 when I bought it, $35 here ) and it’s all I need for the screws. Some of the labels/stickers are a bit tough on just fingernails, so I’d recommend some kind of metallic spudger tool for those. As mentioned the magnets are quite strong so have fun with ferrous-metal tools occasionally snapping over to the magnets Thumbs Up
The best platter I almost had showed significant head-crash damage. Along the inner half-inch the coating was mostly completely removed (some rings here and there remained). However, that platter technically belonged to an old employer and had to go to their secure data destruction procedures… (they drilled holes in the platters). My plan for my shiny platters is to mount them all in a frame as a cute artsy “mirror”.
That’s cool re: 5.25” floppy drives. I’m not old enough to have ever used one myself, though I’ve encountered them (and the actual floppy floppy disks) as scrap occasionally over the years.
turkeydance
turkeydance's picture
Last seen: 12 hours 31 min ago
salvaging magnets from old tech was something we did for several years.
now, we check out the recyclers on Craig’s List when we need some more.
regarding mirror-like platters: we used the hole as an aiming device
for signaling in Cub/Boy Scouts. it was harder to do as opposed to
using a dedicated signal mirror, but it can and was done.
fragility forbid inclusion in our load-outs.
Sari33
Last seen: 8 hours 28 min ago
Forgive my ignorance, it can be harm to the eyes look direct a Led driven by about 5 mA but with PWM?
the driver is AMC 4*7135.
A friend ask me if there will be eyes issues with PWM.
Scallywag
Scallywag's picture
PWM itself will not harm eyes. However, if it’s slow enough, it can be unpleasant to see. Even disorienting, I think.
ggf31416
Last seen: 8 hours 5 min ago
If the driver is 4*7135 the current should be 1400mA, so it’s unlikely to be 5mA unless there are 280 of such LEDs in parallel. I guess you mean 5W.
jeff51
jeff51's picture
I don’t think it makes any difference if the LED is PWM controlled or current controlled as far as looking at it is concerned.
Too bright is too bright no matter how you get there.
As Scallywag said, a too slow PWM coupled with a short duty cycle makes for a very unpleasant light to use in almost any circumstances.
Some lights have truly awful PWM running in the 100Hz to 300Hz range with 5% to 25% duty cycles.
One of these will cause eyestrain and headaches for me and many individuals. Yet some folks seem immune to truly awful PWM.
There are several threads about PWM that are buried in the general info category.
I made a video of the LT1 PWM charactistics and duty cycle here:
https://budgetlightforum.com/node/73356
That might help explain the relation of PWM to brightness.
And another looking at PWM vs camera shutter speed.
https://budgetlightforum.com/node/73615
All the Best,
Jeff
jeff51
jeff51's picture
Scallywag, Here are a few of my platters. 2.5”, 3.5”, 5.25”, and Big’en out of an old IBM mainframe disk pack.
All the Best,
Jeff
Scallywag
Scallywag's picture
All the Best,
Jeff
The big one is amazing. I don’t even have any 5.25s, and I expect within a few years there won’t be any active spinners in the house anymore.
CNCman
CNCman's picture
Last seen: 35 min 54 sec ago
All the Best,
Jeff
Thanks Jeff Thumbs Up
I will check this out. Is there a way to improve the duty cycle time ?
jeff51
jeff51's picture
CNCman,
PWM and the duty cycle is baked into the firmware.
So unless you can get hold of the code and flash the driver you are stuck with the OEM settings.
In another thread TK told me that the 5K PWM at the lowest levels was to provide enough “ on time” pulse to light the LED.
I (think) I can detect PWM into 3K realms if the conditions are right.
Total dark and spinning fan blades that I can vary the RPMs.
5K and up and I’m good.
All the Best,
Jeff
CNCman
CNCman's picture
Is it possible to modify a Halogen light bulb spotlight to use a XHP 70.2 led. I am concerned the reflector is not designed correctly for a led.
A good friend uses a cheap Q beam on his early morning fishing trips in his Bay boat to navigate to open waters. I thought maybe it could be improved since he is disappointed in its output. I wanted to dig into it since my operating table is vacant. Wink
Scallywag
Scallywag's picture
Yeah, most likely the reflector is not shaped correctly for an LED. Think about where the light is being emitted in each case – and therefore where the reflector’s focal point should be. For an LED, it’s almost exactly at the bottom of the parabola. For a halogen bulb, it’s going to be some distance inside the reflector.
anonymous_user
I have seen several Surefire lights that include a clip that makes it go bezel up when stored in pocket. What are the practical uses for such a configuration?
I know for some small lights you can clip to your hat and use as a pseudo headlamp but what of larger lights?
MascaratumB
MascaratumB's picture
Last seen: 55 min 10 sec ago
Do lighted forward clicky switches exist?
JasonWW
JasonWW's picture
Last seen: 10 hours 14 min ago
The lighting element and the switch are two separate pieces. So yes, you can mix and match to create a lighted forward clicky switch. As far as whether you can buy a pre-made lighted clicky switch, I don’t know. They’re not very common on factory lights.
carsknivesbeer
carsknivesbeer's picture
Last seen: 7 hours 35 min ago
At the time I ordered, CSLMN1.23 C8+ was out of stock, so I ordered a CSLNM1.TG C8+ 12 mode to swap the .23 into but I just learned the forward voltage is less for the red Osram. I’m new at doing swaps and figuring out drivers so what driver should I use in place of the 12 mode driver I ordered? I want to probably order stateside because I have a certain time frame in mind for a project (4th of July…). So which driver can I use turbo or 100% for a good bit without frying the red?
Yokiamy
Yokiamy's picture
Last seen: 8 hours 5 sec ago
I’m not sure Simon uses different drivers for those LED’s, his drivers arent that sophisticated.
i think you should be fine, maybe a good google search will give both currents.
MascaratumB
Thanks for your reply Jason!
I was looking for something “pre-made” as I don’t have the skills to do something joining pieces!!
Thanks for the reply and the quest continues Wink
Rayoui
Rayoui's picture
Last seen: 1 day 17 hours ago
Simon offers a buck driver designed for red LEDs and single cell.
https://www.aliexpress.com/item/1005001619557257.html
carsknivesbeer
I am already 3 weeks into an order from Convoy and was trying to get on in 2 weeks.
This is a feasible driver correct:
https://www.mtnelectronics.com/index.php?route=product/product&path=67_1...
Rayoui
Rayoui's picture
Yes, that should work fine.
Frankthetank63
Last seen: 2 months 4 weeks ago
The Convoy 4×18a flashlight sbt90.2 can be purchased with or without its 18650 batteries,
I don’t know anything about the included batteries, and I am wondering if it would be worthwhile to purchase them separately for a performance standpoint?
JasonWW
JasonWW's picture
It looks like Convoy is offering 4 of the Liitokala 3500mah cells for an extra $18. I’m not too familiar with that particular cell and I can’t find any reviews or tests on it. All I can say is it would fall in the “high capacity” style which looks like it would be fine for this light. Does anyone know the driver type of the SBT90.2 version? If its a FET driver you might be able to squeeze out some more lumens, but only when measured. Its doubtful you would see the difference with your eyes.
Those included cells should be fine.
Frankthetank63
Thank you for taking the time to reply, I will be ordering one for me and two as gifts it will make things a lot easier!
ArtieT59
ArtieT59's picture
Last seen: 9 min 40 sec ago
OK - i have a stupid question!
I feel like i should be able to understand this by now, but every time i think i do i realize i dont.
Regarding XHP35, XHP50.2 (NOT 3 volt), and XHP70.2
 -Are they all both 6volt and 12volt, depending on how the LED's mcpcb is made? Or are xhp35 and xhp70.2 12 volt, and xhp50 6 volt?
The reason i'm confused (i feel compelled to explain) - i have asked Simon @ Convoy numerous questions about putting a xhp35 in a xhp50 (6 volt) light he offers on his page, or about putting an xhp50 in a xhp70.2 light he offers on his page, or any one of the combinations you could think of between these three LED's and all the awesome offerings h has for them.
Sometimes he says yes it can be done, and sometimes he says no it cannot. Just today he told me the xhp35 could not be put into the M3c-u light he has because there is only a driver for xhp70.2 so far. What does that mean? if they are the same voltage, would there be another reason they wouldn't be compatible? Could the amperage be too high for the xhp35?
Also, based off of Simon and my conversations, i was sure i knew that the xhp70.2 was a 12v LED< but then looking on his AliX store today ( i do this often) i found the LED offering for a "xhp70.2 6volt on 25mm mcpcb".
So now i am lost.
NOTE: * I am NOT blaming Simon for my confusion. I feel like if i actually spoke face to face with someone who knows this information, i would've understood it months ago, but sometimes with the "back and forth" of the computer, key info gets lost to my brain. thats a "me problem".
What volts are these LED's? Or is the voltage for these particular LED's determined by the mcpcb layout? (i feel like once u/cncman shared pictures with me of 12volt mcpcb's vs 6v mcpcb's.
Thanks!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
