I would like to do this in a group buy format. If we have enough interest for 100 pcs, you would then make a prototype, send it out to someone like Djozz who has the testing equipment to double check that it functions well with the LT1. Once he gives the green light that it’s ready, you would get the boards made, assembled, then list them on your website.
You can add in your fee onto each board (so maybe $1 per board?) to recuperate your costs for designing the boards rather than having one person carry the entire burden for the design fee. I think the $16-17 shipped price is a reasonable price at which people would buy the boards at, are you alright with it?
I would only like this project to go ahead if we can garner enough interest to make it worthwhile for you to make it and sell it at a reasonable cost.
Are you okay with this proposal BelMOR?
And like to ask, if an complete LT1R with already installed SUNLIKE LT1 board might be possible?
I would be definetely interested then. Sure in for 2 copies with 2700K and 660nm red if complete assembled with LT1.
But swapping the existing board out and a new one in with having a useless spare one wouldn’t be for me.
I know. Logistically it might be somewhat difficult to coordinate. Sofirn doesn’t seem very flexible especially for small orders from what I’ve seen and read. I’d imagine there would be a lot of hassle trying to coordinate this from the factory.
The best I expect they might be willing to do is sell the LT1 without the MCPCB or LEDs
This is the cheapest option I believe. It’s a nice lantern and I do recommend them to people. I think we will have enough interest to get this project going but I cannot be certain we will reach 100 pieces of interest at this point.
I brought up the idea of having 4 more warm emitters than cool ones to LampMan and he said the two colours have similar brightnesses so it would offset the balance.
I’m trying to keep the total cost as far below $20 as possible since the LT1 is only $50 on its own.
We’re talking about 123 vs 153 mA/LED and the same total current. Efficacy improvements will give at most a few percent difference in output. Please note that most of efficacy improvements come from lower Vf rather than higher output. And here this improvement will be burned by 7135s anyway.
And in the datasheet I see a few percent difference between CCTs as well.
So I actually think it would act as an output equalizer.
This may be different if the LT1 driver has extra 7135s soldered (which I would recommend anyway).
EDIT: I see that 7*7135s per channel is the max. So efficiency improvements from having more pads would be quite small but still, they should improve the outputs balance.
This is what I said but LampMan (BelMOR) is adamant that the warm and cool emitters are the same brightness.
I expect the lower Vf than the LH351D and same current but higher light output will result in a cooler LT1 head/top part which is good since that’s where I notice most of the heat building when running my LT1 for extended periods of time with 7 amc7135s active.
Id like to have at least one. Im not too picky and will likely settle on a popular combination of warm tints, once the group reaches a consensus. This is an interesting thread and I appreciate the R&D going into it.
1. I can do 18+18, it is all in this space
2. In future will be 3rd generation of SOL2835, it is much more brighter, but without violet
3. 660nm red have ~2.2v, not ~3v. It will work or no?
