I don’t have an SP35 yet, but would like to compare the ATR with a SP33 V3 which had extreme output oscillations. And a full review, of course.
I see it only comes in 6000-6500K. How’s it look? White or blueish?
Mine is white, and quite clearly closer to 6000K, compared to my 6500K SC31B, which has a blue cast.
I’d like to see an OP version of the current reflector to bolster the short range a bit. Intermediate is this light’s strong suit.
For a thrower, maybe they’ll repeat the past with
flooder : thrower :: SP32 : SP31 :: SP35 : SP35T
I think Luminus SFT-40 could be a great emitter for SP35T, especially if it was available in 5000K CCT. It is basically the SST-40 without dome. It probably gets you a bit more peak intensity compared to SST-40. As an alternative (more lumens, less intensity) they could incorporate Luminus SST-70 (6V) into that light but then it takes to use a boost- or buck/boostdriver, like their SD05 diving light.
Thanks
Does anybody know if there are any plans for Sofirn to make this light in 4000k or 5000k?
They could easily offer a 5000K version but I suppose SST40 5000K is very limited right now. They have probably used them up for SC31 Pro and SP36 Pro.
SST40 4000K does not exist. XHP50.2 3V (as alternative) is not available in anything warmer than 5000K and even these are prone to greenish tintshift.
I’m really liking this updated sp35 with ATR working,looking forward for the reviews,seems like a good balance for lumens/battery duration and with thermal control you can give it to uneducated userà.
Meanwhile, I have received my new Sofirn SP35 (with ATR) from AliExpress, purchased a couple of weeks ago. Today, I have run a detailed analysis regarding runtime and temperature. Below you find the results:
Conclusion
In general, Sofirn did a great job with their new model SP35 as you get a decent price/performance ratio for a small budget. The initial version without ATR (sold out) received a lot of good feedback in forums like BLF and TLF and revealed how good a buckdriver with constant current regulation can be. Many customers appreciate the option to manually step down their lights with regard to proper safety precautions.
Now, with their new ("revised") version with ATR I feel a bit displeased. On a positive side I can confirm that ATR works effectively, i.e. the flashlight remains within its thermal limits of about 55°C. Overheating will be prevented successfully. On a negative side I discovered a way too aggressive regulation which cannot provide a steady continuous output. Quite the contrary, the output always fluctuates between 28% and 63% of its initial ANSI output. This is such a big difference that you can even notice it with your bare eyes. For some of you this "sawtooth" profile will remind you of Sofirn's SP33 V3 which has also received some negative feedback for its mediocre thermal regulation.
Sofirn shows how it can be much better with their SF47T model. There you will get a much smoother regulated output with fluctuations of only 8%. I include the runtime chart of SF47T for comparison below. I hope that Sofirn will be able to do some tweaking on SP35's thermal regulation. Apart from that there is not much to not like about this flashlight. If they were to offer more neutralwhite/warmwhite tints as well as a logarithmic ramping curve, it could become one of the most recommended budget flashlights.
My SP35 with ATR should arrive in the next few days to a week. I was very hopeful after seeing your SF47T test… Sofirn finally stepped up their ATR game! But alas, it looks like that better version didn’t make it into the SP35. What a shame.
It might be the same ATR and the SF47T just performs better due to higher mass and thermal buffering/dissipating surface area. Dissapointing for sure. That PID needs tuned for a smaller light
The non-ATR version shows still available on Amazon. It looks like the ATR version is also available there as of today I think.
https://www.amazon.com/Flashlight-Without-Battery-Inserted-Outdoor/dp/B08QR1VD4V
Been waiting for review of new model with ATR, glad I did not order new model.
Just got one of the old ones.
Thanks!
I was thinking about buying this light but this “advanced” temperature regulation is very dissapointing.
Thanks for review.
They regulated the temperature well but at the cost of steady lumen output.
I am just doing an analysis on High mode. As expected I see ATR is being triggered as well. I am going to post more details later on.
Is the max temperature fixed or adjustable?
You mean the stepdown threshold? No, it’s fixed. Sofirn says their new ATR uses three threshold values (45/55/65°C) that control brightness increase/decrease differently. In a nutshell: The hotter the light gets the more quickly the brightness will be decreased.
To my mind the average temperature kept during operation is too conservative with only 48-52°C. gchart revealed in his review of the no-ATR version that SP35 can maintain High mode (approx. actual 840lm OTF) stable at 56°C, provided that ambient conditions are probably around 18-22°C.
I hope gchart will not mind if I borrow his runtime chart of SP35 no-ATR on High mode...
Darn! I was waiting for the ATR version for safety. But I should have gone for the non ATR version. Now I will only buy them if they rectify this
Thanks, it was that 45/55/65 thing that threw me.
