They will be MUCH brighter?
Do you know when these will become available?
Do you have any data to compare to the 2nd generation SOL2835?
Id assume they will be more efficient at the same current (Higher flux BIN/higher lumen per watt).
If that’s the case, Id rather wait for the 3rd gen SOL2838 to justify the emitter swap and proposed higher efficiency.
First, need to raise money at all to start this project. And after pcbs are ready, it will be very easy to solder any other LEDs there. But at this rate of raising money, I suspect that the 5th generation will come out before the boards will be ready…
My intention was to first check how many people would be interested in this idea and if we had the interest, then we would go ahead and take the steps towards making it.
If we didn’t have the interest for about 100 orders, it wouldn’t be worthwhile trying to put this into production.
Personally I think it is a bit premature to be fundraising before we really have an idea of how many people would be interested.
If I thought exactly the same, then my SunLike light bulbs would appear in 2020, but they appeared at the very beginning of 2018
s And at all. I said that 10 customers would be enough. You were talking about 50 or 100
pps. I already ordered the red ones 2835 660nm. But with flashlight some problems… Sofirn official store on aliexpress did not answered about shipping inside China and discount with it
I think 16+16 would be best so the brightness is more even. Wouldn’t 18+18 make the brightness less even without increasing the overall brightness by much?
Do you need jumpers? Wouldn’t something like this work where the red highlight is the (+) and the black is the Warm white Negative and the blue is the Cool White Negative work?
do not worry, all will be fine. I use 660nm (for growing lighting) since 2014, and I see difference by my eyes between 630 and 660nm without spectrometer.
Also I am going to order it from another seller too
