Great news Tom… Yeah I just got pfizer shot #2 on Tuesday. I had absolutely no side effect all from either 1 or 2. Maybe just a hint of a light bruise sensation on my shoulder but that only lasted a few hours and only the night of. Nothing else to report at all.
Shot #1 I got at a local community center. 1:15 hour line that circled around an adjacent park, about additional 25 minutes to administer the shot and screen for side effects on site. Limited parking. I had to park in an adjacent neighborhood and walk a couple blocks… shrug, beggars can’t be choosers.
Shot #2 was at my local football stadium. WELL staffed, zero line… I literally just walked in after staff member checked my paperwork. ~35 minutes for everything. Not sure if you have a choice, but IMHO sports arenas seem to be much better at handling large crowds and parking.
Good luck and get well soon!!
[EDIT] Tom E if this is too far off topic for your thread, just let me know and I will edit this post. Good Luck though, hoping for the best for you
Can an owner of these lights take a caliper measurement of the body tube diameter? Specifically the texture grip area across the mid section.
I am leaning towards the XHP50.2, 6500K. How is the color tint of the XHP50.2 when driven around ~1000 OTF lumens in a constant-ON scenario? How green/yellow does it get?
I received my gray SST 5000K today. There are no questions about the quality of the case and assembly. Slightly disappointed with the quality of the light. Maybe I’m just spoiled with similar optics on the Manker MC-13 with osram. I’m not used to seeing artifacts in orbit around the sunspot. I thought illumination will be smoother … SST-40 is seriously green at low levels … In general, I still don’t understand if I like it or not.
Anduril is peculiar. For example, you cannot configure thermal control after 10 clicks (via technical mode).
I will check the parasitic leak later, but this is not very important, it makes sense to unscrew the lid anyway. A few millimeters are enough.
Wow, I love the beam and tint, hhmmmm. Saw someone else post about how they liked the beam of this optic and was think'n the same thing. I got lots of multi-LED SST-40's and XHP50.2's way brighter, but this light for me hits the spot with a nice clean spot, not crazy heat, and I'm not noticing the green I guess. I'm using the Vapcell T50 with this light and it's outstanding. Granted, it's not the good SST-20 3500K quality, but for a 5000K, it's better than other 5000K LED's I got.
For me, the 351D 4000K sliced, XPL-HI V2 5D, and the good SST-20 3500K are about the best.
Of course I got Anduril 2 loaded, fully calibrated for temp and voltage.
Isn’t 50T too much for a direct drive SST? I think this is exactly the option: you even connect a nuclear power plant, anyway, a diode greater than 9A will not accept …
By the way, on my substrate is not copper, brass, although 2mm thick.
In general, I do not like SST 5000K in this optics. I will put XHP50.2 3000K. Only now I think: to dedomite or not?
Yes, it’s 2mm, but I’m pretty sure it’s red copper in mine. I polished it to make it smoother. Unfortunately, there is no 3V XHP50.2 warmer than 5000K. At present, it is currently only available around 6000K.
I’d like to see with CULPM1.TG.
Are you talking about the MCPCB??? Don't know why you are not answering my questions.
If so, from 2012, I've never seen or heard of a brass MCPCB - ever. It's thermal conductivity is worse than aluminum, it would be a mistake and tragedy, to say the least.
Some copper MCPCB's, like Hank's Noctigons, have gold plating on the bottom that has the same color as brass - maybe that's why?
