The leds for the Sunlike boards are Sunlike, which is a cooperation between Seoul Semiconductors and Toshiba. So no chinese leds. And even if they were chinese (btw, even chinese leds are improving all the time ) there is no reason to expect them not no last many thousands of hours, if things go wrong with cheap led products, it is always the electronics, not the leds.
I disagree with your comments regarding the robustness of the Sunlike board. The emitters are made by Seoul Semiconductor which is a reputable company and not some noname Chinese manufacturer.
I have faith in BelMOR’s judgments because he is experienced in this field and has been selling his bulbs for some time.
I don’t believe a DTP board is needed. Each emitter is getting at most 153mA at 3V, that’s less than half a watt of power.
DTP is necessary when you’re driving high power emitter beyond specs. 150mA is the average rated spec of these Sunlike emitters with their max current being 300mA
7 AMC7135s active results in just 2.45A, being shared between 16 emitters is not a lot of heat to dissipate.
I wouldn’t move ahead with this project if I didn’t think the final result would be a good, robust design.
Thank you, and I stand corrected. So getting into it… browsing SOL’s 2835 data sheets were rather spartan and lacking, which did not inspire confidence. Nor could I find any of their emitters being used by large certified luminary manufacturers. Also, CRI was rated >80, not the high 90’s. I was also put off by the response I received from SunLike when I asked him about the higher binned 2835’s he had mentioned. He also ditched Sunnysunsun when he asked for a datasheet. Perhaps a language barrier, or just a sales driven ambitious fellow anxious to make a buck. Reading his older threads… I felt the same hard push to sell and avoidance to anything that might prevent that from happening. After further searching, I couldn’t find any independent reviews concerning the longevity of any of his products. Now having said all that, I was still interested in one of his boards… its only $20, but Id rather have the stated much brighter emitters he had mentioned that were in the works. I’ll see when those might become available through SSC/SOL, if I haven’t lost interest by the time he’s producing the boards. I often browse industry publications and business related articles because I sell large high value luminaries to local businesses (typically GE and RAB products), thus my interest. I have yet to ever see or read about one implementing SSC/SOL emitters. Probably because they do not appear to carry industry certification standards, which eliminates them from certified commercial markets and vendor lists. All comments welcome. Its another toy to play with, and I think the research is half the fun for most of us. Im probably done digging for now.
Im still much more interested in owning a nice red anodized LT1R. Hopefully it will happen soon.
SunLike products are not sold everywhere, just as you will not easily find Optisolis products. The reason I think is not so much the quality, but that the lighting industry is (still?) very much focused on 80CRI, 90CRI the most. 95+CRI products is a niche market. There is a rather large german company, Lumitronix, that has SunLike products in their standard assortment: https://www.leds.de/catalogsearch/result/?q=Sunlike
About the guy from Belarus, I think that he is doing interesting stuff on the boundary of DIY and professional work, that is too specialistic for most companies to be profitable. He has his typical way of communicating things, that may be a personal or a cultural thing, but I also think that he is starting up his company, is not rich and really needs the money, and is blunt about that.
I would be interested in a red anodized LT1 that ramped between deep red and 4000K high CRI. I would not be interested in one with 2200K LEDs, or anything warmer than 4000K really.
Just got mine today. I am curious what type of add-on accessory people are buying to use as a handle? Just a big lanyard, or is there some other accessory that can be added on?
Has the option of a high efficiency driver been considered? I’d be cool to have that as an upgrade option when buying an LT1. Maybe Sofirn can commission Loneoceans like Fireflies did to build them an efficient driver? That along with SunLike LEDs offered stock would truly make this the endgame lantern for me.
Does the LT1 when fully charged, the on/off button/glow switch turn green. Mine is orange and I have put in on charge for like 5+ hrs still not turned green. Charging with battery charger that was shipped by default
The button is orange by default, and will turn red when you plug it in and start charging. It will turn green when it hits termination. It does take quite a while to charge all of the way, depending on which cells you have there’s a lot of capacity and I don’t think the charge current is very high.
With completely flat cells, it can take as long as 10 hours to fully charge. The charge current is only 1.5A.
Make sure the red LED illuminates under the button cover to indicate that it is indeed charging when you plug it in. The older rev driver board will not charge with a USB-C to C cable (must use USB-A to C).
The cost is not worth it. It might be as much as $15+ for components alone for not all that much improvement. You’re already getting 4+ hours on high with 7 7135s.
Yes, you’d gain maybe 15- 20% efficiency at the start at most but that efficiency gain decreases as the batteries discharge. It won’t even make a difference heat wise since the LEDs are far away from the driver.
On top of that, you’d have to pay people to design the driver and much more.
Some questions that have for the thread. Is it possible to run the device off a single battery? Or two? Or three? I’m looking for ideas to reduce weight. I can see that running off of USB directly is possible. I was thinking as an alternative, if there was a cap/base that could be put on the bottom to protect the inside of the lantern, and then just dedicate a USB power bank of my choosing?
This has probably been asked before, but is there a pogo pin kit I can buy to flash the LT1 with a new firmware? I already have the kit Hank sells for Emisar / Noctigon lights, so if I can use the same with another pogo pin end, that would be nice. TIA.
I can confirm it will run just fine on only 1 battery. It’s still pretty damn heavy though, I’ve just resigned myself to leaving it at home anytime weight is going to be a concern.
