Because of the risk of spam messages and calls, it is generally not a good idea to share personal contact information on the web. I recommend editing the post to remove the number and sharing such information by private message.
Barry was the Sofirn contact for various BLF-Sofirn joint projects, like the Q8 and the LT1 lantern, although he is not the boss, he has influence, and for us the only one there who speaks english.
I understand that 660nm is available but I can’t resist to mention an experiment I did a few years ago.
The experiment was adding red light to 80CRI 2700K leds, and it appeared that the most effective wavelength for that was 640nm, which is more efficient than 660nm (almost 3 times as visible to the eye) and makes for a better spectrum with less of a gap in the red region. The CCT went down to about 2400K if I remember well, and CRI went up to 95.
I’m not sure if I like the sunlike + red idea…
SOL has no problem with producing 660nm and even over 700nm.
I have a feeling that colour rendering is more likely to go down than up, especially if there’s a lot of red mixed in to the spectrum.
But I’m not sure about it.
Anyway, mixing different red wavelengths might be an option as well.
I understand that with SunLike leds the red peak goes more to the the right than with 80CRI leds and so longer wavelengths will fit better in the spectrum.
It will at least be very interesting how this works out, I like new stuff!
Is that 37 + 2$ for each full LT1 or just the empty body with the intention to replace with your board?
I am definitely interested in a 2700k + 660nm DR LT1 board. I haven’t had any experience modifying lights before, how tricky would it be to swap the board out for a SunLike one?
Sounds great, I have placed an order for a 2700k + 660nm Red. Would be cool to put this in the red anodised body spoken about in the LT1R thread if that does end up being produced by Sofirn.
Wow that’s surprising! I expected a lot of people to want warmer tints/red with the requests for 2200k and warmer!
With my current LT1, I much prefer the warmer white and have found myself keeping it at the warmest setting more often so I have no need for another lantern with cooler LED’s. I have enough torches for that purpose.
I would love to have a 2700k warm white into red for outdoor use late at night. Excited to see the project progress
