for now we just release RD6006P, please wait
RD6018 customer review
In Russia, delivery via DPD to the halva postamat. Very comfortably. compared the readings of the voltmeter of the converter with my devices. I'm happy with the result.
https://www.aliexpress.com/item/1005001488070904.html
RD6018W review
Finally I put together a kit. It turned out to be a nice beautiful and useful laboratory power supply for my radio workshop. The unit arrived at 65V 12.3A.(you can still get 18A output on RD6018 even it is 12.3A from the PSU)
RD6018 customer feedback
arrived quickly. packed in styrofoam. thank you seller. accuracy up to 2 decimal places.
RD6018 feedback
Good product, good seller. Detailed explanation on the YouTube channel I bought 2 of the same product. RD 6006 and RD 6018 both products are of very high quality. The product arrived quickly and is very, very well packaged.
Everything is very neat, high quality. Well done just the way it should be. It's a little silly to talk about the speed of delivery. In this case, it did not depend on the seller. Of course, I recommend it for purchase.
I collected everything for an hour. The block is whistling. To stop whistling, you need to put a resistor from the kit. In general, like everyone else, it whistles and works =)
RD6018W customer review
The original idea is a power supply from ready-made independent parts.
excellent, almost accurate readings. difference of 0.01 V relative to a verified tester.
RD6018W customer feedback
All perfectly. The box comes with a complete set of wires and fasteners, an outlet and a switch.
all perfectly.
RD6018W feedback
The converter with the housing came to me in good condition and without any additional charges. visually everything is really good quality and it looks like everything will be OK. I am very happy with my purchase
this is necessary for everyone who works with electronics, has a pretty good monitoring, very good product.
I ordered a complete set: RD6018W with an S800 case and an S-1000-68 power supply and assembled it. Everything works fine. The packaging is branded, especially the RD6018W module, so iPhones are packed.
RD6018W feedback
Well packed. I want to use it with a 1000VA toroidal transformer 50VAC (70VDC) to have less noise, it fits perfectly in S800 case.Nice soft buttons. WiFi tested and works good. Battery charge datalogger is ok, but it only exports to Excel.
Very nice packaging. Works great.
RD6018W feedback
Everything is at the highest level. Delivery to Belarus took 15 days. Packed soundly.
RD6018W feedback
The best power supply dc/dc DIY, nice product 100%
Frequently asked questions:
Can I use your power supplies to charge battery?
yes, for RD series, please use the battery charging terminals, it has protection function, for DPS series power supply, you must check the wiring before turn on the output, it has no reverse protection.
perfect product, matches seller's description
