Dedoming the LEDs will reduce the colour temperature but also increase throw and reduce brightness by about 10%. I don’t think anything below 5700K exists for the 3V XHP50.2. The ones that claim to be 5000K are ususally just a bit rosier which is nice but still not 5000K.
Well now I know why they only came in the cooler tint. You learn a new thing everyday never knew that about the 3V XHP50.2 thanks.
Looks like its staying on the cooler side which is fine just thought it would be better around my sweet spot 4K. Not sure it would be worth the effort just for a rosier tint.
So all the XHP50.2 FW21 pro lights came in 5700k only? Maybe I have 6500K version I could not find that info anywhere.
My first copper light I think every new light will be in copper from now on.
I just wish it would patina faster as I like that old look better than the shiny look.
Update: Lumintop just got back to me about my tint question with this reply “Hi, this FW21 PRO Copper we only have xhp 50.2 led with 6500k”
So looks like I could go warmer as Cutters here in Aus has 3v XHP50.2 in 3b 5K sweet.
But I cannot seem to get my bezel off my light has anybody pulled this light down yet? I cannot seem to find a review where a reviewer pulls the light down showing the emitters does anybody know of one?
Just trying to see what these LED’s are mounted on so I order right. Hate to order bare led’s to find out they are mounted on single boards.
Hey Rat, that FW21 in copper looks sharp. I have a bunch of xhp 50.2 emitter lights so I’d probably want sst40. Where do you get those battery wraps from? I have FW4A & FW3A so I’ve been tossing up between the SBT90.2 FW90? or whatever it’s called but now ive decided it’s gonna be copper for sure.
You mean this top part that has to be unscrewed to change LEDs? Because it can be pulled out easily, just like FW3A series, I unscrewed it doing the review, to show the inside, but unfortunately, when screwing, I destroyed all LEDs, just annihilated them… So I decided to not show it.
Yes the top part. Mine is stuck on very hard. I run the light on high multiple times to get it nice and hot than used rubber strap wrenches but still would not move. Maybe the copper version is different.
Have you still got a picture of it with the top and reflector off?
The FW21 X9L (SBT90.2) also comes in copper. I think I will be getting that light next when it comes on sale. The copper KR1 also looks nice and sounds like it performs.
The scale wraps only took 8 days from aliexpress Here
I also use black wraps to get the battery a little thicker Here
The next one I do I will try a black wrap, than skull wrap, than a clear over that or it could be two black to get the right thickness I cannot remember how many I used on that battery.
I dedomed my fw21 pro xhp50 before I sold it a few months ago. They are mounted on one board together. If you get bare 3V xhp50.2 leds you will be fine. You do not need to get a board. And I don’t know where you’d find a mcpcb like the fw21 pro “off the shelf”, I tried emailing lumintop to see if I could purchase a couple extra mcpcbs from them for the fw21 pro, but they never responded to me…I was going to mount 3 osram CULPM1 emitters on a second mcpcb so I had 2 different mcpcbs I could go between. The osram CULPM1 and culnm1 are both 4040 footprint like the sst40, so would be an easy reflow if you had the extra mcpcb
So… the appearance changes a lot. The tint changed approximately 1500-2000 cct, it will look like less than 5000k after dedome. The only concern is, it also turn quite green.
If you want it less green after dedome, You can order small sheets of Lee’s minus green from a member of blf here (DC-Fix Diffusion Film Sale) which will help counteract the green. If you do get the Lee’s minus green, go with –1/2. I did the –1/4 and I should have went more.
I loved the look after dedome at first but then after getting more lights with lower cct emitters, I realized how green the dedomed xhp50.2 is and ended up regretting the dedome. But if I had the appropriate minus green filter it would’ve been fine.
Remember, you will lose approx 15% output dedoming, but you’ll pickup about same % in throw.
If you have a heat gun, heat the bezel on medium / medium high for a couple of minutes. That is what I have done for inset stainless bezels that are hard to remove and it works every time. Also, if you have rubber heavy duty work gloves that helps a lot too.
Oh wow Mocarney! I’ve never seen anything like that !
Put (3) osram CULPM1 !! It would be so awesome, and I wanted to do it. You can buy them bare from Simon for about $27 for all 3 of them. Would be an awesome mod, and they are 4040 footprint so they would reflow right into the existing mcpcb. Perfect opportunity to do it considering what happened to yours.
Thanks for that looks like a simple MCPCB swap if I can get my bezel ring off.
Lumintop said they can sell me the MCPCB for XHP 50.2 so I will order two. Then I can keep the 6500K LED’s on the original board. If I do not like the 5400K as much I can just fit the original back on. I will keep the second MCPCB for future mods maybe.
thx
