I think the general conclusion is flashlights are useless as blinding weapons. No matter how powerful the light is, they aren’t effective at blinding a determined attacker for more than a second or so.
MS18 at 100k Lumen turbo is throwing out an insane amount of light. Anyone looking directly into the beam will certainly be blinded initially.
I would say it’s a hefty piece of kit to be trying to quickly turn on someone and get onto turbo to try and blind them, especially if they are a determined attacker. If you are wanting a torch to have a brief blinding affect on someone I would say anything from 5k lumens upwards being ‘turbo’d’ at someone’s face (depending on range) would blind them initially, might buy you a few seconds.
Lumen count is not the only consideration, a light with a high candela aimed at someone is going to be completely blinding. I would not want to be on the other end of the beam of a Weltool W4 shone directly at my face that’s for sure.
If someone is determined to attack you for some reason, no amount of light shone in their direction is going to help as much as running/defensive manoeuvring. You might scare off an opportunistic attacker quickly turboing a light in their direction or just cause them to come at you even faster. All going to depend on the circumstance.
Human eyes are extremely good at adjusting to different light levels - it’s why anyone with decent eyesight and health can go from walking around in 100,000 lux sunlight, and then later on night lit only by a sliver of the moon and still able to see to a fair degree.
You know how it goes. The aggressor creeps up from behind, then stops and shouts: “Hey, I’m going to attack you now.” You turn around, pull your light out of the holster … “just a second please, Mr. aggressor” … and point your light towards him in full turbo. Only seconds later he’s ash. You know, villains always make some small talk, talk about their plans and so on. Plenty time.
I recall reading one anecdote on CPF years ago where someone successfully used a flashlight to defend himself.
He was walking along at night when he saw a group of young men approach him looking to perhaps mug him.
He pulled out his flashlight and shined it at them while asking “How can I help you boys?”
The would-be muggers instantly jumped to the (incorrect) conclusion he was a cop. They said “no problem” and abruptly changed changed course to get out of his way.
If the aggressor happens to be on his way to the toilet in the middle of the night 20,000 lumens
should be enough to keep him from falling back to sleep after the attack
Efficient self defense tools were not designed for illumination, therefore they are extremely inefficient as illumination tools.
Efficient illumination tools were not designed for self defense, therefore they are extremely inefficient as self defense tools.
Form and function. One looks like an Underwood loaded G29, and the other looks like a MS18. I have both. I just don't confuse their form, therefore I do not confuse their function.
The MS18 is rated at 1350m throw. That means a surface 1350m away has 0.25 lux cast on it. That’s as bright as things lit up by a full moon. Once eyes get used to this then it’s easily enough for a night hike. Of you looked at an MS18 from that distance then it would look as bright as a full moon.
If you half the distance then there’s 4 times as much light hitting a surface.
At 40 meters there’s about 250 lux. That’s about the same as room lighting. Shine a MS18 at a room across the street and your neighbors will think they left a light on. If they looked at your flashlight then it’d be like looking at a light bulb in the same room.
At 20 meters there’s about 1000 lux. That’s like an overcast day. Looking up at the sky where the sun is can start to get uncomfortable.
At 5 meters there’s about 20,000 lux. That’s the same as a shadow on a bright sunny day.
At 2m there about 100,000 lux that’s like a bright summer day. So that would be as bright as looking directly at the sun (don’t do that). The sun is mostly dangerous due to UV though, so while the MS18 would look bright, it still wouldn’t hurt.
Light by itself is minimally effective at best, since attackers always approach from behind. You won’t even see it coming. Only way an attacker presents himself to his victim is if they’re stoned, drunk, determined or raging pissed. Under such mental conditions light (by itself) once again is not stopping them.
IMHO light is more of a preventive tool to evade and avoid a situation. Identify threatening situations, and avoid before they are close enough to become threatening.
