Got my today. Starlight blue and Amber. Really cute keychains. Smaller then expected lol. Button is a little stiff to press but i guess ok if u are gonna use them on your keychain so wont press on so easy in pockets etc.
The UV looks kidna weird on both, but red and blue are very bright, hard capture that with phone. For the price total worth it.
I received my white K2 today but I think it is defective unit after a little use. I didn’t read manual in first use and just trying some button combos of the key. Ramping was worked well and when I turn on for first time the light. I didin’t know what combo I am activated but now my light have very slow ramping. It is like a very slow step mode without ramping. For now to adjust the brightness is very difficult. I tried to factory reset but the result is the same. Do you think is the my unit is defective?
PS
Today I tried to full discharge the battery and seem that works. The ramping is reset back to normal. After that I tried to do some random clicks and that broke the ramping again. I discharged again and that reset ramp. So there is some firmware bug related to some sort of clicks. So if you have similar problem try to full discharge light.
I wondered if others were encountering this bug. It seems to go away by itself but it does not build confidence in the quality of the product. The UI seems like a modified form of Anduril to me. If so I wish they had used the unmodified version.
Also there is bug with RGB lights and battery check mode when is present ramping issue. Time between blinks are very long almost minute. Also to reproduce that problem again it is very easy if you make some random clicks. I think to escalate BG for refund or partial refund. I also waitng to receive second K2 in red. I hope there to not have same issue like in white version which i received first.
So…. This today This happened, I pull my keys out of my pocket and notice that i only had half a flashlight.
the rest was still at the bothem of my pocket. i only remember dropping my keys once, when i just got the light.
The plastic seems to be way to hard to survive as an edc, i think i wil go back to the Nitecore tiki
Yesterday I received my second K2 in red body. I am disappointed from it. The UV and blue leds are very dimming to be useful because there is paint over them in the body plastic. I dont know is that pattern is the same for all K2 units or they differ. Also seems they used different firmware version. So far there is no present ramping bug. Also I think ramping speed on my red K2 is a little faster compared to white version. Also on my new red K2 version lowest level of SST20 led is significantly brighter compared to white version which is more like usefull moon mode.
