[Review] Skilhunt M300 - throwy EDC flashlight | XHP35, 18650
22 posts / 0 new
Lumeniac
Lumeniac's picture
Last seen: 15 hours 58 sec ago
After releases of 14500 powered Skilhunt M150 and revisited version of Skilhunt M200, it would be logical to expect that significantly brighter Skilhunt M300 would get significantly more capacious 21700 battery. For some reason, manufacturer decided to keep the same 18650 battery for this model. Be that as it may, Skilhunt M300 turned out to be good and entertaining model. so, here is my review of Skilhunt M300 in its less bright, but throwy version.
You can buy Skilhunt M300 at ALIEXPRESS
BANGGOOD
AMAZON
OFFICIAL PAGE the model.
_LED: CREE XHP35 HD / HI
Max output:
HD: ANSI 2000 Lumens
HI: ANSI 1700 Lumens
Max runtime: 30 days
Max beam distance: HD: 219 meters HI: 293 meters
Max peak beam intensity: HD: 11500 cd HI: 21500 cd
Waterproof: IPX-8
Impact resistant: 1 Meter
Battery: 1 × 18650, 2 × CR123A
Rated Range: 2.7V ~ 8.4V
Dimension: Length 111 mm / 4.37 inch
Head diameter 28 mm / 1.19 inch
Body diameter 23 mm / 0.9 inch
Weight: 72.5 g / 2.56 oz (without battery)
Accessories: User manual, Spare O-rings, Lanyard, Clip, Magnetic Charging Cable._
PACKAGE ANDAPPEARANCE
A white box with a good design, it is quite suitable for a gift
Kit includes: M300, lanyard, charging cable, clip, o-rings, plastic round instead of a magnet, instructions.
There is battery-included kit as well.
Flashlight is bigger than M200, and, again, 21700 battery would have been great for it. With all this, it seems somehow big only against of small and elegant M200. By itself, Skilhunt M300 undoubtedly fits into the typical EDC sizes, this is a regular flashlight exactly 11cm long. It is still compact.
As for the design, it is entirely designed in the same style as the two previous models: M150 and M200, see for yourself.
M150 and the first version of the design of the M200
Old and new versions of the design M200
Old M200 and M300
It can be seen that design update made the flashlight significantly more pleasing to the eye. It was only worth borrowing an azure bezel from Olight.
Let’s take look at it from all angles. Frankly, M300 is one of the best looking flashlights that I saw this year, if not the most attractive at all. It seems that there is nothing fundamentally new in appearance here, but I really do not want to let it out of my hands.
A strong magnet at tailcap can be replaced with a plastic spacer.By the way, Skilhunt could make a logical move and add a diffuser, like Lumintop do. Convenience as a camping lamp will be much more than the penny price of this appendage.
Solid and thick springs, .
The thread is well lubricated.
Knurling is quite large and tenacious. Skilhunt M300 fits comfortably in your hand.
The bezel around button, as I mentioned, is Olight-ish azure ring. The button itself is medium size, barely protruding from the body. The move is short, soft, with an average click.
Quick blind find can only be done in a standard way – by placing the clip on the opposite side. The button has a red-blue indicator of the remaining charge level. Everything remained unchanged relative to the M200.
On the opposite side – the same charge pad known for all the Skilhunt models. The magnetic strip keeps quite firmly. Although, for me, let the flashlight be 3-4 mm longer, but with standart type-c \ micro-usb. Now the user is actually tied to the native and expensive cable.
Immediately, at the same time, you can evaluate the depth of the cooling fins. I think that, as in the case of the M200, engineers made the maximum possible for a head of this size.
A smooth bezel was replaced by a toothy one. The teeth, however, are more likely decorative unlike tactical flashlight.
Glass with enlightenment, below – smooth reflector with XHP35. HD or, as in this review, less bright, but significantly more throwy XHP35 HI (i.e. without a silicone dome). The reflector has become significantly larger. In my opinion, it is already comparable in size to some kind of tactical tactical flashlights.
That, in fact, is all. Skilhunt M300 looks neat. There’s nothing to complain about, the flashlight is assembled without visible flows and has a pleasant brand look, fits wonderfully in the hand ..
UI
With the release of M200 HiCRI and Skilhunt H04, interface has changed significantly.
Now, in addition to the classic Skilhunt UI, there is a customizable interface, in popular style of Olight-Thrunite. I like this one, actually.
Attention! Do not be confused all this schemes. In fact, the old, familiar UI is exceptionally simple. The new one is only slightly more complicated in that it is possible to preselect the necessary brightness levels from the two available. In real use, the interface does not cause any difficulties at all. AT ALL, again.
HOW SKILHUNT M300 SHINES
A dedomed LED of such brightness is definitely an extremely rare choice for a flashlight. And I’m glad that the manufacturer provides the user with classic brighter and floody XHP35 HD, or a significantly more throwy XHP35 HI.
There is a question of priorities – it’s more important for someone to shine wider, someone wants to be able to enlighten further. I would choose HD, but from the perspective of the review I think that the HI version is more interesting due to its unexpectedness.
It’s easy to figure out how HD shines. But the dedomed LED is a rare option for EDC flashlight. I note that, nevertheless, I would like a warmer color temperature.
The maximum brightness is declared 2000 in the HD version and 1700 in the HI. My measurements (T2 \ T1 readings relative to 600 lumens in High1) allow me to calculate that these are true numbers. But! As for the maximum brightness in T1, you get it de jure, but it drops somewhere by 15% instantly and this is about 200 lumens. So real maximum brightness here is about 1450-1500lum.
But at such a brightness, the flashlight shines as promised, for a minute, before stepdown, and this is, actually, a lot. And there is also TIMED stepdown, you can immediately launch T1 for the second time. And further, to the very limits of common sense and the ability of your palm and batteries in flashlight to withstand heat.
There is no such problem with T2, it honestly shines its 3 minutes. Given the possibility of a restart, this is enough time to see everything around.
Well, then you can safely rely on a fully stabilized 600 lumens in H1 mode. It is quite worthy of brightness.
Generally, everything is fine. There are a lot of modes, you can configure for yourself necessary ones (or not bother with the settings and stay in the classic interface, here you have to give up essentially only instant access to the turbo).
HI version will not give you wide light, but even at low brightness you can shine at a distance that will definitely surprise a regular person who knows only noname zoomie crap.
It is unlikely that anyone would expect such a compact flashlight to shine so far (and to be so bright at maximum brightness).
The Skilhunt M300 video review contains much more examples of how this flashlight shines.
OVERALL IMPRESSION
Skilhunt M300 itself turned out to be quite good. In fact, this is a upgraded version of the upgraded M200 with classic and olite-like interfaces.
Flashlight looks cool, fits comfortable in the hand. Despite a noticeable drop in maximum brightness immediately after launch, a minute at the level of one and a half thousand is damn very decent, as well as 3 minutes at the level at which the M200 gave out only 2 minutes.
But I don’t see any logic in continuing to use 18650 battery here. In conjunction with 21700 , flashlight would work amazingly. The sizes would change by a couple of millimeters of length and width, and rutime would grow sooo much.
And personally, I see the manufacturer’s decision to stay in the new model with the familiar 18650 as erroneous.
Regardless of battery, I repeat, this model is interesting. Stylish, bright, long-range in the version with HI LED, where you can expect the ability to shine well in the distance, which fans of this light will surely appreciate. And an additional quasi-Olight interface should appeal to those who spit on the classic Skilhunt UI (i know those ones).
At the end, Skilhunt M300 is a revised and enhanced version of M200. But the flashlight could become much better and take its rightful place among the few EDC flashlights with 21700.
Along the way, due to a small increase in size, it would be possible to increase the duration of work in a turbo. And now this is a very pleasant, but one of the many 18650 flashlights. And here the choice is very wide, so Skilhunt themselves put themselves in more difficult competitive conditions. In any case, I believe that those who buy the Skilhunt M300 will not regret at all and like this model.
Isn’t that the most important thing?
Edited by: Lumeniac on 10/12/2021 - 12:23
varbos
Last seen: 3 weeks 6 days ago
Question: Did you receive any compensation from Skilhunt in exchange for the review ? Free flashlight, post-review discount etc ?
This should be stated in the opening paragraph.
MAX-MX
MAX-MX's picture
Last seen: 6 hours 10 min ago
Thanks for the review.
MascaratumB
MascaratumB's picture
Last seen: 22 min 19 sec ago
Thanks for the review Wink
Indeed another great light from Skilhunt!
I wish they could go back and make the M1500 with this perfcet(ed) UI !
Lumeniac
Lumeniac's picture
i got flashlight for review from them
mention it or not - each one decide for himself
i do not, as for me that makes no difference
if crap is crap, i call it
as you can see here, i dont lick manufacturer and mention all sujective and objective CONs that i found
i'm too long in all this to sing hymnes for any flashlight , just because that is review examplr
Yokiamy
Yokiamy's picture
Last seen: 3 hours 9 min ago
varbos wrote:
Question: Did you receive any compensation from Skilhunt in exchange for the review ? Free flashlight, post-review discount etc ? This should be stated in the opening paragraph.
Probably, ive been asked to do the review of the M300 last year, but then it got delayed due to technical issues and the light had to be improved.
I got the M150 instead, but after a not very positive review, suddenly corresponding with them was very difficult, finally i got this reaction
“ Dear friend.
Thanks for your email.We will offer free or 80% discount to the quality review, and 20% discount for simple comments as review.
You can choose M150 , M200 or M300, here is the purchase link,https://www.aliexpress.com/item/4000003884168.html
And please send me the review after you finish, we will refund via PayPal deal to the quality of reviews.
Regards
Ruan”
Lumeniac
Lumeniac's picture
not positive?i have to read it, i like  m150
i had the same situation with couple of nitecore top models several months ago
they had many flaws , which i mention in details
well, u have to understand them - who needs suchbad reviews about new product )
Danthemanz
Last seen: 10 months 5 days ago
Has anyone tried opening the bezel and getting to the LED?
Im looking for a small decent XHP35 light to replace with a nice 80 CRI warm XHP35 HI.
niajef
Last seen: 1 week 6 days ago
has anybody compared the magnetic charging time vs taking the battery out and just charging it with a regular charger? i heard magnetic charging is very slow? can anybody confirm?
FromShadowlands
FromShadowlands's picture
Last seen: 1 hour 56 min ago
Are both models 6500K ?
If not, please explain.
fromshadowlands
U.S. Coast Guard Auxiliary Aviation
Sofirn Q8 Pro - Skilhunt H300 - Astrolux FT03 - Fenix E16 - Manker MC11 II - Wurkkos TS21 - Sofirn IF22A -Wurkkos FC11 - Sofirn SC 31 Pro
https://www.flickr.com/photos/darrenwb/
EL1M1N80R
Last seen: 1 year 2 weeks ago
How does this compare to the Fenix e30r for it’s size. I an looking for a fenix e30r but I could be persuaded to get one of these..
Lumeniac
Lumeniac's picture
didnt tested Fenix, but M300 is specifc light - if you need throw from EDC size - here it is
but mostly no sidelight
id30209
id30209's picture
Last seen: 4 hours 13 min ago
I swapped emitter on mine with 90CRI 5700K and really like it.
The only thing bothers me is reflector. I never was a fan of SMO reflectors and this one just calls for OP update.
Just need to find one...
Stock reflector meassure 21.8x13.2mm.
Does anybody know where i can find one?
WTB Titanium 4sevens 2xAA tube
MascaratumB
Just need to find one…
Stock reflector meassure 21.8×13.2mm.
I would say to try it here: https://www.aliexpress.com/store/708513/search?SearchText=reflector
id30209
id30209's picture
Thx Mascaratum, seen all possible known sources without positive result.
FromShadowlands
Mine arrives today!!!
fromshadowlands
netprince
Last seen: 5 hours 6 min ago
nice review, thanks!
TheAuditor
Last seen: 2 hours 30 min ago
My M300 steps down instantly. I have tried different batteries but I don’t get 1700 lumens for more than a couple of seconds.I assume something is wrong.
Bonum commune communitatis.
Yarp.
samyy
Last seen: 1 week 2 days ago
My M300 HD behaves similarly.
Skilhunt states – 1 minute on the T1(highest level) and then stepdown to H1(third highest level).
My M300HD works only 5 – 8 seconds on T1 and then steps down to T2(second highest level).
TheAuditor
I am pretty disappointed because the M300 is supposed to be a step up from the M200 but it really isn’t. That’s th earliest Stepdown I have ever seen.
Yarp.
Tasslehoff
Tasslehoff's picture
Could the battery be the issue? On the website it says please use a high performance battery (Discharge current over 8A). Going throught the bl-135 specs the max discharge is 8A however the bl-131 has a 15A continuous drain albeit lower total mAh of 3100. I was thinking of getting this light but now not so sure?
Followup: Yeah I can confirm I bought it and it steps down nearly instantly after about 8 seconds (HI version). I’m guessing the temperature sensor is badly uncalibrated I have an Astrolux thats comes with the anduril software and that is fantastic can calibnrate the temp. I think the bl131 battery i ordered with mine is even faulty as it usually flickers twice and sometimes shuts down the light after a cold start on turbo like the 2.8V protection is falsely kicking in even fully charged with my xtar charger. Still a nice light but shouldn’t have these issues for that price.
zoulas
zoulas's picture
Last seen: 35 min 7 sec ago
I hate lights that do that. I prefer to deal with the heat. Its my light, it should be my choice, no?
